Help with shifter purchase.
DWP
DWP is offline
PostPosted: Tue Apr 28, 2015 4:51 am    Post subject: Help with shifter purchase. Reply with quote
Need recomendations for a shifter that is bent back about 4"-6". from stock for my Baja. After mounting the seats further back it's hard to reach 1st and 3rd.
I am thinking about the Scat Dragfast for early bugs.
DWP
Brian
Brian is offline
PostPosted: Tue Apr 28, 2015 8:42 am    Post subject: Reply with quote
Stock 67 down shifters have that bend to them, not sure how much. Hurst and EMPI knock offs are pretty nice too.
Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter
DWP
DWP is offline
PostPosted: Tue Apr 28, 2015 9:00 am    Post subject: Reply with quote
Thanks, i will look at them. I was considering the bugpac shiftright but was told it only bends back about 2".
In the photo below you can see how i raised the shift plate and brake plate. The body has a 3" lift and 3 rib trans.After mounting the seats i realized i should of moved the shifter back.
Anybody know how far back the Early Scat handle is bent?
DWP
ORANGECRUSHer
ORANGECRUSHer is offline
PostPosted: Tue Apr 28, 2015 11:55 am    Post subject: Reply with quote
Is that a steering coupler I see between your shift box and P-brake box???
Brian H.
OrangeCrushERBerrien Warrior-2.4L Quad4-2x3 arms-1.5Fox coilovers-094-930CVs
LAZY MARY1970 Baja 2110cc-82mm CB forged crank-AA pistons/cylinders-Grant rings-1.1 vw rockers-CB serpkit-CB chromoly PRs-CB maxiflow filter pump-wix51515 filter-Dual 44IDF-cut/turned front beam-AEM wideband-Auber CHT-Donaldson Dual PowerCore filters-custom AL air boxes
DWP
DWP is offline
PostPosted: Tue Apr 28, 2015 12:12 pm    Post subject: Reply with quote
Yes I was having a little fun with design. The shift rod itself runs inside the steering part and out the back and to the trans. I have to stop looking at Steampunk sites!!!!!!!
DWP
flashho
flashho is offline
PostPosted: Tue Apr 28, 2015 12:29 pm    Post subject: Reply with quote
Hell yes! For steampunk. Smile
rant _ classified ads with out pics are almost worthless
B Ramsey
B Ramsey is offline
PostPosted: Tue Apr 28, 2015 1:54 pm    Post subject: Reply with quote
whack the shift lever off and weld whatever you want that fits.
mtnroads
mtnroads is offline
PostPosted: Sun May 03, 2015 11:58 am    Post subject: Reply with quote
You can always get a bus shifter bend and cut as necessary. I've seen it done in rat rods.
pax
No Good Deed Goes Unpunished....
