Steering column support
prkid424
prkid424 is offline
PostPosted: Wed Jul 22, 2015 6:19 am    Post subject: Steering column support Reply with quote
does anyone know where I can get this or something similar?
Want to have some support of the column until i get a roll cage installed which will have a horizontal tube on the front hoop for the support.
Dale M.
Dale M. is offline
PostPosted: Wed Jul 22, 2015 6:48 am    Post subject: Reply with quote
Make one.... I used a exhaust pipe clamp and a short length of strap steel welded to clamp for a mounting tab....
Used idea form this picture I found somewhere on i-net...
Found this from Jegs...
And this...
And this Chevy Part...
This is not rocket science... And keep in mind nobody sees it except you....
Dale
prkid424
prkid424 is offline
PostPosted: Wed Jul 22, 2015 7:31 am    Post subject: Reply with quote
And this...
Dale
Of course exhaust clamps....so obvious but I didn't even "see it". Time to search the scrap pile for a bit of sheet metal for that tab. That pic from Jegs is also interesting. May fab some thing like that.
tgodber
tgodber is offline
PostPosted: Wed Jul 22, 2015 7:44 am    Post subject: Reply with quote
Thanks for all the very helpful posts you make Dale!
My wife said I never listen to her.
Or something like that!
prkid424
prkid424 is offline
PostPosted: Wed Jul 22, 2015 9:21 am    Post subject: Reply with quote
Ditto....my search queries through this forum usually include Dale. Much appreciate your contribution to the community.
BL3Manx
BL3Manx is offline
PostPosted: Wed Jul 22, 2015 10:43 am    Post subject: Reply with quote
The upper end of the column is what needs the support. This steel frame ties the windshield frame, hood/dash, and body into a more rigid unit and gives the steering column a solid mounting point right behind the dash
http://www.meyersmanx.com/mmstore/store-classicdashframe.shtml
It all works even better with these brackets which fit in the channel of the new windshield frames, increasing its mounting rigidity.
Dale M.
Dale M. is offline
PostPosted: Wed Jul 22, 2015 12:21 pm    Post subject: Reply with quote
Welded a plate to stiffener tube across body at upper end of column and you guessed it...Muffler clamp.
Dale
