EverettB  Administrator
Joined: April 11, 2000 Posts: 71919 Location: Phoenix 602
Posted: Mon Feb 15, 2016 9:05 am Post subject: Forum search on the site and Feb. 2016 update |
As some of you know, the Forums search of the site has been overloading the site from time to time for a while.
On Feb. 14, 2016 I made a big change to how it works.
Unfortunately this does not appear to have helped.
For now I have had to turn off the search and redirect people to a Google Search of the site I set up that will search the Forums only.
This search is accessed via the normal Forums -> Search menu items at the top of the site.
I hope to re-enable the internal Forums search in the future but I have no target date on when that will be possible. _________________ How to Post Photos
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 36356 Location: Conejo Valley, CA
Posted: Mon Feb 15, 2016 7:16 pm Post subject: Re: Forum search on the site and Feb. 2016 update |
| Do we use normal Samba Forum syntax for the search terms, or standard google syntax? |
eche_bus Samba Member
Posted: Mon Feb 15, 2016 8:59 pm Post subject: Re: Forum search on the site and Feb. 2016 update |
Sorry to hear the search update didn't fix the server loading problem. I've been experiencing a lot of long delays and timeouts while browsing the website lately, even just a few minutes ago.
Since we're using Google to search for now, is there a way to tell google to limit itself to within a single sub-forum? |
Posted: Mon Feb 15, 2016 10:31 pm Post subject: Re: Forum search on the site and Feb. 2016 update |
| eche_bus wrote: |
I think it will help if you add "Bay Window" or Vanagon to the search terms.
I tried some searches with "Split Bus" added and it seemed to work.
Example search: oil filter Vanagon _________________ How to Post Photos
Erik G Samba Member
Joined: October 16, 2002 Posts: 13587 Location: Tejas!
Posted: Tue Feb 16, 2016 3:14 pm Post subject: Re: Forum search on the site and Feb. 2016 update |
Much faster!
sucks about the search... do things like [brackets] and -exclude work? doesn't look like it but maybe I'm doing it wrong, it's been a while
for instance timing a 009 for a type 3. I tried 009 [Type 3] but it brings up 13000 posts, type 1, type 2, etc _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
DwarfVader Samba Member
Joined: July 28, 2015 Posts: 646 Location: Missoula, MT
Posted: Tue Feb 16, 2016 7:41 pm Post subject: Re: Forum search on the site and Feb. 2016 update |
Boolean search parameters work using the Google search... They actually make searches for specific info much easier.
http://www.webopedia.com/TERM/B/Boolean_search.html _________________ - oderint dum metuant -
I'll find my van someday, or it will find me. |
BayCreamPuff Samba Member
Joined: August 10, 2015 Posts: 769 Location: Oakland, CA
Posted: Tue Feb 16, 2016 9:10 pm Post subject: Re: Forum search on the site and Feb. 2016 update |
You can use quotes around a string of title characters that only applies to the forum you want to search in.
"Split Bus - View Topic" fuel sender
"Bay Window Bus - View Topic" fuel sender
"Vanagon - View Topic" fuel sender _________________ Cream Puff
'79 CA Stock FI Deluxe Campmobile
Earl Grey
'87 GoWesty 2.2 Westfalia
Marsha Mellow
'00 Eurovan VR6 Full Camper |
Erik G Samba Member
Posted: Wed Feb 17, 2016 8:36 am Post subject: Re: Forum search on the site and Feb. 2016 update |
| BayCreamPuff wrote: |
"Vanagon - View Topic" fuel sender |
thats awesome advice - thanks
searching fpr "Type 3 - View Topic" 009 brings up the correct topics and leaves out all of the other junk types  _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
srfndoc Samba Member
Posted: Mon Feb 22, 2016 9:58 am Post subject: Re: Forum search on the site and Feb. 2016 update |
| EverettB wrote: |
Regarding the comments above:
I made it so if you are searching from within a specific Forum it appends the Forum name and View Topic to help. |
Thanks for doing that, makes it much more useful. _________________ RPM=(MPH*336* (R&P*4th*1.26))/Tire Diameter in inches |
Posted: Wed Feb 24, 2016 10:40 pm Post subject: Re: Forum search on the site and Feb. 2016 update |
Just wanted to say I am working on this and have come up with a new design to use for the Forums search engine.
I changed the Gallery search to use this new format earlier today as a test before I work on doing the same change for the Forums.
If you are the kind of person that does Gallery searches for various terms, please let me know if you have any issues there.
There is a maximum of 5,000 items returned from a search with this new design but I don't think that is an issue.
I doubt anyone would search on something and look through 5,000 photos (or threads).
If that happens to me I usually just scan through a few things and either select a specific category or add more search words to limit my search further.
(Hint, hint)
Update:
Locked as I started a new thread for the new Forums search:
http://www.thesamba.com/vw/forum/viewtopic.php?t=649220 _________________ How to Post Photos
