What to look for when buying a Thing . . .
Captain Spalding
Captain Spalding is offline
PostPosted: Mon Nov 14, 2011 5:53 pm    Post subject: What to look for when buying a Thing . . . Reply with quote
Greetings to all of you prospective Thing owners out there. Looking for a Thing? Need to know what to look for when you're beyond the tire kicking stage? You've come to the right place.
For those discerning individuals already lucky enough to own a Thing, please feel free to add your thoughts!
Semper_Dad
Semper_Dad is offline
PostPosted: Mon Nov 14, 2011 6:14 pm    Post subject: Reply with quote
The deal killer for me is rust Shocked . Particulaly in the rocker areas. Bolt on pieces such as lids, doors, and fenders are easy enough to replace but anything on the main body will require expensive replacement (or donor) panels and welding skills. Only possible rust exception might be battery area. You can almost expect that.
Oh,....and watch out for Bondo. Some Things have literally been sculpted out of the stuff. Use a small magnet to detect the stuff. I found the magnetic catch on my camera case to work really well.
Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492
markmatthewsphd
markmatthewsphd is offline
PostPosted: Wed Nov 16, 2011 10:34 am    Post subject: Reply with quote
Thanks for this wonderful and timely posting! Starting to look for a Thing for my 14-year-old son for his 15th birthday. We shall endeavor to rebuild it in anticipation of his 16th birthday.
-mwm
Captain Spalding
PostPosted: Wed Nov 16, 2011 1:05 pm    Post subject: Reply with quote
-mwm
I wish you were my Dad!
For a new driver, I might consider high back seats (see this sticky), disk brakes, maybe a roll bar with shoulder belts, and a mild motor. The old adage Good judgment comes from experience, and experience comes from bad judgment more than anywhere else applies to new drivers. Wink
Welcome to the forum!
Ian Epperson
Ian Epperson is offline
PostPosted: Mon May 07, 2012 10:45 pm    Post subject: Reply with quote
Clues that may lead to a larger rust problem:
No top or windows. These aren't great at keeping out the elements, but they're a heck of a lot better than nothing.
Flexing windshield, glass and gasket falling into the frame. These are signs the lower frame has rusted out - a complex part that isn't easy to fab and is fairly expensive to replace.
Missing body seal caps at the top of the door posts, above the front door hinges and near where the top hinge pins reside. Water doesn't drain from these voids and rust follows.
Missing body seal caps in the wheel wells - one in each. These cover a round opening into the rockers and without them, the wheels can easily splash water into the rockers.
Missing one-way valves at the base of the rockers or the holes are sealed with non-valved caps. The rockers are designed for a bit of water to flow through them. There are a series of dimples in the base of the door frame to allow water to flow in.
(top-right little hole in this photo)
Then there are three holes at the base of the rocker with one-way flap valves in them. If you run your hand along the bottom edge of the rocker, you'll note there are three bumps, each is a small drain hole - verify that you can gently peel open the rear of the cap with a finger nail.
(you can see one of those bumps here on the new lighter-grey panel, middle-left, and the round hole that should be capped in the rear wheel well.)
If these holes are plugged, water splashing around the door or into the door will collect in the rocker and rust will follow.
VW-181 shirts and stickers.
http://ian.epperson.com/vw
HUGO bOSS
HUGO bOSS is offline
PostPosted: Sun Jul 29, 2012 3:55 pm    Post subject: Reply with quote
And another rust trap is in the front quarter panels...
Normaly you seen them like this:
But under the paint sometimes is just like this:
Should be like this:
With two different metal parts... not just one...
Chas223
Chas223 is offline
PostPosted: Sat Nov 15, 2014 7:10 pm    Post subject: Re: What to look for when buying a Thing . . . Reply with quote
Nicely done!
Captain Spalding
PostPosted: Sun Nov 16, 2014 11:59 am    Post subject: Reply with quote
Thanks!
bump
bump is offline
PostPosted: Thu Nov 26, 2015 10:52 am    Post subject: Re: What to look for when buying a Thing . . . Reply with quote
Thanks for this great thread! I've wanted a type 181 for decades and am now in a town where we can use it.
sportin-wood
sportin-wood is offline
PostPosted: Tue Dec 23, 2025 10:34 am    Post subject: Re: What to look for when buying a Thing . . . Reply with quote
From my own recent experience (and this pretty much applies to any ACVW that has sat out in the elements for an extended time), check the frame horns for rust by getting down on the ground and looking - of which I failed to do.... Hoping I can get it repaired.
Dave
1966 Bug project
1973 Thing project
