1972 battery ground cable strap connection location
Page: 1, 2, 3  Next
aeromech
aeromech is offline
PostPosted: Thu May 07, 2015 8:29 pm    Post subject: 1972 battery ground cable strap connection location Reply with quote
Guys, I swear... I can't figure out where the battery ground strap attaches to the frame on this bus. It appears to not be the same as a 1971 and not the same as a 1976. So was 1972 some special location?
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Ian
Ian is offline
PostPosted: Thu May 07, 2015 9:11 pm    Post subject: Reply with quote
All the ones I've seen have it going to the engine block. 72 is a weird year.
All your Buses are belong to us.
Love and good roads!
IN LOVING MEMORY OF ROB CRESS 1968-2012 & KEN CRIMMINS 1957-2024
busdaddy
busdaddy is offline
PostPosted: Thu May 07, 2015 9:35 pm    Post subject: Reply with quote
72 bolts to the wheel well just below where the ECU would go if it had FI.
I think I can almost see the hole just below the kink in the bodyline in this pic:
If that single dangly wire swung to the right a few inches it'd be over it.
Слава Україні!
Ian
Ian is offline
PostPosted: Thu May 07, 2015 10:26 pm    Post subject: Reply with quote
No, it doesn't. Maybe late 72 ie. 73 model year.
aeromech
aeromech is offline
PostPosted: Fri May 08, 2015 6:03 am    Post subject: Reply with quote
Mark, I can't believe this. I think Ian is right. I know the hole you're thinking about and this bus doesn't have it. I'd sure like to see an original picture of how VW did it.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Ian
Ian is offline
PostPosted: Fri May 08, 2015 8:57 am    Post subject: Reply with quote
Not many all original 1972 Buses out there anymore.
aeromech
aeromech is offline
PostPosted: Fri May 08, 2015 9:01 am    Post subject: Reply with quote
Ian, I can't tell shit from that picture. Can you?
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Ian
Ian is offline
PostPosted: Fri May 08, 2015 9:04 am    Post subject: Reply with quote
Nope! That's all we get this many years later for "perfect original example"
aeromech
aeromech is offline
PostPosted: Fri May 08, 2015 9:05 am    Post subject: Reply with quote
I just cannot accept that VW grounded the battery to the engine like that. It just looks too bush league.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
sjbartnik
sjbartnik is offline
PostPosted: Fri May 08, 2015 9:37 am    Post subject: Reply with quote
They did it in the Karmann Ghia so, you never know:
Xevin
Xevin is offline
PostPosted: Fri May 08, 2015 10:05 am    Post subject: Reply with quote
Gary, my 72 ground is attached to the block like Ian's picture. But I have a mystery cable with a battery terminal clamp on one end and the other is bolted to the battery tray near the side marker. Always thought that was the orginal ground. I don't use it because the tray is cRusty. Thought the PO added the current strap.
Keep on Busin'
67rustavenger wrote:
Clatter wrote:
skills@eurocarsplus wrote:
SGKent wrote:
aeromech
aeromech is offline
PostPosted: Fri May 08, 2015 10:26 am    Post subject: Reply with quote
Well, I think I'm just gunna fabricate some kind of ground location. I have a rivnut puller. Maybe I'll install a rivnut somewhere solid like VW did with the later buses. They come in large sizes like 8mm
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Xevin
Xevin is offline
PostPosted: Fri May 08, 2015 10:30 am    Post subject: Reply with quote
I've seen people to something like that near the right side of the cover plate in your photo.
Keep on Busin'
SGKent wrote:
Xevin
Xevin is offline
PostPosted: Fri May 08, 2015 10:32 am    Post subject: Reply with quote
"AWOL" Stuart suggested that to me as well.
Keep on Busin'
SGKent wrote:
Tcash
Tcash is offline
PostPosted: Fri May 08, 2015 11:10 am    Post subject: 72 ground cable strap Reply with quote
Both diagrams depict the battery being installed with the Neg terminal toward the rear of the vehicle.
http://www.thesamba.com/vw/archives/info/wiring/bus_8_71_1700.jpg
http://www.thesamba.com/vw/archives/info/wiring/bus_8_71.jpg
Thanks to mayor ratwell. "09/28/04 Early battery negative was bolted to hole in battery tray. Yuck."
72 bus in original condition
ratwell wrote:
68-72 bolted this way. 73-79 bolted above the battery in the front.
72 ground strap
72 trans strap
aeromech
aeromech is offline
PostPosted: Fri May 08, 2015 11:13 am    Post subject: Reply with quote
Thanks Tim
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Wildthings
Wildthings is offline
PostPosted: Sat May 09, 2015 4:26 am    Post subject: Reply with quote
Grounding to the engine is a much better set up in my opinion. With it grounded to the engine you will not get starter current running through the clutch cable even if the ground strap is missing. The reason VW grounded it to the body was to save a few pennies, not because it was a better way to do things.
aeromech
aeromech is offline
PostPosted: Sat May 09, 2015 5:27 am    Post subject: Reply with quote
WT,
Respectfully I need to disagree. By installing the "battery return" ground strap to the engine, you'd be sending ALL the electrical loads through the transmission strap, the engine, and fan case. The clutch would flow as well as soon as it became the path of least resistance to the battery. Things like stereos, wipers, headlights, etc would all need to flow through the engine. A much better path for those is through the frame.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Lil Lulu
Lil Lulu is offline
PostPosted: Sat May 09, 2015 6:01 am    Post subject: Reply with quote
My second 72 and they were both grounded like this:
'65 Beetle "Lil' Lulu"- Ruby Red
1600 stock from '71 bus
'72 Deluxe - Niagara Blue w/pastelwiess Camper Special 2L dual 40 Webers 002
'74 Hightop Weekender "Dixie" 1800 34 Del singles
Wildthings
PostPosted: Sat May 09, 2015 9:08 am    Post subject: Reply with quote
aeromech wrote:
WT,
Per the original system all the loads you mention are already flowing through the tranny ground strap when the alternator is charging as the strap is the return path to the alternator. If they also flow through the ground strap at those times the engine is off or the alternator is not putting out sufficient amps then such a load is minimal compared to the starting load.
With the engine running and the alternator putting out a large amount of extra amps to charge the battery then the load on the tranny ground strap will be less than as per the original system and not more.
Page: 1, 2, 3  Next
