64slow Samba Member
Posted: Sat Jun 13, 2015 9:20 pm Post subject: Running on 2 cylinders? Need troubleshooting help |
Hello All,
I'm in the middle of a road trip to Yellowstone National Park in my '64 SO35 camper. I'm having some engine troubles, I need to bounce some ideas off someone to help me troubleshoot.
Engine was just swapped out 2 weeks ago with a rebuilt 1600. Was running smooth this morning, all through Colorado. About Rawlins Wyoming, I started noticing a loss of power. Started off adjusting the timing (009 distributor) and carburetor (34PICT-3). Shut off the motor on the side of the road and got everything back to baseline (7.5 BTDC, and carb adjusted to baseline) Did all that, kept struggling. It got worse after awhile. In hindsight, I may have been on 3 cylinders, then dropped to 2.
Here's what I need advice on: At one point, I started pulling spark plug wires from the distributor. When I disconnected the spark plug wires that go to the cylinders on the right hand side, motor didn't miss a beat. No difference in what the motor sounded like with the wires connected, vs. disconnected. I did the same thing with the cylinders on the left side, and the motor stumbled until I reconnected them.
I pulled the spark plugs out of the 2 right hand side cylinders (one at a time), and ran the motor. Grounded the spark plug to the engine case, and I'm getting spark at the plugs. I did not have a compression tester with me, so I need to get that piece of information as well.
The motor runs, but I don't have hardly any power. I stumbled into Riverton WY, and I'll be troubleshooting tomorrow.
Based on the fact that pulling the spark plug wires doesn't make a difference in how the motor runs, I suspect I'm running on 2 cylinders.
Please confirm my line of troubleshooting is correct.
Here's my plan for tomorrow:
Compression test on all 4 cylinders.
Valves
check and compare spark at all 4 plugs
Check coil?
Any suggestions are welcomed, thanks!
Mike A. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 53120 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sat Jun 13, 2015 9:51 pm Post subject: |
A valve adjustment would be high on my list, a ghetto compression test is disconnect the coil wire and crank the engine while listening, rrrr...rrrr...rrrr...rrrr....?, or rrrr...rRRr...rrrr...RR...?, if the sound changes between each RRR or one seems shorter and faster than the rest you have a soft cylinder. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
G-wood Todd Samba Member
Joined: January 11, 2005 Posts: 1047 Location: Colorado
Posted: Sun Jun 14, 2015 8:48 am Post subject: |
It sounds like you are on the right track. As mentioned above, a valve adjust is a must before a commpression test. Would also check the condition of distributor cap, rotor and point gap to ensure a good and consistant spark. Good luck and keep us posted. _________________ and take the kids for instance "Are we going in the Volkswagen bus?" and they say "Yay!" and clap their hands and if it's a glorious day you can slide the sunroof back and let a little of the glory in and all of a sudden, it stops looking funny.
-Volkswagen ad |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 26188 Location: Olympia Wash Rinse & Repeat
Posted: Sun Jun 14, 2015 10:46 am Post subject: |
Not real likely, but your rocker arm could have pulled loose a stud.... _________________ In Stereo, Where Available! |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7124 Location: Lawrenceville, Ga
Posted: Sun Jun 14, 2015 11:09 am Post subject: |
| busdaddy wrote: |
| A valve adjustment would be high on my list, a ghetto compression test is disconnect the coil wire and crank the engine while listening, rrrr...rrrr...rrrr...rrrr....?, or rrrr...rRRr...rrrr...RR...?, if the sound changes between each RRR or one seems shorter and faster than the rest you have a soft cylinder. |
when you are troubleshooting, do the easy things first... checking and adjusting your valves is easy and quick. you can also visually inspect the rockers while you are in there. do that first _________________ regards
Uli
64 ragtop volks Samba Member
Posted: Sun Jun 14, 2015 12:01 pm Post subject: |
| i would inspect the points and inside of dist cap. then the spark plug wires and plugs. hopefully its just something simple, mabey try swapping the coil. mechinical problems will usally have strange engine noises that go with them. |
flemcadiddlehopper Samba Member
Joined: December 05, 2011 Posts: 2345 Location: Kelowna, BC. Canada.
Posted: Sun Jun 14, 2015 7:19 pm Post subject: |
I agree with above. Start by checking the simplest things, like points gap.
My guess would be poor high tension wires, especially if it the passenger side that has lost power, the wires leak where they pass under the generator/alternator. If you spray them down with soapy water while running and watch for spark jumping from the wires to ground.
Good luck with it and let us know how things turn out.
Gordo. _________________ Everybody Dies....Some Never Live.
Retrograde Garage. Vintage Aircooled, and others. |
BarryL  Samba Member
Joined: November 01, 2004 Posts: 15406 Location: Casa de Oro, California
Posted: Mon Jun 15, 2015 10:11 am Post subject: |
| If it's a dual port check to see that all the boot clamps are tight. |
KevinAlbrecht Samba Member
Joined: March 07, 2002 Posts: 996 Location: Ocean City > Boca > Pompano > Kirkland > Eugene > Sarasota > Babcock Ranch
Posted: Mon Jun 15, 2015 2:50 pm Post subject: |
Check the plugs. That should help you diagnose what is going on with each cylinder. covered with gas would indicate it is not firing. Oily? something else is going on. Charred with carbon, too rich. When I traveled at elevation I had to swap jetting.
I had a BIG power drop as compared to sea level. _________________ Kevin Albrecht
1963 Panel
Don't forget those seat-belts!
Click to view image |
