1641 for a daily driver?
daisy71
daisy71 is offline
PostPosted: Wed Aug 19, 2015 7:19 am    Post subject: 1641 for a daily driver? Reply with quote
Would it make sense to put on 1641 pistons and jugs for a daily driver? I don't mind the stock 1600 but a bit more kick to keep up with traffic is always nice.
71 Super beetle
Brian
Brian is offline
PostPosted: Wed Aug 19, 2015 9:32 am    Post subject: Reply with quote
It would make more sense to slip in some jugs to make a 1835. I had a 1641 and it was great, but you can get a little more kick for, barely, more money.
Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter
Cusser
Cusser is offline
PostPosted: Wed Aug 19, 2015 12:06 pm    Post subject: Reply with quote
I love my 1835 !!!
Multi69s
Multi69s is offline
PostPosted: Wed Aug 19, 2015 1:32 pm    Post subject: Reply with quote
The problem with going 1835, is that you have to totally disassemble the engine, then send the case and heads out to be bored. Personally I wouldn't go 1835 for a DD unless they are thick walls. Cusser, I know that you have ran yours for quite a long time, but you have a Baja, and they tend to run cooler then a sedan.
69 road Bug 2110
73 Squareback - 2L, T4, Automatic W/ AC
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight=
gt1953
gt1953 is offline
PostPosted: Wed Aug 19, 2015 1:42 pm    Post subject: Reply with quote
Um no Mr. Cusser does not have a Baja. But he will tell us that.
As far as going to a 1641 hardly worth it. Save you $$ and then decide what you want.
72 type 1
72 Squareback
goober
goober is online now
PostPosted: Wed Aug 19, 2015 2:08 pm    Post subject: Reply with quote
It's easy to do. I've been running 1641 single-ports in my street-bajas (engines are enclosed) for years without any problems. You're only going to get a couple more horsepower but it helps.
Where I noticed the improvement the most was being able to climb hills better in 4th gear.
Cusser
Cusser is offline
PostPosted: Wed Aug 19, 2015 4:39 pm    Post subject: Re: 1641 for a daily driver? Reply with quote
The "advantage" of the 1641cc is that the stuff is just bolt-in; nonetheless, it would be "a little" more power, but I would never tear down a working 1500cc or 1600cc engine to install those. However, if one was doing a top end build anyway and wanted to do this, would only cost a few dollars more.
No, my 1835cc engine is not in a Baja. It was in my 1970 sedan for 17 years using dealer-installed AC, sat idle for like 5 years, then has been in my 1971 Convertible for about a decade. I do live in Arizona though, doesn't get much hotter than the 117F we had here last Friday. I don't run a doghouse cooler either, I've run an external cooler on the front (hidden) side of the fan shroud since back in 1976 - the kind of cooler that many say won't work. And I have engine lid standoffs.
Are my cylinders scored or out-of-round due to heat? I have no idea, I last saw them when I bolted them on in 1986 !!!
mhisel
mhisel is offline
PostPosted: Sat Dec 12, 2015 3:45 pm    Post subject: Re: 1641 for a daily driver? Reply with quote
1679cc slips (88pistons) into to the case and open/machine heads.
pernest
pernest is offline
PostPosted: Sat Dec 12, 2015 6:52 pm    Post subject: Re: 1641 for a daily driver? Reply with quote
My wife and I have been driving a '73 std beetle as a back up car to our also old Chevy Lumina for over 18 years with a 1641. The engine was rebuilt in 1997 and we have put over 70 thousand miles on it.
I would go back to 1600 if it ever needs to be rebuilt again under our watch but the 1641 has never run hot and is very dependable.
Peyton
morymob
morymob is offline
PostPosted: Sun Dec 13, 2015 4:43 am    Post subject: Re: 1641 for a daily driver? Reply with quote
My biggest boost on that size eng was adding a 2bbl carb, solved the hill problems on roads i usually use or getting upto speed in traffic, rarelly did the 70's mph tho.
danlewister
danlewister is offline
PostPosted: Sun Dec 13, 2015 10:15 am    Post subject: Re: 1641 for a daily driver? Reply with quote
I took my stock 1600 and built it into a 1641 as a daily driver. It gave me a little more boost, which was all I wanted at the time. This was a recommendation from a long time vw mechanic after I told him what I wanted. I was doing a rebuild anyway and had a tight budget. You'd be surprised by how much power this engine can produce if it is well-tuned. This mechanic ran a rail buggy with this size engine and stock carburetor and was able to outrun other who spent thousands more to get more power!
