Oil filler cap spooj / gunk
nocartax
nocartax is offline
PostPosted: Sat Oct 31, 2015 12:53 pm    Post subject: Oil filler cap spooj / gunk Reply with quote
Hi..my daughter's '72 1600 gets a sort of milky / foamy spooj type substance in the oil cap area. - i could expect this with a water cooled car - but air cooled?..
We are in the South of England, and it's her daily driver with about a 20-30 minute commute.
Any ideas?
Cheers
Tim.
djkeev
djkeev is offline
PostPosted: Sat Oct 31, 2015 12:55 pm    Post subject: Reply with quote
Crankcase oil vapor mixing with high humidity in the air.
Dave
Ghia
Vanagon
Beetle
ps2375
ps2375 is offline
PostPosted: Sat Oct 31, 2015 12:58 pm    Post subject: Reply with quote
Moisture in the crankcase. Normal in cooler weather, especially in a humid area. Short trips don't help with not getting up to temp for long enough to "burn" the contaminates off. Change the oil more often or have her drive it longer.
nocartax
nocartax is offline
PostPosted: Sat Oct 31, 2015 1:04 pm    Post subject: Reply with quote
Thanks chaps, so i guess we need to change the oil more often. Thats Ok. Any breathers or anything else?
Cheers
Tim.
HRVW
HRVW is offline
Smile It is the brand of oil your using.
If it were a climate thing then all the cars would have the same issue but DO NOT thus the brand of oil.
Having been a engine builder in a coastal city would on occasion see a car that had the same soapy/foam substance mentioned. I narrowed the problem to a particular brand of oil the people were using in my area.
There will be some disagreements here but proof is in the pudding.
Edit: Had customers that lived 30 ft from the beach sand that had NO problem while another did.
When listening to a running motor would remove the oil cap looking for any blowby and then casually asked how long they had been using a certain brand of oil. Question was asked, "How did you know that?" I explained my conclusions having been on the same street in business for 17 yrs.
Such is life.
Mudpump
Mudpump is offline
PostPosted: Sat Oct 31, 2015 1:05 pm    Post subject: Reply with quote
common issue on ACVW's. Frequently also shows up in the breather hose. Looks ugly but doesn't hurt anything
runamoc Premium Member
runamoc is offline
PostPosted: Sat Oct 31, 2015 1:19 pm    Post subject: Reply with quote
Usually occurs in ACVWs that don't have a thermostat. Now we can hear from folks that live where the humidity is 0% and will post to tell they don't need one. You will need one to get the engine/oil temps high enough to 'boil' the water out of the crankcase Laughing
BarbBee
BarbBee is offline
PostPosted: Sat Oct 31, 2015 1:50 pm    Post subject: Reply with quote
Hi, I'm on the south coast uk too. I've not found a change in oil brand made any difference tbh. My a/c's have always been dailys and I had the same problem when only doing short trips, plus at this time of year when it goes damp in the evenings (like this evening) it can be more of a problem than the summer. Have her take it out for a good drive at the weekend and just wipe out now and again as needed. It shouldn't build up that quickly Smile
VWCOOL
VWCOOL is offline
PostPosted: Sat Oct 31, 2015 2:29 pm    Post subject: Reply with quote
As others have said, it's not harmful - just indicative of a little moisture in the oil rising and condensing under the cap.
Moisture is a normal by-product of engine operation
Do you have the breather hose fitted from the oil cap area to the air cleaner?
nocartax
nocartax is offline
PostPosted: Sat Oct 31, 2015 3:40 pm    Post subject: Reply with quote
Yes. it is there. It pretty much looks like ice cream in there at the moment. My cork gasket looks like shaving foam.
miller0358
miller0358 is offline
PostPosted: Sat Oct 31, 2015 3:49 pm    Post subject: gunk Reply with quote
Same thing happens when people think it's a good idea to start the motor for a few minutes when the car is stored for the winter. It creates condensation that doesn't have enough heat to evaporate. You always need to get to operating temperature and then some to take care of this problem Jeff
gt1953
gt1953 is offline
PostPosted: Sat Oct 31, 2015 6:15 pm    Post subject: Reply with quote
Honestly I was waiting for this post to show up as it always does this time of year.
Simple solution is to drive the car on the hyway one way for 30 minutes and turn around and drive back. White foamy gooy stuff will be gone.
Having a thermostat and flaps helps out a bunch.
72 type 1
72 Squareback
Bruce
Bruce is offline
PostPosted: Sat Oct 31, 2015 7:15 pm    Post subject: Re: Oil filler cap spooj / gunk Reply with quote
Any ideas?
Look under the right cylinder bank. Do you see a bracket with a brass bellows? I'm guessing no. That is the cause of the foam you're seeing. Many years ago, some lame brained mechanic decided that it was so hot in the UK all the time that your engine needed maximum cooling, even in the winter. The result is your engine is now over cooling. The foam you're seeing is the messenger of the problem. Install the thermostat and in her 20 min commute the engine will get up to full operating temp, which will prevent the foam at your filler cap.
Volks Wagen
Volks Wagen is offline
PostPosted: Sun Nov 01, 2015 10:13 am    Post subject: Reply with quote
I agree with Bruce.
1973 1303 with AB-motor - sporadic
reconstruction as time permits, 1986 ex-Bundeswehr Doka - on the road again.
I'm definitely, probably, the worlds greatest lover.
Aithníonn ciaróg ciaróg eile.
nocartax
nocartax is offline
PostPosted: Mon Nov 02, 2015 12:44 am    Post subject: Re: Oil filler cap spooj / gunk Reply with quote
Bruce wrote:
Any ideas?
I will have a look. Good advice. And i wouldn't describe any weather in the UK as hot.
I recall seeing a bellows type thing undneath but paid it no attention. Is it this?
Maddel
Maddel is offline
PostPosted: Mon Nov 02, 2015 1:47 am    Post subject: Re: Oil filler cap spooj / gunk Reply with quote
nocartax wrote:
...I recall seeing a bellows type thing undneath but paid it no attention. Is it this?
Taken from emu88's gallery:
By the way, the crankcase breather is missing the "duckbill valve" in this pic... Wink
Also make sure the flaps connected to the thermostat work correctly.
nocartax
nocartax is offline
PostPosted: Sun Nov 15, 2015 2:46 pm    Post subject: Re: Oil filler cap spooj / gunk Reply with quote
Sorry. Blatant bump up to remind myself to check this.
