Alexios Samba Member
Posted: Sat Feb 11, 2012 6:24 am Post subject: |
Under dash 16a
On heater 8a ( i will run down and check later today)
I have never had the fuse on the heater blow. Just the one under the dash.
Alex |
obnoxiousblue Samba Member
Joined: February 21, 2007 Posts: 2946 Location: East Northport, NY
Posted: Thu Oct 25, 2012 7:02 pm Post subject: |
Hey folks! I have a BN4 in my Baywindow, looks like a dealer install, as its too clearly routed and loomed to ave been a PO install. I'm to sure on the procedure for trying to fire this thing up, and am soon to replace my fuel lines and had been considering bypassing the heater altogether.
Before I do, can someone give me a short list of things to check to see if this heater might run, how to run it, or what to look for? I'm or familiar with these things AT ALL lol
If I do wind up bypassing it, is there anything I should be cautiouslf to avoid creating a new hazard?
Hope this thing is workable!
Thanks!
Mike
_________________ Mike
1964 Beetle
2001 Eurovan Camper |
Captain Spalding Samba Member
Joined: February 19, 2005 Posts: 2519 Location: . . . in denial.
Posted: Thu Oct 25, 2012 8:49 pm Post subject: |
I would just make sure that the intakes and exhausts are free of critters and nests. |
Posted: Thu Nov 08, 2012 5:55 pm Post subject: |
Hey guys! Mike here, new to the thing/181 forum but making my grand entrance to call upon your gas heater expertise.
I have a Baywindow, with a bn4. My heater doesn't work. I had considered trying to fix it, but found a guy here on TS that has great pricing on restored units.
Next comes to, while I have one currently installed does anyone here have instructions perhaps from when these things were new on how to PROPERLY install the heater?
Of course I'm very fearful of fire, and have no idea how these things work or hook into the bus. I will be learning, once I have all my pieces gathered in a couple weeks. But would like something to look back upon so I can be comfortable I've installed it the way it was intended.
Thanks _________________ Mike
1964 Beetle
doublecanister Samba Member
Joined: September 23, 2008 Posts: 1184 Location: Richmond, Va
Posted: Wed Apr 17, 2013 10:31 am Post subject: |
Alexios wrote: |
Hi
I am having almost the same issue. My heater is working fine(finally) but burns the fuse after one hour and 30 min. If i replace the fuse immediately it blows it again after less than 5 minutes. The fuse that gets blow is the one under the dash.
Does the thermal cutout switch through the fuse under the dash or the one one the heater?
Alex |
Hey Alex!
I just caught one thing you said, "after and Hour and 30 Min",
The timer for the heater was Only supposed to run like 25 min I think, then start the cool down cycle, then you'd have to turn it back on and repeat.
Don't know if that means anything but could your's be getting hot cause the timers bad and wont cycle to off? not sure, but Mine was broke and wouldnt time off, I ended up replacing with one from the Thing shop.
Could be totally off but thought I'd mention.
Also, ive had mine trip/reset before, so I dont run it full wide open on the temp setting any more, seemd it was getting a bit too hot maybe.
so far been running well.
good luck with the fix.
T _________________ ****************************************
2020 - Mustang Eco Boost [High Performance]
1973 - Thing
1966 - Mustang GT- Fastback
1951 - Ford F1 pickup Flathead V8 |
Bajaman65 Samba Member
Joined: January 16, 2007 Posts: 469 Location: Borrego Springs
Posted: Sun Jul 21, 2013 7:41 am Post subject: I got lucky |
I think I must have just got luck when I installed the new fuel pump and it all work just like it should, not cheap but it works good. Good luck to you.
perello Samba Member
Joined: April 15, 2005 Posts: 830 Location: where social security comes for free
Posted: Mon Jul 22, 2013 11:09 am Post subject: |
Sorry for OOT, but Bajaman65...what did you place under the spare wheel bracket??
Mines is lousy and wonder what should be done to make it hold tight _________________ Aug '58 pressed bumper SO23
1974 German Thing
1978 Bug 1200 |
Posted: Sun Jul 28, 2013 6:51 am Post subject: Bracket |
That is a totally stock factory mount with the 1/2 inch felt glued to the bottom. I have had it off road and the tire never moves around. |
crofty Judas of the North
Joined: August 09, 2000 Posts: 19673 Location: Land of Whine and Phonies
Posted: Tue Aug 27, 2013 1:42 pm Post subject: |
obnoxiousblue wrote: |
Thanks |
Stacey in Canada sells a reprint of the BN4 heater manual. A WISE investment for sure. Search the classifieds for "eberspacher" _________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
analogmax Samba Member
Joined: September 27, 2006 Posts: 161 Location: Chandler, Arizona
mr white Samba Member
Joined: October 02, 2005 Posts: 1193 Location: beautiful Oregon & Mohave County, AZ
Posted: Sun Oct 20, 2013 7:56 pm Post subject: |
I think I am losing it! I could have sworn I read a stretch in here regarding a guy who rebuilds the timer switches in the dash. Is there such a person or service? Mine needs it....bad! |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22465 Location: Escondido CA
Posted: Fri Oct 09, 2015 3:19 pm Post subject: |
That is great.
