1965 just cranks and cranks when hot. Won't fire up
Page: Previous  1, 2
DeVertible
DeVertible is offline
PostPosted: Fri May 22, 2015 8:42 am    Post subject: Reply with quote
Sorry about the multi pixs. My hand must have stuttered does have correct lid. 1987 restoration of an original Lake Tahoe based vehicle. I have adjusted valves at .006. The charging system does seem suspect as I drive last night's with lights on and I get a faint gen light. Got trickle on the battery while away. Will re visit issue Monday
Johnous
Johnous is offline
PostPosted: Fri May 22, 2015 3:04 pm    Post subject: Reply with quote
https://www.youtube.com/watch?v=eU6aVBW71Es
FYI
DeVertible
PostPosted: Fri May 22, 2015 9:06 pm    Post subject: Reply with quote
Very interesting. . . Wow. Thanks, another possibility.
DeVertible
PostPosted: Fri May 22, 2015 9:08 pm    Post subject: Reply with quote
DeVertible
PostPosted: Mon May 25, 2015 5:24 pm    Post subject: Reply with quote
Update; It is not the condenser, nor the fuel pump rod binding. I replaced the condenser and checked the actuator rod for freedom. Replaced coil with a used one and replaced the regulator with a new one which did solve the dim idiot light issue so that's good. I do not think it is vapor lock either, as it will not start with starting fluid or added gas to carburetor. I am coming to the conclusion it is simply a flooding problem. It will start using the standard 'open full throttle' to let things dry out and vaporize after sitting for thirty minutes or so. wish they made a 6 volt idle shut off. Has anyone tried to operate a 12 volt unit successfully on six volts? It just may be as good as it gets. Ever here the song; 12 Volt Man by Jimmy Buffet? I think that's me
Eric&Barb
Eric&Barb is online now
PostPosted: Mon May 25, 2015 5:46 pm    Post subject: Reply with quote
Idle shut off only helps to keep engine from running on after shutting down a hot engine. Will not stop flooding due to carb/fuel pump getting heated up.
In Stereo, Where Available!
mukluk
mukluk is offline
PostPosted: Mon May 25, 2015 8:29 pm    Post subject: Reply with quote
If you're really serious about operating a 12v shutoff solenoid in your 6v car, there are 6 to 12 volt power inverters available for purchase that'll do the job, just be warned that they aren't terribly cheap.
DeVertible
PostPosted: Wed May 27, 2015 6:09 pm    Post subject: Reply with quote
FYI. . . Installed 12 volt idle cutoff after testing on 6 volt battery successfully. It operated most of the time but would stop holding occasionally and the engine would quit. Pretty simple unit . A guy could make a living rewiring the coils
DeVertible
PostPosted: Sat Jul 18, 2015 7:26 am    Post subject: follow up to hard starting issue Reply with quote
Installed correct 1967 pict -1 carb, 6 volt idle cut off and correct 1966 67 vacuum advance dist. Starts first crank. Happy Guy
DeVertible
PostPosted: Sat Jul 18, 2015 7:27 am    Post subject: follow up to hard starting issue Reply with quote
Eric&Barb
PostPosted: Sat Jul 18, 2015 12:42 pm    Post subject: Reply with quote
Most excellent!! Thanks for updating us all.
Page: Previous  1, 2
Page 2 of 2
