levi20AE Samba Member
Joined: June 24, 2005 Posts: 485 Location: Las Vegas, NV
Posted: Mon Aug 17, 2015 3:56 am Post subject: |
I have one and it has saved me twice now. The Go Westy adapter does not work since the vanagon jack point accepts a larger diameter tube. I found that out and ended up welding on a proper sized tube.
_________________ 1973 Campmobile http://www.thesamba.com/vw/forum/viewtopic.php?t=524511&postdays=0&postorder=asc&start=0
20th AE VW GTI - 369hp 340tq @ 26 PSI
1982 Rabbit Pickup - German AAZ 1.9TD - daily with lots of MPGs |
Tcash Samba Member
Joined: July 20, 2011 Posts: 12843 Location: San Jose, California, USA
Posted: Mon Aug 17, 2015 8:22 am Post subject: |
Thank you.
Tcash |
Brian Samba Moderator
Posted: Mon Aug 17, 2015 10:13 am Post subject: |
Exactly what I needed to hear. Time to start welding _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
Kirk Samba Member
Joined: December 05, 2003 Posts: 5492 Location: North Texas
Posted: Mon Aug 17, 2015 11:07 am Post subject: |
Guess I'll stick with my harbor freight light weight aluminum jack instead. Interesting info. _________________ MAKE FORUMS GREAT AGAIN
Bear
Fasty
Super |
benandmj Samba Member
Joined: October 29, 2012 Posts: 550 Location: Atlanta
Posted: Wed Nov 11, 2015 7:20 pm Post subject: |
| levi20AE wrote: |
Tell me about how you mounted your jack to the swing away? _________________ 85 Westfalia Weekender
91 Syncro Westy |
Hoody Samba Member
Posted: Wed Nov 11, 2015 11:07 pm Post subject: Re: High-Lift, Highlift, High Lift, Hy Lift, Jack |
| Colin prefers a bottle jack. The fact that MADMAX who has seen more extreme situations in more Continents then ANY of us can ever imagine and does not think these are a good idea.....well that's all that I had to read. If your original jacking points are in good shape I don't think you can beat the scissor jack sold by the BD. Much safer then the cheesy one supplied by VW. |
Posted: Thu Nov 12, 2015 3:17 am Post subject: Re: High-Lift, Highlift, High Lift, Hy Lift, Jack |
The original VW jack is hinged so that it doesn't bind in the jacking point and rip it right out of the body. If you want to make an adapter to use a hi-lift on a bus it should also incorporate a hinge.
When I used to do a lot of 4 wheeling, I had pipe bumpers and would insert the tongue of the hi-lift into the ends of the bumpers instead of just setting the tongue under the bumper like most everyone else did. This greatly reduced the chance that the hi-lift would kick out and maiming someone in the process.
How is this for an idea? Find a piece of tubing that fits the jack point well and cut it three or four inches longer than the depth of the jack point. Now take a 2" ID lifting ring and weld it beneath one end of the tubing in such a way that the tongue of the hi-lift can stick into into the ring. Now you can lift by the jack point with the jack further from the body and have it so the jack can not kick out very easily. The adapter will also function as a hinge.
https://www.carrlane.com/catalog/index.cfm/2802507...5352435A5F |
Posted: Wed Nov 18, 2015 5:13 pm Post subject: Re: High-Lift, Highlift, High Lift, Hy Lift, Jack |
I like the look of those brackets, thanks. That damn Hi Lift weighs more than everything else combined. I'm tempted to stick a bottle jack under the bench.
Enjoyed your build thread! _________________ 85 Westfalia Weekender
91 Syncro Westy |
Posted: Thu Nov 19, 2015 5:58 pm Post subject: Re: High-Lift, Highlift, High Lift, Hy Lift, Jack |
I had a similar idea to the ring once before while getting out of a dumb situation. I was planning to build a set of rock rails with adapters to distribute the load of the jack between both existing jack points and probably two additional braces back to the center frame rails. The really big benefit of the GoWesty style adaptor is that it helps prevent the bus from tilting away from the jack point and punching a hole through your body work with the top of the jack. That leverage adds up fast. _________________ 1973 Campmobile http://www.thesamba.com/vw/forum/viewtopic.php?t=524511&postdays=0&postorder=asc&start=0
