ppgpaintlady Samba Member
Posted: Mon Jun 18, 2012 3:26 pm Post subject: Re: L21 Mixing codes |
Austin16V wrote: |
Hi,
My local paint shop have no codes for L21 (pearl Grey).
I am after some 2K and some cellulose.
They use ICI for 2K and Maxmayer for celly.
Any help appreciated!
Thanks |
--I only see that is avalible in PPG Global DG, Sorry! |
matumorales Samba Member
Joined: August 21, 2012 Posts: 5 Location: Asunción, Paraguay
Posted: Tue Aug 21, 2012 2:38 pm Post subject: Paint codes Holy Grail |
Hello, everybody!
This is my first post, and I hope everyone appreciates it! I've just stumbled across the Holy Grail of Glasurit Paint codes:
http://color-online.glasurit.com/
At this website, you just type the paint code you desire to obtain a formula of (i.e.: "L457" for the all-time most sought-after "Cadmium Red") on the first field up left and press the "Start Search" button. BINGO! You have just found your color!
Then you click on the color's name (middle field) and select your paint line in the bottom left field (usually formulas are for paint line 22 and 68, although you might find some line 55 paints occasionally) and then press the "Next" button on the bottom-right corner of the page. VOILÁ!! You have all the formulas to get that exact paint color!
Usually, you don't only get one formula, you can get many different base combination formulas that reproduce the exact same color!! L456 Ruby Red had 4 different mix-ups!! YAY!!!
Besides, you can enter your target value (in kilograms or liters) for how much paint you want to get, the page will automatically calculate how much of each base you need to mix (in grams) to obtain the exact amount of paint you specified... or, you can specify if you're dealing with a small, medium or large car, and then check the panels you intend to paint (i.e., one fender and one door) on the sample car that's on the side and the page actually calculates how much paint you need to paint that panel... and then, you can PRINT all the results!!!! Not only the formula for your target value, but also a comparative of different default target values, and the Cumulative Values of each base being added
Most codes are available in Glasurit line 22 base (AD2224)
Is this amazing or what?? |
woodwerker Samba Member
Joined: September 02, 2004 Posts: 194 Location: Chicago
Posted: Fri Oct 12, 2012 6:50 am Post subject: |
Anybody know what the Glasurit variant codes on that site mean?
Glasurit Line 22
Glasurit Line 90
Glasurit Line 68
Glasurit Line 55
Posted: Fri Oct 12, 2012 7:21 am Post subject: |
woodwerker wrote: |
Glasurit Line 22
Glasurit Line 90
Glasurit Line 68
Glasurit Line 55
It refers to the different basecoat systems. Line 90, for instance, is water-borne, while lines 22 and 55 are solvent-borne. It all depends on the color-system your paint shop offers. The formulas are different from one line to another, because the base colors used to achieve the desired tone are also different. |
58silvert Samba Member
Joined: September 05, 2012 Posts: 28 Location: california
Posted: Fri Feb 15, 2013 9:29 pm Post subject: |
Here is the DoveBlue code and formula from AkzoNobel Sikkens. This is by far one of the best paints out there.
This is a 2 stage, so base and clear coat.
Is made from their autowave MM line, which is the latest ecofriendly waterborne paint. Let me know if you guys need other colors as I will be posting some of the popular ones soon.
AKZO code is FLNA50549
Here are the toner need it
098 41.2g
971 1.1g
575 12.3g
744 23.4g
Activator waterborne 29.2g
This formula gives you 0.10 liters, is what I use to make the spray out card in the picture.
Gustav_t Samba Member
Posted: Tue May 20, 2014 5:26 am Post subject: |
1972 combi - cargo floor colour?
I was told that it was L275 leight beige.
My painter says thats a 1955 metallic colour!!!
G. _________________ 1951 deluxe
1967 razoredge
1964 panelvan
1967 fastback TL
1967 callooker
1972 Poba camper conversion |
cgolloub Samba Member
Posted: Tue Jun 17, 2014 7:41 am Post subject: Chromabase L90D and L30B |
I am restoring 1973 Bus. After much time and phone calls, I found out that the Pastel white (L90D) has a Chromabse nunmber 8561K and Kasan Red (L30B) is RS583K, Hope this helps some one... |
NoRules Samba Member
Joined: August 17, 2014 Posts: 2 Location: Cloverdale, BC, Canada
Posted: Sun Nov 23, 2014 5:03 pm Post subject: Does anyone know the paint code crossover number for L62 ivo |
Does anyone know the paint code crossover number for L62 ivory for BASF RM paint? OR know where i can find it?
