High-Lift, Highlift, High Lift, Hy Lift, Jack
Tcash
Tcash is offline
PostPosted: Fri Aug 14, 2015 10:10 am    Post subject: High-Lift, Highlift, High Lift, Hy Lift, Jack Reply with quote
High-Lift Jack
Vanagon High-Lift Jack Extension
High-Lift Jack and Recovery Kit
Tcash
Tcash is offline
PostPosted: Fri Aug 14, 2015 10:11 am    Post subject: Vanagon High-Lift Jack Extension Reply with quote
Why won't the Vanagon Extension work on a Bay?
Thank you
Tcash
Kirk
Kirk is offline
PostPosted: Fri Aug 14, 2015 11:25 am    Post subject: Reply with quote
I actually thought about adding one of these to my bus, on the roof rack, but its crazy heavy. So since your post shows what works for the vanagon, what do people do for the bay?
MAKE FORUMS GREAT AGAIN
Bear
Fasty
Super
babysnakes
babysnakes is offline
PostPosted: Fri Aug 14, 2015 1:37 pm    Post subject: Reply with quote
Kirk, the answer seems to be right there. The idea is simply brilliant. The steel rod needs to be modified or replaced with a section if thick wall square tube bent to conform to the Bay jack point. Could this be something Jeremyrockjock could ad to his wares?
Thanks Tcash.
Malokin Martin
Malokin Martin is offline
PostPosted: Fri Aug 14, 2015 2:29 pm    Post subject: Reply with quote
I wouldn't want to be the guy who welds these and then sells them to the general public with the idea of jacking the bus up a substantial distance in the air. All it would take is one crusty bus and one crushed hippy to ruin his day.
skills@eurocarsplus
Samba Peckerhead
PostPosted: Fri Aug 14, 2015 2:42 pm    Post subject: Reply with quote
forgot to put hi lift in title too
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
Kirk
Kirk is offline
PostPosted: Fri Aug 14, 2015 2:58 pm    Post subject: Reply with quote
Thanks Tcash.
BAsically what I was thinking too. And Ditto Jeremy. His roo bar mounts look like those things. I have his towbar and roo bar. If he built one I would buy one.
Bear
Fasty
Super
Brian
Brian is offline
PostPosted: Fri Aug 14, 2015 3:51 pm    Post subject: Reply with quote
They work without the adapter on the stock spot, but it's really tight and you'll scratch the shit out of your paint. The one from Gowesty should work, or a tube bumper Cool
Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter
TomWesty
TomWesty is offline
PostPosted: Fri Aug 14, 2015 4:20 pm    Post subject: Reply with quote
Great for plastic surgeons and dentists.......
aeromech
aeromech is offline
PostPosted: Fri Aug 14, 2015 4:52 pm    Post subject: Reply with quote
And to think that I gave away one of those jacks a few years ago
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
SGKent Premium Member
SGKent is offline
PostPosted: Fri Aug 14, 2015 8:15 pm    Post subject: Reply with quote
they are great for getting out of the mud or being high centered. They were not designed to be used a general purpose side jack on bus. They can also be used as a cheap comealong. Using it to change tires on a bus would be like using a 20 pound sledge hammer to drive nails.
George Carlin:
Skills@EuroCarsPlus:
Brian
Brian is offline
PostPosted: Fri Aug 14, 2015 8:23 pm    Post subject: Reply with quote
They weight a lot and take up a lot of space. But are excellent when you need them.
Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter
danfromsyr
danfromsyr is offline
PostPosted: Fri Aug 14, 2015 9:25 pm    Post subject: Reply with quote
I have a farm jack (hi-lift) for equipment and trailers
a tirfor (Grip hoist) manual winch for extraction
and a hydraulic jack for lifting purposes..
they are a cheap man's jeep jack.. and dangerous as all heck if you don't respect them like the town drunk with a 9 iron.
each has it's place. and no farm jack on my bus.
Abscate wrote:
babysnakes
PostPosted: Sat Aug 15, 2015 8:14 am    Post subject: Reply with quote
These jacks are not for everybody. They are great for off road situations where a stock jack would sink into the dirt. They can be very dangerous. We always carried 2 on our fulltrack swamp buggy, and I have seen them pop out, fly out and bend under the weight of the buggy. Also used them as a Come Along to install the tracks. I carry a floor jack while on the road, but would prefer a Hi Lift with an adapter for the jack point for off road.
Brian
Brian is offline
PostPosted: Sat Aug 15, 2015 8:25 am    Post subject: Reply with quote
Yea, sometimes when you're letting it down it 1/10 times it will completely let go and drop to the floor. If you don't get it straight, you risk leaning to one side or the other. Even on road, the base for it is helpful:
Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter
akscooter
akscooter is offline
PostPosted: Sat Aug 15, 2015 8:36 am    Post subject: Reply with quote
They call'em man killer jacks for a reason.
1975 campmobile
1949 Ply Special Deluxe
1991 Custom 1200 HD Sportster XLH
Tcash
Tcash is offline
PostPosted: Sat Aug 15, 2015 12:15 pm    Post subject: Reply with quote
The only time I have had trouble with them is if they are not lubricated and the pins get stuck.
If you get stuck you can jack up the rear and push the vehicle over from the side and get the tires out of the ruts. A bumper jack can be used as well, if you can find one.
Couple of High-Jacks and some Jack stands I imagine you could pull a Type IV motor on the side of the road. Amskeptic you game?
Good day
Tcash
Brian
Brian is offline
PostPosted: Sat Aug 15, 2015 12:25 pm    Post subject: Reply with quote
I need to see this done. Laughing
Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter
Tcash
Tcash is offline
PostPosted: Sat Aug 15, 2015 12:53 pm    Post subject: Reply with quote
I can picture it now. Amskeptic on the side of the road in the Mohave desert. Pulling the engine to change the clutch, all the while documenting it with his camera.
Laughing
Tcash
MadMax78
MadMax78 is offline
PostPosted: Sun Aug 16, 2015 8:43 am    Post subject: Reply with quote
I actually bought one of these for my bus and modified a Defender adapter to fit the bus jack points.
Jacked the bus up once and then sold the jack again. They are rather dangerous, especially if they are not on firm ground. Using the stock jacking points brings the jack way too close to the body, a little slip and you've got a huge dent in your bus, or in your head. They work a lot better on a Defender with jackmounts in the bumpers.
Besides that, they are impossibly heavy.
1978 T2b ASI Riviera Plan I // Camper Special with MegaSquirt Injection & Ignition // 091 with 5.14 R/P and Peloquins LSD
Powered by Just Kampers, German Supply , Busted Bus, Aircooled Technology & DIYAutoTune
2008: Amsterdam - Beijing - Olympics -- 17.500km
2010: Amsterdam - Cape Town - FIFA World Cup -- 26.000km
2014: New York - Rio de Janeiro - FIFA World Cup -- 27.000km
http://www.oranjetrophy.nl
Camper Special Club Member