I'll be downloading a number of his videos. |
hubscaps Samba Member
Joined: March 24, 2013 Posts: 6 Location: United States
Posted: Thu Nov 05, 2015 4:52 pm Post subject: BN4 wire diagram question |
Good day!
I am rebuilding a Eberspacher BN4 gas heater but I'm having a problem trouble shooting some wiring issues.
I have taken a picture of the data plate on the heater and a shot of the wiring and attached to this email for your reference.
I was wondering if you hade a copy of the correct wiring digram for my heater? Please note that my heater does not have a temperature control sensor at the exit of the heater.
Thank you in advance for any help you can offer.
[/img] |
Posted: Sat Dec 26, 2015 1:11 pm Post subject: Re: Heating FAQs - BN4 Gas heaters & heating related top |
I've been snooping around lately for new glow-spark plug buying options, pleased to say I've found a few. They are available here on the samba from time to time, but the vendors here seem to be really proud of them and ask for way too much money for an item that not many VW enthusiasts are even into. Shame as these cool - "hot" parts may never get into the right hands and may be destined to sit on a shelf - too proud to see use. Ive tried to show these vendors links and sales for the same parts - for less elsewhere with little interest to sell at a comparable price. So fine - I get to use this emoji :fist: and this
I posted most info to the bay BN4 thread I've been running up. Just thought some of you would find some of the last postings of interest.
http://www.thesamba.com/vw/forum/viewtopic.php?p=7926397#7926397
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
Posted: Sun Nov 13, 2016 11:12 pm Post subject: Re: Heating FAQs - BN4 Gas heaters & heating related topics |
Anyone have any temp control knobs they want to sell? The one on the left for the cable - hooked to the thermostat says TEMP on it?
Let me know. Thanks! _________________
t3kg wrote: |
1964 1500 S
Posted: Mon Nov 14, 2016 12:15 pm Post subject: Re: BN4 wire diagram question |
hubscaps wrote: |
Please note that my heater does not have a temperature control sensor at the exit of the heater. |
Yeah. It has an unusual safety switch there too. Possibly some home brew happening there.
You can find the wiring diagrams for the BN-4 in the Technical Section under Thing Wiring. Click here and scroll down. While you're there you might want to have a look at the BN-4 Ladder Diagram. You should be very wary of operating a gas heater with substituted or missing components. The safe use of the heater depends on the ability of the components to interact with one another.
Here's a photo of the top of the heater with the components labeled as per the wiring diagram.
Hope that helps . . . |
ashtonmwilson Samba Member
Joined: March 09, 2016 Posts: 3 Location: Hailey, Idaho
Posted: Wed Dec 07, 2016 11:40 am Post subject: Re: Heating FAQs - BN4 Gas heaters & heating related topics |
so... Is there any "safe" way to bypass the "saftey switch", one of my little paper looking fuse type connectors on the top end of the saftey switch is busted, can it be replaced? if so with what? |
Posted: Wed Dec 07, 2016 12:05 pm Post subject: Re: Heating FAQs - BN4 Gas heaters & heating related topics |
ashtonmwilson wrote: |
I would get a new safety switch. But its basically a circuit breaker for the most part. If you bypass and something else is at fault - I could only imagine a wire heating and burning ruining your loom. If everything is fine - it will run fine. _________________
t3kg wrote: |
1964 1500 S
Posted: Wed Dec 07, 2016 6:35 pm Post subject: Re: Heating FAQs - BN4 Gas heaters & heating related topics |
The Safety Switch is an important safety component. There is a small heating element in the safety switch. When you turn on a cold heater, that heating element begins to heat up. If for any one of a number of reasons the BN4 doesn't fire and begin to produce heat, after a predetermined time the heater in the safety switch will heat up a bi-metal piece inside the safety switch which will deform and trip the switch, thereby shutting the BN4 heater off. This is to prevent a dangerous buildup of unburned fuel in the BN4. So, while it is possible to bypass the safety switch, it's not advisable. |
