Yorvo Samba Member
Joined: March 30, 2008 Posts: 131 Location: Lake Havasu City, AZ
Posted: Mon Apr 13, 2015 2:39 pm Post subject: Red light on |
I just changed the fuel pump on my 65 and now the red light is staying on bright after I start it. I knocked the coil wire loose while changing the pump but I've put it back and have checked all other wires. Everything seems connected. The battery may have worn down a bit trying to start it. Could any of this be related or is it all a coincidence? Any suggestions?
Thanks!! |
rcroane  Samba Member
Joined: January 03, 2013 Posts: 2018 Location: Springfield, Virginia
Posted: Mon Apr 13, 2015 4:20 pm Post subject: |
Other symptoms? Is is idling ok? What type of fuel pump did you install? Did you check the pressure? Many of the aftermarket fuel pumps put out way too much pressure. |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 26086 Location: Olympia Wash Rinse & Repeat
Posted: Mon Apr 13, 2015 6:41 pm Post subject: |
Check the wiring from your alt or gen to battery. _________________ In Stereo, Where Available! |
Yorvo Samba Member
Posted: Mon Apr 13, 2015 7:46 pm Post subject: |
I haven't checked pressure. That makes sense. I changed the oil thinking some gas may have got into it when the old fuel pump blew. (also an aftermarket). But it didn't change the light being on. It's a constant on after I start it. No flickering. The wiring appears to be hooked up. |
Posted: Tue Apr 14, 2015 4:12 pm Post subject: |
Red light for your year of bug should be the generator. Green light is oil pressure.....
Lots more info you need to know in the Owner's Manual you can access thru the "Technical" button at upper right of this webpage. _________________ In Stereo, Where Available! |
Posted: Tue Apr 14, 2015 6:32 pm Post subject: |
Eric&Barb....I think he was referring to the fuel pump pressure that I asked about in my earlier post. |
Posted: Tue Apr 14, 2015 9:12 pm Post subject: |
Yorvo wrote: |
Still sounds like OP is talking about the red light... _________________ In Stereo, Where Available! |
Aynthm Samba Member
Joined: July 07, 2010 Posts: 1315 Location: Beaverton, Oregon
Posted: Tue Apr 14, 2015 11:18 pm Post subject: |
Which coil wire did you knock loose?
Yorvo Samba Member
Posted: Wed Apr 15, 2015 10:03 am Post subject: |
Thanks guys. I knocked the wire from the distributer to the coil. All the wires seem to be back in place. My "How To Keep A Volkswagon Alive" book said the red light was also for oil in my year. My mechanic suggested checking the oil for the gas. I'm thinking it's the voltage regulator or the generator or the wiring to. I checked the battery and it lost a bit of charge. Thought it might have been from cranking it over from the fuel pump issues. I charged it and the light is still on. I drove it around the block a couple times and it lost charge again. The battery is new.
I picked up a multimeter last night and I'll start checking when I get some time. |
mukluk Samba Member
Joined: October 18, 2012 Posts: 7452 Location: Clyde, TX
Posted: Wed Apr 15, 2015 10:17 am Post subject: |
For clarification's sake, is the red light you're referencing to the left or to the right of your turn signal indicator in the speedometer? _________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Wed Apr 15, 2015 10:24 am Post subject: |
Take off the wire from the oil pressure sender, make sure it is not grounding out and turn on the ignition switch to "Run" position. One of the two lights will be out, that one will be the oil or should be if wired correctly.
Idiot's manual is nice but has a lot of wrong info or easy for beginner to mix up later info with info for early VW.
Get the Bentley reprint of the VW dealer workshop manual:
http://www.amazon.com/Volkswagen-1200-Workshop-Man...hop+manual
You can find good used ones for a lot less if need be. _________________ In Stereo, Where Available! |
Yorvo Samba Member
Posted: Fri Apr 17, 2015 9:00 am Post subject: |
Thanks! Yeah, I pulled the wire from the oil sensor. Yep, wrong light. I changed oil for nothing. Haha. I tested the battery under load with a multimeter. It's not taking a charge. So now it's time to go through and find the problem. |
Harleyelf Samba Member
Joined: April 23, 2009 Posts: 1573 Location: Appleton, WI
Posted: Fri Apr 17, 2015 9:50 am Post subject: |
See if the wire is pinched to ground somewhere. The key is that it happened suddenly after you worked on it. Go back and re-trace your steps; it's probably something you touched.
Both lights get power from the key and ground out to light up when the circuit involved is not in a running state. Oil light grounds when you have low pressure and generator light grounds when charging voltage is less than battery voltage. Might you have dislodged a generator wire? |
Yorvo Samba Member
Posted: Fri Apr 17, 2015 10:28 am Post subject: |
It has to be something I did. Because it's a steady bright on. All of the sudden. Everything seems connected. I'll inspect the wires better. |
Posted: Fri Apr 17, 2015 10:31 am Post subject: |
Maybe post a few pictures of your engine so we can possibly spot a wire out of place? |
Aynthm Samba Member
Posted: Fri Apr 17, 2015 10:34 pm Post subject: |
rcroane wrote: |
Yorvo Samba Member
Posted: Sat Apr 18, 2015 8:57 am Post subject: |
This is what I've got.
Aynthm Samba Member
Posted: Sat Apr 18, 2015 1:20 pm Post subject: |
someone is going to have fun with this one, i dont have time right now. sorry. |
mukluk Samba Member
Posted: Sat Apr 18, 2015 1:45 pm Post subject: |
Other than being filthy and having a rather interesting throttle return spring setup, things seem to be generally in order. I'd start by cleaning and reconnecting all the wires on the voltage regulator, followed by checking to make sure the generator is actually working, brushes in good shape, etc. _________________ 1960 Ragtop w/Semaphores "Inga" |
mukluk Samba Member
Posted: Sat Apr 18, 2015 1:47 pm Post subject: |
Oh, and the metal tube for your distributor vacuum advance is installed upside down. _________________ 1960 Ragtop w/Semaphores "Inga" |
