25hp generator pulley
Rusting Hulk
Rusting Hulk is offline
PostPosted: Sun Dec 04, 2005 2:55 pm    Post subject: 25hp generator pulley Reply with quote
I'm asking on this forum to get a pic of a 25hp pulley but the engine i'm building is for a 55 and i'm not sure of the type of pulley to use on the generator, i have a three piece 36hp pulley with the fat lip on the outer half of the pulley. But i'm thinking it should still have the thin lipped 25hp pulley. I have a 54 hand book and it shows pics of the thin slot generator with round regulator with a 25 hp pulley.
Any thoughts help with pics greatly appreciated
64 356 C Coupe
UZI
Platinum FUBU
UZI is offline
PostPosted: Sun Dec 04, 2005 3:17 pm    Post subject: Reply with quote
simon, how detailed do you need?
i could have a close-up for you tomorrow
Extravagant Lifestyle
PostPosted: Sun Dec 04, 2005 5:13 pm    Post subject: Reply with quote
My '55 Barndoor original engine had the thin lipped upper pulley.
RareAir
RareAir is offline
PostPosted: Sun Dec 04, 2005 6:26 pm    Post subject: Reply with quote
If you're using the thin-lipped pulley, then you'll need the 36mm nut. Both of which is correct for a Pre '55 motor. The lower crank pulley should also have no lip, as opposed to a curved lip pulley which was introduced in 1956 to coincide with the newer fat-lipped generator pulley & 21mm nut.
Rusting Hulk
PostPosted: Sun Dec 04, 2005 11:09 pm    Post subject: Reply with quote
Uzi, could you get me a picture of the three pieces apart so i know what the front/back and the hub look like, i think i have the parts but need to compare with something.
thankyou
Simon
64 356 C Coupe
PostPosted: Mon Dec 05, 2005 10:22 am    Post subject: Reply with quote
More info:
The toolkit changed to remove the larger generator pulley wrench on August 4th, 1955 so I would assume the 36 mm pulley nut was also changed at that time.
johnshenry
johnshenry is offline
PostPosted: Mon Dec 05, 2005 5:19 pm    Post subject: Reply with quote
John Henry
'57 Deluxe
'56 Single Cab
Rusting Hulk
PostPosted: Mon Dec 05, 2005 11:05 pm    Post subject: Reply with quote
John thankyou very much, exactly what i wanted, and i think i have one.
Simon
64 356 C Coupe
SplitPersonality
SplitPersonality is offline
PostPosted: Mon Apr 28, 2014 12:37 am    Post subject: Reply with quote
Ole thread I know...but still:
Where can I buy the puller-tool to get the original thin lip 25HP crank pulley off in the correct manner?
Robert Chambers
Robert Chambers is offline
PostPosted: Mon Apr 28, 2014 4:32 am    Post subject: Reply with quote
This may be what you need? http://www.thesamba.com/vw/classifieds/detail.php?id=1605077
'63 OG 117 Herbie Replica
'56 Euro Oval Deluxe
'52 Standard Zwitter
'63 OG 117
SplitPersonality
PostPosted: Wed Mar 04, 2015 5:08 am    Post subject: Reply with quote
Regarding early generators:
The change from 36mm to 21 mm nut on the pulley was mid-1955.
When was the change from "thin lip" pulley to "deep draw pulley"....but maintaining the big nut on both?
PostPosted: Wed Mar 04, 2015 10:12 am    Post subject: Reply with quote
Looking at progressive refinements, this is the only thing I found:
21 Dec. 53
Beetle: 1-0575415 695 282
Bus: 20-069409 695 356
Industrial: 122-019 888
Pulley
Now: 1.25mm sheet metal
Formerly: 1.0 mm thick
This is also the change date for 36hp engines.
Note: This doesn't sound right to me as I thought 54s and 55s has the thin lip lower pulley too but I don't see another entry.
And this is a late-1955 bus engine, engine # 20-1251855 (December, 1955)
I see that RareAir above said it changed for 1956.
I could not find any other information on the change.
Other stuff (upper pulley changes)
