joe matlack Samba Member
Joined: August 24, 2009 Posts: 1 Location: REHOBOTH BEACH DELAWARE
Posted: Wed Aug 26, 2009 3:01 pm Post subject: Adjusting the steering box |
| anyone have any pointers or experience in adjusting the steering box on a 66 bus? I seem to have some free play coming from this thing. |
Campy Samba Member
Joined: January 10, 2005 Posts: 4933 Location: Chico, CA
Posted: Wed Aug 26, 2009 6:02 pm Post subject: |
If the play on the outer rim of the steering wheel is more than one inch, and the tie rod ends are alright, adjust the steering box:
1) Put the front of the bus on jackstands;
2) Have the steering wheel in the straight ahead position;
3) Loosen the large locknut on the backlash adjustment on the left side of the steering box;
4) Tighten the adjustment until the steering is stiff; back off the adjustment until a slight drag is felt near the mid position. Hold this setting and tighten the locknut.
This is in Clymer's VW Transporter manual. _________________ Don't worry; be happy. (Baba) |
lucareda Samba Member
Posted: Tue Jun 09, 2015 10:59 am Post subject: |
| Campy wrote: |
This is in Clymer's VW Transporter manual. |
This is the only procedure I can find on steering box adjustment. Can anyone confirm this is the correct procedure? |
glideking Samba Member
Joined: February 02, 2013 Posts: 990 Location: California
BarryL  Samba Member
Joined: November 01, 2004 Posts: 15473 Location: Casa de Oro, California
Posted: Tue Jun 09, 2015 11:32 am Post subject: |
| I would never want a "slight drag" in the mid point unless Clymer was assuming the locking nut pulled back on the adjuster just enough while taking up its threads to cause a perfect freeness. When done there should be zero drag mid-position. |
bubba Samba Member
Posted: Tue Jun 09, 2015 11:36 am Post subject: |
Check all you tie rod ends be for messing with the box.. 90% of the time it is wore out tie rod ends.. Do not by the crap Brazilian ones... spend the money on German one. _________________ ***WANTED***
SO-23 Cargo net hooks...
for sale
curtain Bungee cords for SO23, 22, 33 ,34 ,35
http://www.thesamba.com/vw/classifieds/detail.php?id=1587591 |
otis_bartleh Samba Member
Joined: August 19, 2009 Posts: 1153 Location: Burlington, WA
Posted: Tue Jun 09, 2015 11:40 am Post subject: |
| bubba wrote: |
| wore out tie rod ends.. Do not by the crap Brazilian ones... spend the money on German one. |
X2... _________________ -Adam
'59 Mango Bus
'69 Bug - Cobalt Blue |
| Everything else is fine. This is the only thing left. It's a rebuilt box that I made the mistake of trying to adjust before I knew anything last year. Everything else has been replaced or is OK. |
EverettB  Administrator
Joined: April 11, 2000 Posts: 71927 Location: Phoenix 602
