houseofboyd Samba Member
Joined: September 28, 2014 Posts: 613 Location: Flatwoods, Ky
Posted: Mon Dec 28, 2015 8:04 pm Post subject: To All You Radio Installers, Need Some Guidance |
Ok, my '68 Beetle has never had a radio installed. After months of looking, I found a period correct Ranger by Tenna. This is the radio that would be installed at the dealership for around 80 bucks. This is a NOS radio in new condition, so I'm pleased. I'm no electronics guru, so I'm hoping somebody can help with the install. I know the obvious, black wire from the case is ground, blue wire with inline fuse is the hot wire and the other black wire is the internal light (I'll jump off the speedo light for that)...the thing with the blue wire in the lower right corner of the pic, what is that and where does it go? Any input is appreciated...
_________________ Our 1968 Zenith Blue Beetle: http://www.thesamba.com/vw/forum/viewtopic.php?t=619501
My '74 SB Build On The Samba: http://www.thesamba.com/vw/forum/viewtopic.php?t=609943
Our Web Site: http://www.kentuckyhotwheels.com
1968 VW Beetle
2012 Turbo VW Beetle |
cletus_zuber Samba Member
Joined: January 08, 2010 Posts: 2409 Location: Gladstone, Ore
Posted: Mon Dec 28, 2015 8:46 pm Post subject: Re: To All You Radio Installers, Need Some Guidance |
That is a noise suppressor. I've seen pics of those mounted at the generator, the coil or at the radio itself. Goes inline with the power wire I believe. _________________ 1972 1302
HPMX 40's & 019 |
vwfreek61 Samba Member
Joined: May 31, 2004 Posts: 350 Location: Green Bay, WI
Posted: Mon Dec 28, 2015 8:48 pm Post subject: Re: To All You Radio Installers, Need Some Guidance |
Looks like a noise suppressor for the generator. or ignition. There was one on my Type 3 Squareback bolted to the generator, but I don't remember exactly where the wire was connected. _________________ Kenneth
1964 Bug with Saxomat
1976 VW/Harley Trike Autostick
1987 Vanagon Westy w/Subaru EJ25 and reversed 4EAT |
air-h2o-air Samba Member
Posted: Mon Dec 28, 2015 9:33 pm Post subject: Re: To All You Radio Installers, Need Some Guidance |
try radio without it first...If you dont need the noise choke...leave it off
and if radio is period correct...don't forget to adjust antenna trimmer |
windfish Samba Member
Posted: Mon Dec 28, 2015 9:39 pm Post subject: Re: To All You Radio Installers, Need Some Guidance |
Yep, noise suppressor.
The diagram below suggests it was used to buffer the turn signal, at least for that Sapphire model; that clamp on the end could wrap around the terminal at the relay?
http://www.thesamba.com/vw/archives/manuals/sapphirev/diagram.jpg
I believe I've still got one on my bug, if you're curious I'll follow the wire and see how it's attached. Looks like the above used a split terminal. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31392 Location: Hot Arizona
Posted: Tue Dec 29, 2015 6:47 am Post subject: Re: To All You Radio Installers, Need Some Guidance |
Is that radio just AM like the Saph in my 1970 was? That suppressor may just help for AM stations and not be needed if you do only FM. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Tue Dec 29, 2015 7:17 am Post subject: Re: To All You Radio Installers, Need Some Guidance |
Cusser wrote: |
Is that radio just AM like the Saph in my 1970 was? That suppressor may just help for AM stations and not be needed if you do only FM. |
Yes, just an AM radio. I just got it for aesthetics, but I still want it to work decently...I currently use my phone and bluetooth speaker for tunes when I'm driving around...Going to try it without the suppressor first to see if it's actually needed... _________________ Our 1968 Zenith Blue Beetle: http://www.thesamba.com/vw/forum/viewtopic.php?t=619501
1968 VW Beetle
