how to remove the injectors 1975 bus fi
Tim in alaska
Tim in alaska is offline
PostPosted: Mon Sep 14, 2015 2:26 pm    Post subject: how to remove the injectors 1975 bus fi Reply with quote
I did a search on this and nothing came up... My manual says remove them. thats it. woould one of you fine folk tell me how this is done as I find that if I start pulling wires and undoing screws without knowing what I am doing it ends costing me a lot of time and money. Thanik you in advance and by the way thanks also for all the other great help this group has give me.
SGKent Premium Member
SGKent is offline
PostPosted: Mon Sep 14, 2015 2:31 pm    Post subject: Reply with quote
each injector is held in by a clamp that goes over top of it. One nut holds that clamp. There will be two replaceable rubber seals for each that you will need. Also the plastic will be brittle so be gentle with the electrical connectors. There is a wire hoop that goes all the way around you will need to spring open a little to get them off.
from gallery. You can see the nut on the clamp, and the plastic connector on the injector.
EDIT OUT
George Carlin:
Skills@EuroCarsPlus:
Tcash
Tcash is offline
PostPosted: Mon Sep 14, 2015 2:49 pm    Post subject: Reply with quote
Don't cut the hose unless you have hose and extra hose clamps to replace it.
It is a good idea to replace the hoses while you are in there.
7mm injection hose.
What is it that you are doing?
Good Luck
Tcash
airschooled
Air-Schooled
airschooled is offline
PostPosted: Mon Sep 14, 2015 7:07 pm    Post subject: Reply with quote
Wouldn't it be prudent to put suction on the vacuum line to the fuel pressure regulator first, so you can allow the residual pressure to equalize and avoid spraying fuel out of the freshly-cut lines?
WTB: 215mm Type 4 flywheel. Cash in hand.
www.airschooled.com
Road trip reports and tech blog:
SGKent is offline
PostPosted: Mon Sep 14, 2015 8:25 pm    Post subject: Reply with quote
There are a lot of things that should be done. I probably never should have used that photo from the gallery so I will fix that.
DONE. Too many people thinking too many what ifs around here but in a way that is a good thing cause you are right - some poor soul would just see the photo and cut the hose without thinking about pressure or the fuel tank draining down.
George Carlin:
Tim in alaska
PostPosted: Tue Sep 15, 2015 12:21 pm    Post subject: removing injectors Reply with quote
thanks for your replies to this folks.. tcash I am trying to trouble shoot a low Idle and rough Idle and sometimes a hiccup on highway. In short I did comlete tune up by the book... then timed to 2800 with both hoses to distributor off and plugged... I tested fuel pressuress per the manual and all came out ok so have taken the pressure valve and pump off the list. I did replace fuel filter. I also tested aar valve per the book... I have no problem with starts either cold or hot..... so Now I am going to test the temp sensors and if they are ok going to look at the injectors.....
can I ask too do the injectors have to be cut from the fuel ring that is the hose that connects or does it pop off... regarding fuel pressures when you take them off... at pressure test I took the bolt off the fuel ring and attached pressure gauge there... there was an initial little spray but not alot.
Also could you advise what the sensor is that is shown in the photo ... I thought I had found sensor 1 afm and sensor two in back close to cyl 3 what is this one up by cyl 4.
thanks folks tim
SGKent is offline
PostPosted: Tue Sep 15, 2015 12:27 pm    Post subject: Reply with quote
that photo is #3. left side front.
Hiccup can be a slug of water, loose valve seat, bad plug wire or plug, worn points, bad cap or rotor, loose wire, afm track worn. Start with the easiest items first. Add some fuel drier to the gas and see if that helps. Run a bottle of injector cleaner (techron) thru the tank if that doesn't get it. Check the points if you haven't already replaced them. Look at the inside of the cap for carbon tracks. If it happens more in damp weather suspect the plug wires.
George Carlin:
Tim in alaska
PostPosted: Tue Sep 15, 2015 12:30 pm    Post subject: fuel injectors Reply with quote
woops I think the one shown is temp sensor II the one I am uncertain of is just forward and below the distributor. I know I should get photo but my computer skills are lacking. thanks again
SGKent is offline
PostPosted: Tue Sep 15, 2015 12:32 pm    Post subject: Re: fuel injectors Reply with quote
That one controls the CSV when starting cold. CSV injects fuel briefly when the engine starts cold.
George Carlin:
SGKent is offline
PostPosted: Tue Sep 15, 2015 12:35 pm    Post subject: Reply with quote
oh - the injectors are barbed so once the hose is on it has to be cut off. Most of us put clamps on them when replacing the hose although VW did not. The clamps must have rolled sides so not to cut the hose.
