glutamodo  The Android
Joined: July 13, 2004 Posts: 26494 Location: Douglas, WY
Posted: Tue Apr 09, 2013 6:54 pm Post subject: |
How do you adjust it? You turn the peg the spring attaches to. VW/Bosch had a special tool that fit on it to help turn it.
So you're sure it's 07024 canister then? It will move 5.5mm total?
-Andy |
badufay Samba Member
Joined: December 13, 2010 Posts: 376 Location: Olympia, WA
Posted: Tue Apr 09, 2013 8:46 pm Post subject: |
Ok, I see how to make that adjustment now...looking at things again, I can't say for certain that my can is stock for a 205T, the spring knob is set all the way back so any adjustment would be in the wrong direction. Just messing around, I did pull the weight spring out of an old centrifuge 009 distributor and hooked that up in place of my return spring. The 009 spring is a bit shorter but a lot weaker. I get a full 32' of advance now after I static time to 0, but all 32' is in by about 2000 rpm... So now I've managed to ruin all my stock springs trying to shorten them, am uncertain about my can, and am running not so great setup right now. I think once I get a new stock spring, I'm going to install my NOS 07017 can and run it as a 205K, after all it is with a 30-1 (105-1) ....or find me a (certain) 07024 can, and new spring _________________ Current: 2023 ID.4 Pro S, 2020 Golf TSi 1.4L, 2017 GTI S, 6 spd man, 76 Bus, 2.0L- 3 spd auto
Previous: 2015 Golf S TDI, 6 spd man; 2015 Jetta SE TDI, 6 spd man; 12 Jetta 2.5L, 04 Jetta 2.0L, 02 Golf 2.0L, 98 Jetta 2.0L, 98 Golf 2.0L, 98 Cabrio 2.0L, 95 Golf 2.0L, 87 golf GTI 16 valve 1.8L, 86 Cabriolet 1.6L, 80 Audi 4000 1.6L, 76 Audi Fox 1.6L, 76 VW Beetle 1.6L, 74 Audi Fox 1.5L, 69 VW Beetle 1.5L |
tasb  The Distributor Distributor
Joined: April 27, 2002 Posts: 6664 Location: Pentwater, Michigan
Posted: Wed Jul 10, 2013 9:37 am Post subject: |
I tested 25 loose 36 hp beetle vacuum cans yesterday on my Sun Distributor Machine. Only 8 of the 25 cans were bad. That is a success rate of 64%. The cans ranged in age from 54 years old to 60 years old. The 60 year old one still works fine by the way... check those sticky points plates folks. _________________ Roads Scholar
Member# 2059 |
Posted: Tue Apr 22, 2014 11:43 pm Post subject: |
Here are a couple of oddball vacuum canisters that need to be included in this thread. The first is used with the 1959 Ghia only from August 1959 until January 1960.
I am in need of one of these vacuum cans if any one has one- this one is no good.
Next is the early vacuum canister used on the VJU 4 BR2 from December 1953 until January 1954, less than 8 weeks. The same vacuum canister was then used from January 1954 until August 1954 on the VJU 4 BR 3. Finally it's use continued into early VJU 4 BR 8 production.
These very early vacuum canisters can be distinguished by the vacuum line fitting being raised away from the canister housing slightly. _________________ Roads Scholar
Member# 2059 |
wcfvw69 Samba Purist
Posted: Wed Jun 04, 2014 2:31 pm Post subject: |
Can someone identify what this can is for? The arm moves 4.75mm and the Germany is up side down from the nipple. _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Wed Jun 04, 2014 4:55 pm Post subject: |
Based upon the shape of the canister and the two mounting holes on one side and only one on the other I would guess 40 hp big cap canister. They were used from 1960 until 1964. They are the most common NOS vacuum canister. I would hesitate to say plentiful though. _________________ Roads Scholar
Member# 2059 |
Posted: Wed Jun 04, 2014 6:51 pm Post subject: |
tasb wrote: |
Based upon the shape of the canister and the two mounting holes on one side and only one on the other I would guess 40 hp big cap canister. They were used from 1960 until 1964. They are the most common NOS vacuum canister. I would hesitate to say plentiful though. |
Thank you sir. I figured it was the 07015 can but wanted to double verify it. I have three of these, 2 nos and 1 good used one I bought sometime in the past. Of course, I don't have any use for them but do need the cans for the 67 and 69 stock distributors..
Funny you say "so plentiful".. There's several of these in the classifieds and none for the years I need. _________________ Contact me at [email protected]
Posted: Wed Jun 04, 2014 8:44 pm Post subject: |
Vacuum cans rarely fail. I have restored more than 300 vacuum advance distributors of this vintage. I have less than a dozen bad cans in all that time. Look for a good used one. If your at a swap carry a small length of vacuum line for testing. It's best to test the vacuum canisters that are removed from the distributor.
You would be looking for a vacuum canister off of a 113 905 205 K or a 131 905 205. There is a star pattern on the backside of these canisters similar to the ones above. _________________ Roads Scholar
Member# 2059 |
Posted: Wed Jun 04, 2014 9:11 pm Post subject: |
Vac-only canisters don't fail that often. However the DVDA units fail on the retard side all the time!!!
He'll need the 07017 for the 66-67 but the 07024 for the 69 unit. Which I'm sure he knows, as he's obviously read this thread through.
re: star pattern was on the 66-67 07017 cans, replacement ones, like I posted a photo of a few pages ago, don't have it.
https://www.thesamba.com/vw/gallery/pix/576676.jpg
Now, has anyone ever ordered what RockAuto sells for that one?
http://www.rockauto.com/catalog/x,carcode,1351808,parttype,7232
I don't seem to see them carrying one for the 07024 though.
