koneall Samba Member
Posted: Sat Feb 21, 2015 7:55 am Post subject: Stock air filter too old? |
I have a 1967 bug with a newish 1640cc DP stock engine. With the original oil bath air filter. I noticed with the engine idling when I lifted the oil bath off the carb there was a "whoosh" of sound as if I'd removed an obstruction to the air flow. Could the big filter top collect enough debris after 50 years and need to be replaced? Is it possible to find another top?
TIA
crvc |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 25929 Location: Olympia Wash Rinse & Repeat
Posted: Sat Feb 21, 2015 8:09 am Post subject: |
Any type of good air filter is going to cause some restriction. As long as you replace the oil in the filter as instructed in the Owners Manual it is completely self cleaning.
On the other hand if you are using too thick of oil for the weather you will have more restriction than needed. _________________ In Stereo, Where Available! |
thomas. Samba Member
Joined: July 31, 2010 Posts: 1361 Location: South West (Pa.)
Posted: Sat Feb 21, 2015 4:25 pm Post subject: |
I just bought a used oil bath filter for a type 2 and cleaned out the top filter part with brake cleaner fluid. I ended up using a whole can. I cut the side off a flat sided jug and use it like a parts cleaner. It finally started to drip clean fluid at the end of the can. let it drip dry at least overnight.
I only cleaned it because I'm going to paint it. The one in my bug I've never cleaned. Like Eric & Barb said it shouldn't need it. |
61SNRF Samba Member
Joined: March 29, 2009 Posts: 4656 Location: Whittier 90602
Posted: Sat Feb 21, 2015 7:25 pm Post subject: |
I would imagine a '67 would have a similar "element" as an earlier ACL...
Looks like Coco fiber to me, same as seat padding?
Not sure if it was treated in any way or not either, perhaps the oil just wicks up into the weave by natural capillary action?
I'm curious too as to what can be done to recondition or restore them.
For '67- Late models, OG EMPI probably came up with the best idea, which is a custom top cover and a replaceable element that fits the stock housing...
_________________ -Bruce
An ounce of prevention is worth a pound of cure.
Eric&Barb wrote: |
On the other hand if you are using too thick of oil for the weather you will have more restriction than needed. |
Using 10w30. How is an oil bath 'self cleaning'? I assumed the filter is some sort of steel wool?
crvc |
Joined: April 27, 2002 Posts: 6752 Location: Pentwater, Michigan
Posted: Sat Feb 21, 2015 7:44 pm Post subject: |
My understanding is that the oil does not clean the air it is a trap for the dirt particles. The oil does not wick up into the upper reaches of your filter. The air gets channeled to where it passed down towards the oil and then up where the dirt particles are dropped into the oil. I'm not sure that the filter should be described as self cleaning there is a procedure in the Bentley for cleaning them. _________________ Roads Scholar
Member# 2059 |
Posted: Sat Feb 21, 2015 8:39 pm Post subject: |
The top portion of the air cleaner is cleaned by the oil in the bottom portion. The air being sucked over the oil, splatters oil up into the upper part.
The below from the 1967 Beetle Owners Manual.
Note how the upper part only needs hand cleaning if someone runs the air cleaner too long filling it with dirt or without adequate oil in the bottom. _________________ In Stereo, Where Available! |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11156 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Sun Feb 22, 2015 8:43 am Post subject: |
First you need to know how an oil bath air filter works....
The majority of cleaning work is done by the oil...
The incoming air passes through the oil first and traps the dust.
The fibers are there mainly to disperse and block any liquid from entering the intake and carb.
The oil does the majority of work.. and any oily air and dust that makes it through the oil generally is trapped in the continuously re-wetted fibers which will drip back down into the filter sump when the engine is off. Hence why it gets so sludgy so fast.
Its very important to keep the oil level in the filter clean and the correct level..
The fibers can be washed and swished out in a bucket of diesel fuel or kerosene. That's the cleaning procedure for typical oil bath cleaners.
My problem is most of these nut fibers are starting to show there age.. due to non use (dry)
There is no problems with repacking accordingly it with more fibers or an alternative such as steel wool or a plastic mesh, provided you have time as trying to pack these through the intake perforation is a pain.... and taking them apart usually destroys them. The correct amount of packing is important as well..... too much restricts, too little wont disperse/block...
Finding good wet used ones at the swap meets.. is the best
With that being noted... you can gain some MPG, power and efficiency with a replaceable paper filter.
The other side of the coin... an oil bath air filter is a 100% re-useable and serviceable filter and does a pretty darn good job.
I agree the EMPI top was the ticket.. Better filter, and yet retain all the preheat functions.
Basic oil bath operation, follow the air path...
_________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
Posted: Sun Feb 22, 2015 10:20 am Post subject: |
Diagram is a bit backwards. Dirty air is sucked into the the air cleaner inlet, down around the filter element, across the bottom to the holes underneath and over the oil below, up thru the filter element, then down the center shaft into the carb. The center shaft of the filter element and the shaft of the outer filter are O-ring sealed to each other.
The cone shaped tin attached to the filter element acts as a slope for waves oil oil to be formed by the air being sucked in over it. These waves constantly wash the underside of the filter and cause oil splatter. Below the cone is a layer of very still oil where dirt from the air collects. _________________ In Stereo, Where Available! |
Posted: Sun Feb 22, 2015 11:08 am Post subject: |
Eric&Barb wrote: |
Diagram is a bit backwards. . |
UM.... its not backwards.....its just not a VW oil bath air flow diagram... Its a simple BASIC detached oil bath air filter like on tractors or industrial engines..