George Carlin:
Tcash
Tcash is offline
PostPosted: Tue Sep 15, 2015 1:52 pm    Post subject: Reply with quote
Right below the distributor is the oil light switch.
The one with the brown connector is the TTS (thermal time switch).
Pull the three white wires and clean the connectors for the Injection system.
The TSII (temp. sensor two) causes most of the problems.
Good luck
Tcash
Tim in alaska
PostPosted: Tue Sep 15, 2015 2:26 pm    Post subject: injectors Reply with quote
thank you again for taking the time and trouble to help us pooor old newbys that are just learnin... best to you all tim
rshepard10
rshepard10 is offline
PostPosted: Tue Sep 15, 2015 9:31 pm    Post subject: Reply with quote
That photo looks familiar Wink
Also notice the massive fuel line the "mechanic" put on coming from the pump and just clamped down as hard as he could. Cause of my fuel leak Mad
1978 VW Deluxe 2000cc FI
1994 Jeep YJ (Jurassic Park #22)
Certified Diagnostic Mercedes-Benz Technician
busdaddy
busdaddy is offline
PostPosted: Tue Sep 15, 2015 10:02 pm    Post subject: Reply with quote
And the lack of a grommet where it passes through the tin, quality work there Confused
Слава Україні!
rshepard10
PostPosted: Wed Sep 16, 2015 12:17 am    Post subject: Reply with quote
Right? That guy was a piece of work Rolling Eyes
But that picture came from my injector questions thread a while back
Tim in alaska
PostPosted: Tue Sep 22, 2015 5:15 pm    Post subject: what the but thanks Reply with quote
well being a new by or what ever and also not being computer r literate it looks like I made the over seers of this site unhappy...
when I look at this engine My jaw just goes slack as I mostly have no idea what I am doing... i have rebuilt an old willys pickup took it all apart and put it back to one piece and got it running and sold it. On the willys site you asked questions each time you ran into a problem. folks were pretty happy to help you out.
I thought it was pretty much the same here as I received a lot of good input. I do have the bentley manual and also the bosch fi manual and try to get things done by it before I post here.
as you can no doubt see from my posts I am just looking for answers...and am sure sorry that new threads are a problem with the administrator. I am just trying to narrow things down to help me with what I know almost nothing about... I sure do appreciate you folks for the past answers which have helped me muchly.... best to you in reply to the block and leave it on
Tcash
Tcash is offline
PostPosted: Tue Sep 22, 2015 6:32 pm    Post subject: Reply with quote
No worries. It is easier to follow along and see what repairs you have made if it is located in one thread.
If you have a different question. Change the subject title.
Maybe use this thread?
click on link
1975 bus 1800 fi
Good Luck
Tcash
Tim in alaska
PostPosted: Tue Sep 22, 2015 9:40 pm    Post subject: bad idle tcash Reply with quote
hello tcash and thanks again for all your help... i am going a this in dinda of a shotgun type of way.. my latest is in reading the manual i see where to check egr and throttle you should pull electric from egr and run throttle in and out to see how egr reacts.... when taking off this electrical connection to the egr vacuum i find that the connection to the controller only has one contact that is the blue connector has one connector that is there and one that is non existant... there can be no connection between the throttle and egr... we do not have emmission controlls here and I am wondering if when whoever rebuilt the engine just deleted this from the plug...... would seem like ther could have just taken this off... but with vw you never know i am finding out... could you advise would this cause an idle problem and just how does the blue connector from the controller connect to the controller... can the large black rubber connectionbe rolled back from the blue connector... thanks for your help tim and sure appreciate your help.
Tcash
Tcash is offline
PostPosted: Tue Sep 22, 2015 10:15 pm    Post subject: Re: bad idle tcash Reply with quote
You're welcome.
When taking off this electrical connection to the egr vacuum i find that the connection to the controller only has one contact.
Should have two contacts.
That is the blue connector.
EGR connector is black. Cold start valve is blue.
Could you advise would this cause an idle problem.
Find the black connector and connect that to the egr valve.
Connect the blue connector to the cold start vavle.
Good Luck
Tcash
75 Westy FI noob
75 Westy FI noob is offline
PostPosted: Mon Dec 05, 2022 1:18 pm    Post subject: Reply with quote
Good luck
Tcash
does the plenum have to come off to replace the TSII ?
that's an odd looking gadget.. not clear on how it attaches or connects.
Mine's not running (after 7 year sitting) .. and since it causes problems it may be a prob on mine.
