85 Vanagon, Overheating and the infamous White Smoke
eikkaj
eikkaj is offline
PostPosted: Wed May 06, 2015 6:41 am    Post subject: 85 Vanagon, Overheating and the infamous White Smoke Reply with quote
My dearest van had been running seemingly fine, I checked fluids about a week ago and took her around the block yesterday until I noticed the temperature gauge flashing and seconds later a cloud of white smoke coming from the engine. I pulled over and immediately saw no coolant, filled it, waited awhile, got her back to her home.
Couple hours later I started her and let her idle for about 20 minutes until the temperature gauge just peaked and the light came on so I shut her off for the night. I couldn't hear the radiator fan come on, so I'm thinking this may be a combination of things. My biggest worry though is that the HG could be blown. From what I've read, this is likely, right? Sigh..
newfisher
newfisher is offline
PostPosted: Wed May 06, 2015 6:59 am    Post subject: Reply with quote
Welcome.
Sounds like you are on the right path. Change the fuel lines while your in there Wink
You can also jump the wires at the coolant fan switch up front and verify the fan or the switch inop.
atomatom
atomatom is offline
PostPosted: Wed May 06, 2015 8:11 am    Post subject: Reply with quote
it sounds like you may have a coolant hose leak. the clouds of smoke are actually steam, probably coolant splashing on hot exhaust. don't you see any puddles underneath?
the temp gauge shooting up very quickly and blinking means low coolant. given it happens after the van warms up, the leak is likely past the thermostat (where the waterpump is/left side of engine) and on one of the big hoses that lead to the front of the van.
84 Vanagon Westy, 1.9L, California raised but defected to Canada.
eikkaj
eikkaj is offline
PostPosted: Wed May 06, 2015 8:16 am    Post subject: Reply with quote
I really haven't noticed any puddles. I'm going to check again today. Thanks for the advice though, I am going to try to see if I can find a leak. I'm really just hoping nothing major was wrecked as a result of it overheating
atomatom
atomatom is offline
PostPosted: Wed May 06, 2015 8:47 am    Post subject: Reply with quote
if you had said 'pulled over immediately' instead of 'pulled over and immediately' it would have been better. Smile
was the white smoke (aka coolant steam) coming from the exhaust, or just the back of the van? some leaks will dump right on to hot exhaust, leaving no puddles since they turn into steam.
eikkaj
eikkaj is offline
PostPosted: Wed May 06, 2015 8:56 am    Post subject: Reply with quote
Haha good point
and it was coming out of the back of the van as far as I could see
eikkaj
eikkaj is offline
PostPosted: Wed May 06, 2015 10:24 am    Post subject: Reply with quote
The coolant reservoir is still full from last night and no liquid has leaked from underneath at all!
Ahwahnee
Ahwahnee is offline
PostPosted: Wed May 06, 2015 5:32 pm    Post subject: Reply with quote
eikkaj wrote:
The coolant reservoir is still full...
There are two reservoirs back there. By far the more important is the one on the left which should be completely full.
If the left one is low - top it up and keep an eye on it. If it is repeatedly low after a drive then further investigation is called for.
Bassyaks
Bassyaks is offline
PostPosted: Wed May 06, 2015 6:19 pm    Post subject: Reply with quote
A head gasket leaks externally, O-rings leak internally, and a cracked head leaks into the combustion chamber. white smoke means antifreeze in the combustion chamber, pull the spark plugs and your problem cylinder will be evident.
morymob
morymob is offline
PostPosted: Thu May 07, 2015 4:54 am    Post subject: Reply with quote
Coolant getting onto hot exs sys will do the cloud thing too. I f no leaks when u test after it'sfully warmed up i would change thst and rad fan kicking in , can be checked by letting idle too.
eikkaj
eikkaj is offline
PostPosted: Thu May 07, 2015 4:09 pm    Post subject: Reply with quote
Filled the pressure tank up and let it idle for about 20 minutes. Noticed a small leak and at around 20 minutes coolant started pouring. Guess I found my leak Smile
Ahwahnee
Ahwahnee is offline
PostPosted: Thu May 07, 2015 4:37 pm    Post subject: Reply with quote
So is it a leak in that tank?
If so, you are a lucky dude - that is a cheap and easy fix.
eikkaj
eikkaj is offline
PostPosted: Thu May 07, 2015 4:41 pm    Post subject: Reply with quote
As far as I could tell, yeah. It's leaking from under the tank so I guess it could be the hose. I had to run so I couldnt see exactly where under there. I'll look again tomorrow more easily while its cool.
eikkaj
eikkaj is offline
PostPosted: Thu May 07, 2015 4:45 pm    Post subject: Reply with quote
I took off the bottom grill while I was waiting and couldnt hear the fan though so there may be issues on that side as well...