The principal of operation is exactly the same..
I guess I should know better by now not to use such basic diagrams for a VW as its not "correct" for a VW..
please read below and follow accordingly..
VOLKSWAGNUT wrote: |
Bottom line.. the intake vacuum is pulled through the fibers (or really atmospheric pressure is pushed though).... the oil is the main filter, the fibers or mesh is needed to create the surface area of the filter. Dust sticks to oil, oil washes fibers, drips down, dust settles or is trapped..
Air is lazy.. and follows the path of least resistance.. no mesh and it would simple bubble through the oil..
. _________________ aka Ken {o\!/o}
Posted: Sun Feb 22, 2015 1:34 pm Post subject: |
Also keep in mind that with the oil bath being self cleaning, you do have to change out the old dirt filled oil.
Were the paper air cleaner has "X" amount of tiny holes, for each minute you run the engine "X" amount of holes are being plugged up with dirt/dust right out of the air. Yes, while you can use pressurized air to push out much of the dirt/dust back out of the holes, a certain amount of the holes will not clean out. As time goes more and more of the holes will not clean out making for more and more air restriction.
The oil bath being self cleaning means you always have same air restriction.
A lot of folks found that out here when St. Helen's MT. blew its top. Those with paper air cleaners had them clog up quickly from all the fine dust all over the roads and ended up running the engines without filter. Which soon damaged them.
Those with oil bath filters just dumped/wiped out the old oil and poured in some new. _________________ In Stereo, Where Available! |
herbie1200 Samba Member
Joined: April 27, 2006 Posts: 836 Location: Rome - Italy
Posted: Mon Feb 23, 2015 2:33 am Post subject: |
Eric&Barb wrote: |
The cone shaped tin attached to the filter element acts as a slope for waves oil oil to be formed by the air being sucked in over it. These waves constantly wash the underside of the filter and cause oil splatter. Below the cone is a layer of very still oil where dirt from the air collects. |
Perfect explanation!
A point of attention: the Oring!
Whitout oring (I have never seen a used oilbath filter with oring still there) air is sucked directly by carb from the filter inlet, bypassing the filtering section.
Direct air passage, without oring, is a restriction, so I can assume at full throttle a part of air is however filtered.
But, without oring, ad idle and middle rpms, almost all air reaches the carburetor with no filtering action.
It's strange how the oring absence is underestimated by VW people.
Pheraps air leakage is less a problem than an oil or fuel leakage? |
tisius Samba Member
Joined: July 11, 2011 Posts: 1570 Location: Rotterdam,NL (+Chicago,IL)
Posted: Mon Feb 23, 2015 2:52 am Post subject: |
A proper quality paper air-filter lets air flow through quicker than a more traditional stock oil bath air-filter, while filtering action should be roughly the same.
You do need to replace the paper filter every once and a while.
More air to engine in the same time period = better performance.
However, in very sandy/dusty areas I would prefer to keep the good old oil bath air-filter (and as the original Volkswagen manual says: renew the oil in the oil bath filter more frequently in sandy/dusty conditions). _________________ drive it like you just robbed the bank
.... if it ain't dutch, it ain't much! |
Bret2094 Samba Member
Joined: March 22, 2012 Posts: 665 Location: Linden, Texas or College Station Texas
Posted: Mon Feb 23, 2015 8:17 am Post subject: |
This is the air cleaner I've used for 8 or 10 years. I had added a port for the tube that goes under the left cylinders. You can see the patch job from closing the port. The engine lid kept crushing the tube so I found a spout at Ace Hardware instead.
If I soak the upper piece in diesel overnight, how do I get rid of the diesel soaked into the fibers?
TIA,
crvc |
Posted: Mon Feb 23, 2015 8:52 am Post subject: |
A tiny amount of diesel should not affect the engine. Just drain it out over night. _________________ In Stereo, Where Available! |
Posted: Mon Feb 23, 2015 9:56 am Post subject: |
koneall wrote: |
crvc |
Eric&Barb wrote: |
A tiny amount of diesel should not affect the engine. Just drain it out over night. |
Drip or shake dry. Diesel is nothing more that refined oil...
A flush with brake cleaner will get any excess off as well.
bill may Samba Member
Joined: August 27, 2003 Posts: 14160 Location: san diego,ca
Posted: Mon Feb 23, 2015 1:45 pm Post subject: |
61SNRF wrote: |
yes it is coconut husk fiber.
there is a orange/red line inside bottom half that gets oil up to line as oil level. _________________ Admin note: Bill Passed away - July, 2017
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617 |
jzjames Samba Member
Joined: September 27, 2007 Posts: 1921 Location: Windy Point, WA
Posted: Tue Feb 24, 2015 11:38 am Post subject: |
So are you saying the intake air actually passes through liquid oil?
The way it was explained to me is the intake air, with it's accompanying dirt, is sucked down through the aircleaner center tube and then reverses upward into the carb. And in the process, the dirt particles being heavier than air continues downward into the oil and is trapped there. |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13546 Location: Tejas!
Posted: Tue Feb 24, 2015 11:48 am Post subject: |
jzjames wrote: |
This is my understanding as well. It is not a bong as suggested above (although this is a very common misconception) _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
