Calicub Samba Member
Posted: Tue Jul 28, 2015 4:33 pm Post subject: FrankenVanagon? |
Hi All, I'm the proud new owner of an 82 air cooled westy. I'm running into some issues as it's missing many of the lower tins (under the pushrod tubes & by the heater boxes), thermostat & flap assemblies. In trying to figure out if it's a California or federal model, I'm running into conflicting info, I.E. The double relay has 11 pins, but the airflow sensor appears to be a CA part, the coil looks to be a CA part, but the fuel filter is a cube & not the bosch "can."
Any help or suggestions on how to definitively ID & source the correct tins will be immensely appreciated! _________________ 82 Westy |
geodude Samba Member
Posted: Tue Jul 28, 2015 4:40 pm Post subject: |
There should be a placard (oil filler door on mine) that says what emissions it originally had. Also look on the door jam as it might be there. _________________ 1988 GL Camper
1991 Multivan — the basket case |
BerneseMtnDog Samba Member
Posted: Tue Jul 28, 2015 4:47 pm Post subject: |
The California model will also have an idle stabilizer and ignition amplifier on the left side of the engine bay. I think a Cali model will also have an O2 sensor.
Steve |
rubbachicken Samba Member
the joker Samba Member
Posted: Tue Jul 28, 2015 6:52 pm Post subject: |
cali model had that NLA crossover exhaust and funky EGR stuff o2 sensor
you need all the tins and fix your thermo bellow flap system
chk the engine compartment seal |
shadetreetim Samba Member
Joined: January 10, 2011 Posts: 1994 Location: Riverside, California
Posted: Tue Jul 28, 2015 7:13 pm Post subject: Re: FrankenVanagon? |
| Calicub wrote: |
| The double relay has 11 pins, but the airflow sensor appears to be a CA part, the coil looks to be a CA part, but the fuel filter is a cube & not the bosch "can." |
After 33 years of who knows who touched it service, there is no telling what mash up of parts you will continue to find. I wouldn't look at the parts to decipher which model you have. As has been posted, add some pictures and the collective can help you figure it out.
Good luck with your new Vanagon. _________________ Tim Potts
Doing my best every time I drive it to dispel the myth these Vanagons have to be slow!
'89 Vanagon Bluestar/Country Homes 1.8T & .77 4th
'74 Jeep CJ5 |
Posted: Tue Jul 28, 2015 10:03 pm Post subject: |
Thanks all for the input, I'll get some photos up as soon as I can. Hopefully tomorrow. _________________ 82 Westy |
Posted: Wed Jul 29, 2015 8:54 pm Post subject: Thanks for the tips all! |
She's a federal! Engine bay sticker shows egr & door jam sticker calls out federal as well. _________________ 82 Westy |
