jpjohns Samba Member
Joined: May 03, 2014 Posts: 882 Location: Harrisonburg, VA
Posted: Wed Feb 25, 2015 2:03 pm Post subject: Placing jackstands |
When removing the engine, where would be the best place to put the jack and the jack stands in the rear? I did a search but they all seem to differ. _________________ -Jared
"Scrapyards are for quitters" - Beetlenut (a Samba member) |
SoCalJes Samba Member
Joined: November 02, 2011 Posts: 1093 Location: Broward, FL
Posted: Wed Feb 25, 2015 2:10 pm Post subject: |
I placed the jacks on the rear arms on mine. _________________ Jesse
71 Ghia
______________________________________
Just because it didn't come that way, doesn't mean it shouldn't have. |
c21darrel Samba Member
Joined: January 22, 2009 Posts: 8237 Location: San Dimas
CHUBB805 Samba Member
Posted: Wed Feb 25, 2015 2:22 pm Post subject: |
I put the jack stands under the torsion tube so that they aren't in the way when you're trying to get the motor out. |
oorwullie Samba Member
Joined: May 01, 2003 Posts: 2365 Location: fribourg,switzerland
Posted: Wed Feb 25, 2015 2:26 pm Post subject: |
i've never understood why people want to get the car up so high to get the engine out.
i've always dropped the engine to the floor then raised the car/bus with a large trolley jack to slide the engine out and then let the vehicle back down on it's wheels again.
but that's just me, so do whatever ya like guys.  |
tisius Samba Member
Joined: July 11, 2011 Posts: 1570 Location: Rotterdam,NL (+Chicago,IL)
Posted: Thu Feb 26, 2015 4:25 am Post subject: |
Same here.
I take the engine out first, and let it sit on a flat mdf panel on the garage floor (I can grab the panel and use it as a skid with the engine on it).
Then I jack up the car (I put a wooden block on the jack and then place it underneath the Y section of the trans carrier arms so I can raise the rear as much as possible with the jack... but I do make sure that no floorpan or other vulnerable parts are touched by the wood or jack, since the weight of the car will rest on the wooden block when I start jacking). That will give me enough clearance to slide the engine from under the car's rear end.
And then I support the car with long jack stands (underneath the torsion tube) for more safety.
Finally I pull the mdf sheet with the engine on it from underneath the rear of the car ... job done. _________________ drive it like you just robbed the bank
.... if it ain't dutch, it ain't much! |
CiderGuy Samba Member
Joined: December 23, 2013 Posts: 1351 Location: Bucks County, Pa
Posted: Thu Feb 26, 2015 7:44 am Post subject: |
oorwullie wrote: |
Isn't the engine in the way for the trolley jack? I mean there are only a few areas where you can lift the car without bending or damaging things.
I jacked my car up really high and placed in on jack stands, made it very easy to get to the bolts to drop the motor. _________________ ----------------------
Cars Currently Owned:
1970 Karmann Ghia Coupe
1973 Karmann Ghia Coupe - Project car for sale
1970 Karmann Ghia Convertible (Body off restoration)
Timing is everything |
Posted: Thu Feb 26, 2015 10:02 am Post subject: |
CiderGuy wrote: |
oorwullie wrote: |
I jacked my car up really high and placed in on jack stands, made it very easy to get to the bolts to drop the motor. |
i go in from the side in front of the rear wheels and lift from the middle in front of the tranny.
and i lift the car from the same place to take the bottom engine to bell housing nuts off. without securing it with axle stands...................
yes, i have proper big trolley jacks.  |
didget69 Samba Member
Joined: July 22, 2004 Posts: 4942 Location: Raleigh, North Carolina
Posted: Thu Feb 26, 2015 10:58 am Post subject: Jackstands |
Place the jackstands under the rear torsion tubes at the 'inner side' -
Don't jack up or support the car at the outer ends of the torsion tubes (at the spring plates), as it can screw up the rubber bushings.
bnc _________________ I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door. |
mountainkowboy Samba Member
Posted: Thu Feb 26, 2015 12:34 pm Post subject: |
get an ATV/motorcycle jack, pull engine, drop jack, raise car above engine, roll out. _________________ Chuck in Socal
71 Super Convertible...DD
78 Honda CB750K
06 Honda CR-V (wifes)
63 IH Scout 80 "Beater" |
Posted: Thu Feb 26, 2015 9:43 pm Post subject: |
mountainkowboy wrote: |
get an ATV/motorcycle jack, pull engine, drop jack, raise car above engine, roll out. |
I just use one of these
to drop the engine onto one of these...
- with the exhaust/heater boxes resting on the carpeted sections.
Posted: Fri Feb 27, 2015 3:46 am Post subject: |
didget69 wrote: |
bnc |
that's pretty much what i use as well so thanks for the fine illustrations even if they won't convince many to do it the easy way.  |
Posted: Fri Feb 27, 2015 9:00 am Post subject: |
didget69 wrote: |
bnc |
I have a dolly like that, thanks. I'll have to try the lowering it to the floor then raising the car trick. _________________ -Jared
Stuart Maingot Samba Member
Joined: December 13, 2009 Posts: 240 Location: Trinidad West Indies
Posted: Fri Feb 27, 2015 11:41 am Post subject: |
I would always just back the rear wheels up on 2 wooden blocks each approx 5 " high that I made for this purpose. This gets the right height for my trolley jack and I don't have to jack the body up and down each time I remove and replace the engine. |
Posted: Fri Feb 27, 2015 3:43 pm Post subject: |
Since I have a motorcycle I already had the jack, using it, I pulled the engine from the vert, replaced the donuts on the oil cooler and put it in the Ghia in 3 hours by myself without having to lift anything by hand. But then I'm an old guy with bad shoulders and knees.  _________________ Chuck in Socal
78 Honda CB750K
Posted: Sat Feb 28, 2015 4:31 am Post subject: |
i can understand using the motorsickle jack if you already have one but it's a mystery why people buy one instead of a good 2 ton trolley jack and then have the car fall down while using a crappy scissor jack from wallmart or suchlike.  |
Posted: Sat Feb 28, 2015 6:09 am Post subject: |
oorwullie wrote: |
I just pulled an engine a couple of weeks ago. How are you getting to the two lower studs that connect the engine to the transmission without jacking the car up first? _________________ ----------------------
Posted: Sat Feb 28, 2015 6:31 am Post subject: |
CiderGuy wrote: |
oorwullie wrote: |
I just pulled an engine a couple of weeks ago. How are you getting to the two lower studs that connect the engine to the transmission without jacking the car up first? |
go back and read everything that i actually wrote............
and delete your duplicate post while you're there.  |
Posted: Sat Feb 28, 2015 6:56 am Post subject: |
and ciderguy, please don't send me any more private messages unless you have something creative to say. |
Posted: Sat Feb 28, 2015 3:11 pm Post subject: |
oorwullie wrote: |
Guilty as charged I did miss your post, I just didn't see it, but does that give you any reason to act like a horse's ass? _________________ ----------------------