IdahoDoug
IdahoDoug is offline
PostPosted: Thu May 07, 2015 4:49 pm    Post subject: Reply with quote
Fan may be unrelated. Fix the leak first. Careful not to get burned by the steam - can be shockingly hot if you're not expecting it. Most likely scenario involving that tank is the sensor on top of it failing and letting water dribble out onto the exhaust below. Use eye protection as that sensor could be cracked and fully come apart.
DougM
eikkaj
eikkaj is offline
PostPosted: Sat May 09, 2015 10:58 am    Post subject: Reply with quote
Upon further inspection it looks like coolant could at least be coming from the cap, which I should have thought to replace right away anyway. I also noticed that no coolant from the overflow tank seems to be getting pulled into the expansion tank. Water pump?
IdahoDoug
PostPosted: Sat May 09, 2015 11:01 am    Post subject: Reply with quote
If its coming out the pressure cap because the seal is bad, that same bad seal means it won't draw from the overflow tank to refill itself when cooling after shut down. So, cap for sure. Just don't overlook the sensor issue. Tough to know which (cap/sensor) is the source unless you are looking at it while the engine is hot and the leak is happening. They'll both fill the sensor area, and they'll both drip off the sides of the tank. But start with the cap.
61Scout
61Scout is offline
PostPosted: Sat May 09, 2015 11:18 am    Post subject: Reply with quote
Purchase a good quality German cap from one of the specialty vendors. VC will send you a cookie too. No, you won't find it at your FLAPS or on Amazon or Ebay last I looked. I found out the hard way on this one, and have some "new" yet non-functional caps around. Save yourself the time, money and aggravation. Also I personally avoid any URO parts... just complete junk, imo.
-Kevin
1986 Westfalia Weekender Wolfsburg, RJE 2.3
1985 Tin Top, Subie 2.2 + 5MT
Floppy Mirrors no more: http://www.thesamba.com/vw/forum/viewtopic.php?t=653018&highlight=
Remove the front spindle nut with ease: https://www.thesamba.com/vw/forum/viewtopic.php?t=679567&highlight=
Remove the rear wheel bearing housing without messing with the big 46mm nut: https://www.thesamba.com/vw/forum/viewtopic.php?t=679507&highlight=
-Nec Spe, Nec Metu
eikkaj
eikkaj is offline
PostPosted: Mon May 11, 2015 6:50 am    Post subject: Reply with quote
I really enjoy the cookies VC sends Smile
I actually took the expansion tank OUT and saw that the seam has about a 1-inch long split in it. I'm buying a new tank, caps and sensor today.
xflyer
xflyer is offline
PostPosted: Mon May 11, 2015 8:10 am    Post subject: Reply with quote
eikkaj, Do you know how to bleed air out of cooling system? This is very important.
Best way I've found: Raise rear of Vanagon on ramps or in steep driveway with front wheels in gutter. Open heat controls on dash and rear underseat heater to Hot (red mark on dash). Engine should be cool or barely warm. If hot do something for 45 min.
Fill expansion tank (where blue cap screws on) about 2/3s full. Run engine at idle for about a minute. With engine off fill tank again if nec.
Remove front grille. Unscrew radiator bleed screw at top of rad near right headlight. Air will come out, reinstall screw when coolant comes out.
Fill expansion tank again. Run engine again for about a minute and shut off. This may seem complicated, but it is quicker and more effective than the procedure in the shop manual ("Bentley book").
Top of exp tank again if nec. Screw on blue cap and attach hose from recovery tank. Fill recovery tank (the one behind the license plate) to "full" mark.
Run engine, check for leaks and proper operation of electric fan on radiator. Check recovery tank level over the next week or so every day.
BTW coolant will only transfer from recovery tank into the system if the cooling system is properly sealed. If there are any leaks, such as the crack in your expansion tank, air will go in first.
The expansion tanks are a "maintainence" item. Quality has gone down since OEM tanks stopped being made. I keep one in the garage and regularly check the tank for cracks. Common crack locations are around where the cap screws on and between cap and level sensor.
Also level sensors can break and let coolant out/depressurize system.
I carry a spare in the van along with a socket that fits.
1989 Campmobile, 1984 7 passenger beater Vanagon
Both with cool A/C
