Wideband Air Fuel Ratio Gauge
Page: Previous  1, 2
mattcfish
mattcfish is offline
PostPosted: Tue Nov 27, 2012 5:57 pm    Post subject: Reply with quote
denwood wrote:
Understood..I realize the wideband is using a different sensor that is much more accurate outside stoichiometric. That said, installing it a separate bung won't change much if you're interfacing to digifant with it's "dumb" output.
You only need one bung, and rather than monitoring the ECU -> connection directly as I'm doing currently, you'd run one output (emulator) to your ECU, and a 2nd output to the MTX controller/gauge. Correct?
Yeah, but...I'm under the impression that a Digi ECU designed to use a Narrowband O2 won't work with a Wideband O2. Am I wrong?
71 Bay Window
75 BMW 2002
76 BMW R90S
85 Vanagon with 2.2L upgrade
denwood
denwood is offline
PostPosted: Tue Nov 27, 2012 8:34 pm    Post subject: Reply with quote
Just scanned the tech docs..the Mtx has two analog 0-5v outputs. You would connect one of those outputs to emulate the narrowband function to your ECU.
From the manual, it appears this analog output can be programmed .. so an interesting way to alter air/fuel in closed loop operation. Maybe some mileage gains to be had by leaning things out a bit at cruise. Has anyone out there programmed these curves??
Love the logging option too via serial. This gives the digifant system the option to at least log air/fuel ratio if fitted with the MTX.
Cheers,
Dennis Wood
The Grape
presslab
presslab is offline
PostPosted: Tue Nov 27, 2012 8:41 pm    Post subject: Reply with quote
The wideband sensor only connects to the MTX-L gauge. The gauge then has an output that can be used to drive the stock ECU.
That said, I don't use the emulated output. I only use the wideband while tuning, so I put the extra bung in an easy to access spot. It's easier than trying to patch into the ECU signal.
1986 Vanagon Westfalia EJ25
1988 Subaru GL-10 EJ20G --- 2000 Honda XR650L
2010 Titus El Guapo --- 2011 On-One 456 Ti
mattcfish
PostPosted: Tue Nov 27, 2012 8:47 pm    Post subject: Reply with quote
Just gets better and better.
71 Bay Window
75 BMW 2002
76 BMW R90S
tjet
tjet is offline
PostPosted: Sat Sep 12, 2015 8:58 pm    Post subject: Re: Wideband Air Fuel Ratio Gauge Reply with quote
[email protected] wrote:
http://vwparts.aircooled.net/Innovate-MTX-L-Wideband-Oxygen-Sensor-Kit-3844-p/innovate-3844.htm
is outstanding and inexpensive IMO.
Do you have multiple o2 sensor bungs installed, & just move the sensor as needed to different cylinders?
ohhorob
ohhorob is offline
PostPosted: Sat Sep 12, 2015 9:06 pm    Post subject: Reply with quote
No, you just use the standard bung. The AFR is total system, not cylinder by cylinder.
"Gundy" - '85 Westfalia
GoWesty 2300cc, Digijet
tjet
tjet is offline
PostPosted: Sat Sep 12, 2015 11:51 pm    Post subject: Reply with quote
It's for a dual IDF WBX I bought last month. I want to check both carbs independently
Page: Previous  1, 2
Page 2 of 2
