Correct Air Cleaner set-up
Zylinderkopf
Zylinderkopf is offline
PostPosted: Tue Nov 17, 2015 8:42 am    Post subject: Correct Air Cleaner set-up Reply with quote
There are two hoses that start from the elbow, one goes to the cleaner and one to a port on the carb. I looked at a few pictures in the gallery and saw the hoses connected in a number of different ways. Which way is correct?
Thanks
1963 Beetle
1966 Beetle 1300
1970 Karmann Ghia Coupe
1971 Super Beetle
1974 Thing
"A lot of people never use their initiative because no one told them to."
Ron Domeck
Ron Domeck is offline
PostPosted: Tue Nov 17, 2015 11:11 am    Post subject: Re: Correct Air Cleaner set-up Reply with quote
The long hose connects to the port on the left side of your intake that is plugged on yours. Were that hose is connected to now on the carb would have a hose to the back of the dist. Looks like the wrong Dist. in yours. Check out the engine pics at http://kubeltreffen181.com
Zylinderkopf
PostPosted: Tue Nov 17, 2015 12:12 pm    Post subject: Re: Correct Air Cleaner set-up (vacuum hoses) Reply with quote
Thanks Ron...so Things originally came with dual vacuum advance distributors? I have a Mexican Bosch SVDA on it now. So what I think I'll do is keep the vacuum hose from the distributor where it is now (port on the left side of the carb). I will take the longer hose from the air cleaner elbow and connect it to the port on the intake manifold as you suggest and then plug the port on the back of the carb.
1963 Beetle
1966 Beetle 1300
1971 Super Beetle
1974 Thing
citroen
citroen is offline
PostPosted: Tue Nov 17, 2015 2:42 pm    Post subject: Re: Correct Air Cleaner set-up Reply with quote
here is the 73 thing engine on the last Thing Ron and I just finished you will find this engine is about the most original done you will find.
Zylinderkopf
PostPosted: Wed Nov 18, 2015 4:13 pm    Post subject: Re: Correct Air Cleaner set-up Reply with quote
nice job on that '73 Dennis! You even have the green hose!
1963 Beetle
1966 Beetle 1300
1971 Super Beetle
1974 Thing
ente_kaefer
ente_kaefer is offline
PostPosted: Wed Nov 18, 2015 8:27 pm    Post subject: Re: Correct Air Cleaner set-up Reply with quote
citroen wrote:
here is a 73 thing engine on the last Thing Ron and I just finished you will this engine is about the most original done you will find
Wow, all I can say is . . . wow . . . gorgeous!
A previous owner added a PICT 30 carb, Bosch 009 distributor, as well a 'Flamethrower' points and coil to my car, so my 1973 Thing will not be so 'nice' !
Seeing that the present set up in my car is working, I do not want to fix something that is working . . .
