Thebeas Samba Member
Joined: February 27, 2015 Posts: 159 Location: Mississippi
Posted: Sat Mar 21, 2015 11:13 am Post subject: Oil plug head stripped off |
I've seen multiple threads about threads on the plug being stripped out but I can't find one on my issue. I can't get my socket to grab.
Is this another one of those left handed drill bit fixes I have never had luck with???
Otherwise things have gone great recently...just got my tune up kit from gowesty and this was the last step for me  _________________ 1983 2WD 1.9 Digijet |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32988 Location: Reading Pennsylvania
Posted: Sat Mar 21, 2015 11:46 am Post subject: |
I was hoping for an easy solution...you da man!
Thanks _________________ 1983 2WD 1.9 Digijet |
Posted: Sat Mar 21, 2015 12:08 pm Post subject: |
| You can probably get it out with the tool shown above. You could try beating on a six point socket and that might do the job as well. If neither of the above work you can get someone to weld a nut onto the plug and it will probably almost spin out on its own. |
Posted: Sun Mar 22, 2015 9:00 am Post subject: |
And then when you get the socket kit and it still continues to just strip??? This is frustrating
Posted: Sun Mar 22, 2015 9:15 am Post subject: |
Have you tried Visegrips yet? You might take a sacrificial 10" curved jawed set and grind the jaws off at a bit at an° angle and do any other grinding as necessary to get the jaws a nice full bite on the plug. Waste out a real Visegrip set, most junk off brand sets aren't up to biting hard and holding on at a weird angle. An old tattered set of real vise grips shouldn't cost you much and once worked over a bit may serve you well in the future on other projects.
That neighbor down the street with the welder is probably just dying to help you out and tell you his VW stories. |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10357 Location: N. Idaho
Posted: Sun Mar 22, 2015 9:20 am Post subject: |
It's an old fashioned way, but I have also had good luck with a cold chisel and hammer. A couple hits break it loose and then you are off to the races. Yours is getting so distorted with loss of metal you may be ready to pound on a 6 point socket that is one size smaller. Often there is an SAE size (vs metric you are using) that is smaller and between the correct size metric you have and the next size down metric. Note you are also perfectly positioned for a trick I used once on a vehicle to use a floor jack to keep the socket from popping off. Use a breaker bar with the socket, and a small piece of wood under the breaker bar, and a floor jack to lift up and hold the socket on. Put a good bit of pressure upwards (maybe 100lbs) and turn - pop! _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1993 Toyota LandCruiser, 2002 BMW 325iX, 1982 Toyota Sunrader |
Mulcheese Samba Member
Joined: September 19, 2004 Posts: 548 Location: Maple Grove, Mn
Posted: Sun Mar 22, 2015 9:30 am Post subject: |
Been there once before. Many years ago when I got the van I went to do the first oil change and bam. I was in your shoes and more. The more is I tried the multiple size scoket technique. Hammered on many different ones until it was round. Then out came the vise grip. You can imagine how that turned out. I then tried to cut, with a dremel, some sides to have a tool grab onto but that also didnt work. Soon there was little remaining of the original head. I figured what the hell. Nothing to lose now. I knew it was going to be drilled out at some point so I tried an easy-out.
http://www.sears.com/craftsman-10-pc-screw-extract...Redirect=y
I made sure that the head was as flat as possible. Yours seems still fairly good. Mine was much more mangled. Located the center as best I could. As close to center is key so that the easyout has enough material to grab on to. Tapped a hole correct for the easy out. Threaded it in with an adjustable wrench and damn. It came lose. Out it goes and upo to the parts store for a new plug and in it goes. You may end up pulling the threads out if it is that tight, then again maybe not. Go easy so the easy out starts to bore in to the bolt.
These are a must to have in the shop. Time to buy a new tool. _________________ 82 Westy: Air is cool! |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 10299 Location: Mt Lemmon, AZ
Posted: Sun Mar 22, 2015 10:44 am Post subject: |
Never tried this so perhaps file it under 'straws, Grasping at' but...
I would be tempted to cut a slot with a Dremel that would accept a flat-blade screwdriver. Then use a screwdriver bit (a big one) in a ratchet wrench.
Harbor Freight sell a handy set of bits and adaptors:
http://www.harborfreight.com/100-pc-security-bit-set-with-case-68457.html |
Posted: Sun Mar 22, 2015 11:05 am Post subject: |
I was just laying under the van and had the same dremel idea. I think i might got that route here in a bit.
I don't have a welder, nor do i know anyone that does. I wish I had a gear head buddy, but you guys are my best option.
I've never had luck with the easy outs....they break every single time.
I guess since the van is perfectly drivable I may just find a mechanic tomorrow before i do any real damage. _________________ 1983 2WD 1.9 Digijet |
Posted: Sun Mar 22, 2015 11:31 am Post subject: |
| Thebeas wrote: |
| ...I've never had luck with the easy outs....they break every single time... |
Me too. I had a stud broken off in an iron manifold. The shop I called said they'd take it out for 20 bucks -- IF I hadn't messed with it. If I broke an EZOut in there then it would cost whatever it would cost ($$$). |
Posted: Sun Mar 22, 2015 12:09 pm Post subject: |
You can use a pretty large easyout on a drain plug, pretty minimal chance of breaking one that large. Also if you find the center well you can use progressively larger bits until you drill the head off the plug. Once the head is gone assuming the threads are good the plug will screw out with little force.
Multiple methods can be used at the same time if you have a buddy to help. Drill and start the easyout in and then while applying moderate force have your buddy use a chisel to help jar the plug loose. |
atomatom Samba Member
Joined: May 15, 2012 Posts: 1911 Location: in an 84 Westy or Bowen Island, BC
Posted: Sun Mar 22, 2015 1:12 pm Post subject: |
| Wildthings wrote: |
| Have you tried Visegrips yet? |
this would be my approach... get a firm bite, easier said than done perhaps. then use another pair of visegrips on the first pair so you have a bit of leverage and are less likely to twist the first pair off. _________________ 84 Vanagon Westy, 1.9L, California raised but defected to Canada. |
rubbachicken Samba Member
Posted: Sun Mar 22, 2015 6:07 pm Post subject: |
I know you're getting a million pieces of advice, but I urge you to try the jack trick. The reason the socket slips is because it is ramping itself up and away from the bolt - it's not tearing the points off the bolt, or distorting the bolt. So if you keep the socket from being able to ramp itself up off the bolt, it will provide normal twisting forces. If you don't have a jack, simply get stuff under it that holds the wrench up, then load a bunch of stuff in the van and it will work fine. Or let air out of the tires, or have a couple neighbors sit on the cargo sill, etc.
Its got to be the fastest of all the suggested methods..... _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1993 Toyota LandCruiser, 2002 BMW 325iX, 1982 Toyota Sunrader |
FNGRUVN Samba Member
Joined: October 27, 2007 Posts: 2237 Location: Fort Collins, CO
Posted: Sun Mar 22, 2015 6:46 pm Post subject: |
If you don't have one already, I'd get a replacement plug before you take that one out. If it were me, I'd take the van to a welding shop and have a nut welded on. _________________ "Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote." - Benjamin Franklin |
Posted: Sun Mar 22, 2015 7:41 pm Post subject: |
That's a really good point! _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1993 Toyota LandCruiser, 2002 BMW 325iX, 1982 Toyota Sunrader |
