Superior turtleback lugs
Forum Index -> Custom Wheel/Tire Share: Facebook Twitter
larry88
larry88 is offline
PostPosted: Mon Oct 19, 2015 1:19 pm    Post subject: Superior turtleback lugs Reply with quote
can I get advice on what I use besiside the OG lug which I cant find, to mount turtlebacks Part # would help Thanks
Typ3nut
Typ3nut is online now
PostPosted: Tue Oct 20, 2015 9:00 am    Post subject: Reply with quote
Finding the Originals is Unobtainable, very "Hard to Find" ...
This is what I used as an option for mounting FV Superior VolksMag Wheels : aka Turtlebacks.
*NOTE : Shoulder of Mag Lugs MUST be snug fit to holes, if NOT, Centering of Wheels to Rotors & Drums may not be achieved, they Will be off center.
Mag Wheel Lug Holes may need to be drilled for this application.
Stud Kit, Mag Wheel Lug Nuts, Mag Flat Washers.
Loctite (Heavy Grade, Red) Stud into Mag Lug Nut (Let set-up overnight) install Washer, Mount Wheel, Tighten.
This is what I used for the Volksmag Wheels application.
This is what the Original Lugs look like.
easy e
easy e is offline
PostPosted: Tue Oct 20, 2015 3:47 pm    Post subject: Reply with quote
What the original (be exact):
1) stud size... dia/thread pitch
2) rim's lug hole dia (should keep lug shaft dia to within 1/32" rim's hole dia.)
3) original washer outer dia. (or recess in the rim dia.)
4) original lug shank dia.
Once these get nailed down... you'll have a standing chance.
aka: Evan
larry88
larry88 is offline
PostPosted: Wed Oct 21, 2015 5:22 am    Post subject: got a # Reply with quote
this is what you use but what's the deal, you use this and say maybe drill the wheel to fit, till you find the correct lug but then the wheel is not stock so the correct lug won't fit, what is the part # anyway cause I don't think I'll ever find OG lugs,
Typ3nut
PostPosted: Wed Oct 21, 2015 10:44 am    Post subject: Reply with quote
Cip1 ...
http://www2.cip1.com/SearchResults.asp?Cat=1254
Here's the tread with all the info.
http://www.thesamba.com/vw/forum/viewtopic.php?t=122676&highlight=lug+nut
Mike Fisher
Mike Fisher is offline
PostPosted: Wed Oct 21, 2015 1:10 pm    Post subject: Reply with quote
http://www.ezaccessory.com/Lug_Wheel_Bolts_s/20.htm ?
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
larry88
larry88 is offline
PostPosted: Wed Oct 21, 2015 1:14 pm    Post subject: Reply with quote
already read that thread nowhere does the thread give any definite answer to the question
Mike Fisher
PostPosted: Wed Oct 21, 2015 2:30 pm    Post subject: Reply with quote
Typ3nut is our Resident Expert on aftermarket VW wheels, so If you don't want to follow his advice you are on your own? 12mm X 1.50 thread is the 4 lug drum/disc thread. You can measure your own wheels. Rolling Eyes
fatty1970
fatty1970 is offline
PostPosted: Thu Jan 07, 2016 10:13 am    Post subject: Reply with quote
[quote="Typ3nut"]Finding the Originals is Unobtainable, very "Hard to Find" ...
is this what you used or does this seem like it would workhttps://www.doghouserepair.com/store/item/4150/9511-0-wheel-nut-stud-kit-washers-14mm-1-2-20-mag-wheel-empi/
fatty1970
PostPosted: Thu Jan 07, 2016 10:15 am    Post subject: Re: Superior turtleback lugs Reply with quote
Sorry messed that link up
https://www.doghouserepair.com/store/item/4150/951...heel-empi/
fatty1970
PostPosted: Thu Jan 07, 2016 11:12 am    Post subject: Re: Superior turtleback lugs Reply with quote
And would jb weld be better to use rather than loctite?
air-h2o-air
air-h2o-air is offline
PostPosted: Thu Jan 07, 2016 10:17 pm    Post subject: Re: Superior turtleback lugs Reply with quote
i have a set of original lugs and 4 locking...pm...if i can help
fatty1970
PostPosted: Sat Jan 09, 2016 5:17 pm    Post subject: Re: Superior turtleback lugs Reply with quote
I pm you not sure if you got it
air-h2o-air
PostPosted: Thu Jan 14, 2016 11:43 am    Post subject: Re: Superior turtleback lugs Reply with quote
original Superior Turtleback lugs and locking lugs
fatty1970
PostPosted: Thu Jan 14, 2016 12:20 pm    Post subject: Re: Superior turtleback lugs Reply with quote
Great just pm me
larry88
larry88 is offline
PostPosted: Sat Jul 23, 2016 11:55 am    Post subject: Re: Superior turtleback lugs Reply with quote
just wondering if u still have turtle back lugs ? [email protected]
flightofphx
flightofphx is offline
PostPosted: Sun Nov 29, 2020 10:20 pm    Post subject: Reply with quote
Sorry to dig this up, but I am just recently obtained turtlebacks. Is the stud 14mmx1.50 to 1/2? Or, would this work? https://www.jbugs.com/product/9511.html
Mike Fisher
PostPosted: Sun Nov 29, 2020 11:44 pm    Post subject: Re: Superior turtleback lugs Reply with quote
There was a guy today on Facebook in one of the VW groups showing off his Turtlebacks with new correct lugbolts/washers etc he bought from a company somewhere.
flightofphx
PostPosted: Mon Nov 30, 2020 7:50 am    Post subject: Re: Superior turtleback lugs Reply with quote
Which facebook group?
flightofphx
PostPosted: Tue Mar 30, 2021 10:16 am    Post subject: Re: Superior turtleback lugs Reply with quote
I realize I am late to the party, but I just got turtlebacks for my fastback.
Does anyone know if these will work as wheelbolts?
https://www2.cip1.com/ProductDetails.asp?ProductCode=C13%2D70%2D2703
Annie referred to having to use Empi wheel locks with hers - I am not sure if these are the one she was referring to.
Reply to topic    Forum Index -> Custom Wheel/Tire All times are Mountain Standard Time/Pacific Daylight Savings Time
