icolquhoun Samba Member
Posted: Wed Nov 18, 2015 10:49 am Post subject: Re: Alika's Syncro transmission work |
| ALIKA T3 wrote: |
Thank you guys
Icolquhoun,I'm not sure I understand your advice, I did drill the C-channel and bolted it to the main case. When I added the piece of pipe to keep the pinion nut tool all the way in, there was no way it was to ever slip out of there
The C-channel stuck under the vise was to brace the transmission from spinning around
I have already a Tdi adapter plate from Germany I got a couple years ago before RMW offered it on the US market. Did you make yours? It looks good
I wish I had a lathe to make little parts like that.
Aloha all! |
I know exactly why you have the c channel and it's exactly the way I hold mine to keep it from spinning as well!
I was just suggesting the have the holes drilled in it so that you have more of a length sticking out to the side of the trans so a adjustable wrench wedged in the vice won't be required  |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 7300 Location: Honolulu,Hawaii and France
svenakela Samba Member
Posted: Wed Nov 18, 2015 3:39 pm Post subject: Re: Alika's Syncro transmission work |
| ALIKA T3 wrote: |
Sven, are you up to the lathe challenge for my coolant flange adapter ?
You really think it's gonna be enough of an oil cooler? The weird shape is not gonna make it easy to get a fan to blow air on it :/
Aloha all! |
Yeah, I forgot to check your "drawing by words". D _________________ Vanagon mirror end caps |
furrylittleotter Samba Member
Joined: May 19, 2008 Posts: 1506 Location: West Seattle
Posted: Wed Nov 18, 2015 11:19 pm Post subject: Re: Alika's Syncro transmission work |
Looking good. Forgetting parts does keep us humble....
I agree with Sven. That cooler is perfect. Keep it simple.
Neil2 |
ejimmi Samba Member
Posted: Sun Nov 29, 2015 10:03 pm Post subject: |
Alika, did you end up using this method? I can't tell in the 2nd photo if it is attached to the pipe that goes across.
Posted: Sun Nov 29, 2015 11:32 pm Post subject: Re: Alika's Syncro transmission work |
Hi!
Yes I did, I'm missing a few pics and work to post it:
Here is the line going from the gundrilled mainshaft to the 4th gear oiling port
Redrilled the banjo a little bigger.
It's a stainless steel 8mm line for an Audi 1.8T engine that I cut and bent.
Glued with special compound to a modified round flare and a modified banjo fitting.
I don't have a pic yet of the stud installed, it's basically a gundrilled M10x1.25 bolt on which the hexagonal head has been modified to receive a brazed femalle threaded flare to attach to the nut on the steel line pictured above.
On that stud is a long 10mm IDx18mm OD sleeve from a Subaru belt tensioner roller that got bored partially at 1/2" ID to act as a chamber.
The line from the mainshaft ball bearing oiling port rides across it and will be brazed like a tee on top of the sleeve that will be like a banjo fitting.
The stud will be drilled to be like a banjo bolt.
_________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
Sodo Samba Member
Joined: July 06, 2007 Posts: 10822 Location: Western WA
Posted: Mon Feb 15, 2016 5:36 pm Post subject: Re: Alika's Syncro transmission work |
Alika do you have pics of how you made the groove in your pinion bearing? _________________
....KTMs, GasGas, SPOT mtb |
Posted: Mon Feb 15, 2016 9:05 pm Post subject: Re: Alika's Syncro transmission work |
| Sodo wrote: |
| Alika do you have pics of how you made the groove in your pinion bearing? |
Hey man!
no, I did it with a disc grinder: put some grease on the races to not get them pitted by the sparks. I marked the bearing with a sharpie and I followed the line: one pass to make a slight groove that would guide the disc for the following passes.
Cheers! _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
Doka Todd Samba Member
Joined: January 23, 2014 Posts: 106 Location: Delta, BC
Posted: Fri Feb 10, 2017 11:58 pm Post subject: Re: Alika's Syncro transmission work |
Bringing back an old one...
Alika did you get this up and running? I'm about to embark on case modifications for oiling and am wondering how that bmw assembly worked out. I have access to one and it seems like a slick all around solution.
I've been scouring the forums and you and Sodo are to be thanked for laying this stuff out. Between you guys, Gears, and the well documented efforts of Herman you've made it so much easier for the rest of us. |
Posted: Sun Feb 12, 2017 10:48 pm Post subject: Re: Alika's Syncro transmission work |
| Doka Todd wrote: |
Hi Todd!
thank you for your interest
I haven't mounted the transmission yet as this is for a Syncro I've been building for many years (a conversion to Syncro and to M-Tdi).
I don't have any feedback to offer to you I'm afraid, but some people have voiced concerns on another post about the amperage, something about the pump not able to last if run continuously.
If you need any reduced bushings for in and out fittings for an oil circulation system off the drain/fill plugs, I have them in the classifieds.
I'll finish the plumbing soon on the transmission and will post pictures as time allows.
Aloha and good luck with your project, it's rewarding! _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
Posted: Mon Feb 13, 2017 1:39 am Post subject: Re: Alika's Syncro transmission work |
Thanks Alika. I'm likely going the way of the Exa pump (weddle etc.) as it's a proven part. The BMW setup was so inexpensive comparatively that I really wanted it on the short list.
I've been having some conversations with other members on the direction I'm taking with this rebuild, and as I've said to them, I really need to thank and commend you and the others on the documentation and experimentation you've conducted getting an oiling system to work properly. I have design experience, and am a machinist by trade and am fully aware of the expense of time and money that comes with this trial and error. You guys have made this easy for me, drilling and tapping holes is easy when you know where they need to go. |
Posted: Mon Feb 13, 2017 10:17 am Post subject: Re: Alika's Syncro transmission work |
| Doka Todd wrote: |
You're welcome!
It's our pleasure to share things on the forum, I'm sure you'll find better ideas and improvements as you work on it, that's the way it goes
Lucky you're a machinist, are you for hire? The local ones here suck...
Aloha! _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
Posted: Thu May 11, 2017 4:00 pm Post subject: Re: Alika's Syncro transmission work |
Here is a little update from the work I did a few months ago, I had more pics but I lost my phone
I got some 8mm stainless steel tubing. The manifold-T above theLow gear housing has been machined in France last summer, it is hollow inside, to make a little oil chamber, and the bolt that goes through it is gundrilled and has ports like a banjo bolt. The mini T manifold has smaller ID on the outer edge than the inner edge for machining purposes.
Banjo bolt drilled at 60° , offset on the length to preserve strength
The last pic with the tube bent on the ground goes from the access hole for the pinion bearing oiling port, right side of tranny, above tranny and down to the big rectangular manifold, the rear side of it. The opposite forward entrance of the manifold will be the feed from the pump. The manifold is drilled and tapped bigger on the inlet side for machining purposes to create a chamber.
The big oil dump fitting with the blue tape will have a flex line to the manifold, you cannot see the port but it is horizontal and will go through the black aluminum angle profile that supports it. It will be sandwiched with copper washers, bc the mounting holes were too close to clear the fitting hexagonal part, I screwed up the manifold design, I didn't think of that....
Here is the Syncro diesel gas tank mounted and a view for the clearance above the transmission:
I banged the chassis beam with a sledge hammer to gain a couple precious millimeters for the fitting on the end of my gundrilled mainshaft.
