Pre 52 Coat Hook
Jimmy Perez
Jimmy Perez is offline
PostPosted: Sun Feb 22, 2015 10:17 am    Post subject: Pre 52 Coat Hook Reply with quote
Question, is this pre 52 Barndoor coat hook, not my picture but I have same coat hook all metal, not aluminum. A little different than 52 to 58 aluminium coat hooks also has indentation on top side when resting in up lock position. Anyone with early Barndoor have the same coat hook, any information is helpful.
Thanks in advance Jimmy
Single Cab, Swapmeet Mafia$
austriadeluxe
austriadeluxe is offline
PostPosted: Tue Feb 24, 2015 3:38 am    Post subject: Reply with quote
As far as I know those hooks were accessory and were used in a lots of cars in the 50ies, 60ies, not a VW only part. Correct me if I´m wrong.
djfordmanjack
djfordmanjack is offline
PostPosted: Tue Feb 24, 2015 4:55 pm    Post subject: Reply with quote
all aluminium ( except steel blade spring), I have the same as pictured! came from a VW. as Gerald mentioned these were accessory and universal fit, but maybe VW used them as OEM equipment for the first buses. these hooks don't have any casting or manufacturer numbers, but I guess they would be marketed by a companies like Hagus, GHE, Perohaus aso
54 Oval project
62 Dickholmer, Seeblau L360
Jimmy Perez
PostPosted: Fri Feb 27, 2015 10:28 pm    Post subject: Reply with quote
This coat hook simular to aluminum coat hook but all metal not aluminum with indentation on topside, same as the one in picture on 51 Barndoor, maybe pre 52.