-Andy |
richardhaus Samba Member
Joined: September 11, 2012 Posts: 9 Location: arlington, va
Posted: Sun May 03, 2015 5:24 am Post subject: |
When rebuild, what and where are you purchasing the diagram material? |
Posted: Mon May 04, 2015 6:33 pm Post subject: |
I do not know of anyone who is rebuilding the Bosch vacuum canisters successfully esp not to any quantity. _________________ Roads Scholar
Member# 2059 |
Frank Bassman Samba Member
Posted: Fri May 22, 2015 8:35 pm Post subject: |
Well, I see that this thread has a lot of useful information. But I have one question. What kind of sealant is used on the diaphragms to seal them up after they have been taken apart from their cans? I'm trying to fix mine, and all it needs is to seal well, but I'm wondering what the best, longest lasting sealant I can use on this is.
Thanks! |
Posted: Sun May 24, 2015 7:12 am Post subject: |
I don't believe any sealant was used. The earliest canisters used a paper diaphragm - until about 1970 and then rubber was used. _________________ Roads Scholar
Member# 2059 |
Warren Samba Member
Joined: January 28, 2004 Posts: 121 Location: Pine Valley, CA
Posted: Sun Dec 27, 2015 4:25 pm Post subject: Re: Vacuum Can Discussion Thread |
Super great thread!
My new-to-me '67 had the OEM 205 K with the proper can but it was leaking.
I found a beautifully rebuilt 205 K on eBay with the can and then read about it on then this thread and realized it has the 68+ can with too much advance.
So, I have a 5 cans on the way (star pattern for 66-67) to clean up and find a proper functioning one and in the meantime have timed my Beetle at TDC static.
She runs very well like this but I want to get it all correct.
The good news is that I've bought so many distributors and cans I think I may have 2-3 extra in great shape so I'll have a backup and a few to sell to help get others' 66/67's correct!  _________________ Warren in San Diego
1967 Beetle Sunroof Sedan |
Warren Samba Member
Posted: Mon Dec 28, 2015 11:24 am Post subject: Re: Vacuum Can Discussion Thread |
Just had to mention - Drove the little bugger to work today - She sure runs well on the 68-70 cannister set at TDC static.
Good response, idle, acceleration and no pinging.
I wonder if it matters much between the 66/67 and 68/70 can on the 205 K if you time it properly?
I am still going to get mine correct but what do you all think? _________________ Warren in San Diego
Posted: Mon Dec 28, 2015 1:03 pm Post subject: Re: Vacuum Can Discussion Thread |
Warren wrote: |
I am still going to get mine correct but what do you all think? |
It's perfectly fine. Back in the day, when the original "star" 7.5 BTDC can blew out, you'd of replaced it with that 0 timing can you have now. The most important thing is to time it to the vacuum can, not the distributor. In many years on this site, I've never seen an NOS 67 distributor "star" vacuum can for sale. You can still find the 205T distributor vacuum cans NOS though they are getting pricy.
I wonder how many VW's out there are not running as well as they should due to someone reading the distributor number and setting the timing to it vs. the vacuum can that is mounted on it.
You can also measure the travel of the vacuum can arm to verify which can it is if it doesn't have the "star" pattern on the vacuum can. I did to compare the "star" 67 distributor can vs. the 1969 205 T vacuum can set at 0. There was a difference that this thread highlights. _________________ Contact me at [email protected]
Posted: Mon Dec 28, 2015 4:10 pm Post subject: Re: Vacuum Can Discussion Thread |
I've seen them come up for sale before... I bought the one I showed earlier in this thread (which I've not yet needed to use) off of eBay several years ago. Replacement ones like the one I got don't have the star stamping on it though. |
Posted: Mon Dec 28, 2015 8:09 pm Post subject: Re: Vacuum Can Discussion Thread |
And to muddy the waters, the star pattern also appears on the 40 hp vacuum canisters. You can instantly tell them from the later 113 K vacuum canisters because the 40 hp big cap canisters have three mounting locations where the later have only two.
The correct canisters were still available back in the day at the dealership (as above without the star pattern). The customer or the service technician needed to know the difference though and often they did not.
I would say 1 out of 20 distributor cores that I receive have the incorrect vacuum canister installed. _________________ Roads Scholar
Member# 2059 |
Posted: Mon Dec 28, 2015 8:19 pm Post subject: Re: Vacuum Can Discussion Thread |
glutamodo wrote: |
I've seen them come up for sale before... I bought the one I showed earlier in this thread (which I've not yet needed to use) off of eBay several years ago. |
Wow.. You're lucky to have found that 7.5BTDC NOS vacuum can! I guess I need to look a bit harder. TASB says the vast majority of these vacuum cans on these vacuum only distributors are still good on the distributors he has rebuilt. The "star" 67 vacuum can on my 67 bug is original and has no issues. I bought several used 205 "T" vacuum cans with some core distributors. All of these used "T" vacuum cans failed to hold vacuum! So, I have no spare "T" cans right now.
I did get lucky and bought several used distributors a guy was selling for $4 bucks each at the last VW swap meet I went to. I found a 205M distributor with the "star" vacuum can. It looked filthy on the outside. When I took it apart, I was shocked how clean it was inside and it showed very little wear. The fiber washers were perfect as well. I cleaned and lubed the internals. It cleaned up beautifully and the can was dent free and holds vacuum. By far, my best swap meet find I've scored. It's now my back up distributor for my 67 bug. _________________ Contact me at [email protected]
Warren Samba Member
Posted: Mon Dec 28, 2015 8:44 pm Post subject: Re: Vacuum Can Discussion Thread |
Well out of the 5 I received today only one is close to being okay to use...
They are all stiff and sticky.
6-7 bad out of 8.