Thanks jerry
jerryc1963@gmail .com |
nordtveit Samba Member
Posted: Mon Dec 22, 2014 4:57 am Post subject: colour code for my Blaupunkt split radio |
Anyone know what colour it is on the face plate of this radio?
easy e Samba Member
Joined: May 28, 2008 Posts: 3939 Location: 1 hr north of Santa Barbara
Mark W. Roush Samba Member
Joined: April 22, 2014 Posts: 3 Location: Santa Fe, NM
Posted: Wed Mar 25, 2015 6:13 pm Post subject: 1984 Vanagon Paint Color LH9D Damuso White |
Since it seems that LH9D Damuso White was only used in 1983 -84, I cannot find any way to match it and would like to get as close as I can. Does anyone know of a supplier of this original color? Scanners don't even seem to be able to get close! Thanks, Mark |
karmann1st Samba Member
Joined: September 12, 2010 Posts: 93 Location: Florida
Posted: Sun Apr 26, 2015 5:13 pm Post subject: Factory Paint code 24 question |
Hi everyone,
after looking at my 71 ghia VIN number 1412436742
and thanks to the samba VIN decoder I realized that the factory paint Code for my ghia is #24.
I am looking all the technical data for a 71 and others and I can't find a factory code 24.
I will appreciate any help.
Regards,
AG _________________ Questions? Email me, I always answer all emails, same day or next. |
wcfvw69 Samba Purist
Posted: Tue Sep 29, 2015 1:56 pm Post subject: |
https://www.thesamba.com/vw/gallery/pix/1409905.jpg
L-581 Wolkenweiss paint code BASF _________________ Contact me at [email protected]
The Samba member since 2004.
jmvw Samba Member
Posted: Thu Oct 01, 2015 4:57 pm Post subject: |
I found what seems to be a good match for L471 stone beige.
It's from Dimension's D5 line (single stage urethane) and the color code is 50684. I'll post a pic once I get it sprayed on my wheels. |
jmvw Samba Member
Posted: Fri Oct 09, 2015 3:41 pm Post subject: |
Have you guys seen this site?
http://colorexplorer.rmpaint.com
It works just like the Glasurit site at http://coloronline.glasurit.com, but brings up formulas for other RM/BASF paints -- the single stage urethane UNO line, most notably.
I couldn't find anyone local with Glasurit Line 22, but I did find a shop with UNO, so I got my L457 Cadmium Red for my wheels . |
Tcash Samba Member
Joined: July 20, 2011 Posts: 12846 Location: San Jose, California, USA
jmvw Samba Member
Posted: Thu Oct 22, 2015 10:39 am Post subject: |
Here's a pic of one of my wheels in Stone Beige and Cadmium Red.
If you look closely at the chips on the ground, you'll see the beige one is split in half -- the left side was sprayed with the L471 Stone Beige interior paint from Wolfsburg West and the right side was sprayed with the D5 50684 that was color-matched. In the picture the right side looks lighter, but it's just because it's glossier.
jtauxe  Samba Member
Joined: September 30, 2004 Posts: 5974 Location: Los Alamos, New Mexico, USA
Posted: Wed Mar 30, 2016 5:42 pm Post subject: Re: Paint mixing FAQ |
In a paint color thread that I cannot seem to find now, someone asked if I could post the recipes for the paint codes that I had got from Sherwin-Williams Automotive. Here goes (and if anyone finds that thread again, please let me know). These are the values from the sticker on the can.
Base Paint: Dimension DM628
L65K Ravenna Green:
Code: |
DM628 Base Paint 75.77 g
DM529 Clean Yel 70.89 g
DM528 Ferrite 16.63 g
DM504 Yellow G 3.29 g
DM522 Strong W 0.08 g
L64M Apple Green: (I think they struggled a bit with this one)
Code: |
DM628 Base Paint 77.50 g
DM529 Clean Yel 52.43 g
DM505 Green 17.64 g
DM526 Red Yell 12.58 g
DM510 Blue 2.29 g
DM524 Dark Yel 1.91 g
DM504 Yellow G 0.95 g
DM500 Strong B 0.48 g
DM511 Blue Gre 0.48 g
DM522 Strong W 0.29 g
I believe that these are both in their system, as was Olympic Blue (the stripe color). _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
Tcash Samba Member
oldthingguy Samba Member
Joined: December 02, 2007 Posts: 146 Location: California
Posted: Tue Jun 14, 2016 7:11 pm Post subject: Re: Paint mixing FAQ |
I have a 1963 single cab - the exterior is L380 Turquoise and the interior appears to be Ivory? Would that be the same as the exterior Ivory L62? I found an aerosol for the green, any matches for the interior? Thank you. _________________ 73 914 2.0 - sold
63 single cab
73, 73 and 74 Thing - gone
64 notch - gone
60 23 window - gone
57 oval - gone
plus a few others I should have kept |
