Our 69 kombi rebuild
ezytroopy
ezytroopy is offline
PostPosted: Fri Feb 26, 2016 3:04 pm    Post subject: Our 69 kombi rebuild Reply with quote
Hello Guys. We are about to restore/rebuild our 69 Kombi. It comes from Condobolin, so its pretty good with rust. Its had a rear end smash at one stage and there is alot of bog thanks to this. The nose cone has been replaced at some stage aswell as its a hi light front. We picked her up already stripped, so lots of stuff is missing. Its not going to be a quick project as I already have a lot of commitments, but I will update as we go.
camit34
camit34 is offline
PostPosted: Fri Feb 26, 2016 3:09 pm    Post subject: Re: Our 69 kombi rebuild Reply with quote
Sounds like an awesome project. Share some pictures when you get a chance.
In search of a Vanagon
1971 Westy (SOLD)
1971 Deluxe (SOLD)
1967 Freedom Camper (SOLD)
1965 Bug (SOLD)
williamM
williamM is offline
PostPosted: Fri Feb 26, 2016 3:50 pm    Post subject: Re: Our 69 kombi rebuild Reply with quote
Find a big stump and some body tools - 16 ga sheet steel and be sure to ask some help here-- (not necessarily that last bit) sounds like a lot of fun- Razz
Where is Condomboling any way
some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any!
ezytroopy
PostPosted: Sat Feb 27, 2016 3:59 am    Post subject: Re: Our 69 kombi rebuild Reply with quote
Central West New South Wales. Australia
Tcash
Tcash is offline
PostPosted: Sat Feb 27, 2016 9:10 pm    Post subject: Number stamped behind chassis number Reply with quote
ezytroopy wrote:
Ive got no M plate. But after the chassis number there is a number stamped MB645? Any ideas? Its an Aussie 69
Tcash
Tcash is offline
PostPosted: Sat Feb 27, 2016 9:15 pm    Post subject: Re: Our 69 kombi rebuild Reply with quote
You may have better luck with the identification by contacting the kombi club in Oz. They where mentioned in the other thread you posted about the M-Plate not being there.
Good luck
Tcash
ezytroopy
PostPosted: Sat Feb 27, 2016 11:25 pm    Post subject: Re: Our 69 kombi rebuild Reply with quote
Got the Kombi out today and hit it with the gurney.All the windows have no rust. A little bit in the front lower steps and the lower front apron. The headlight buckets are rusted through. The section above the engine cover is no good either. The roof is a little damaged, i was told a tree fell on it.
ezytroopy
PostPosted: Sat Feb 27, 2016 11:26 pm    Post subject: Re: Our 69 kombi rebuild Reply with quote
ezytroopy
PostPosted: Sat Feb 27, 2016 11:27 pm    Post subject: Re: Our 69 kombi rebuild Reply with quote
ezytroopy
PostPosted: Sat Feb 27, 2016 11:33 pm    Post subject: Re: Our 69 kombi rebuild Reply with quote
ezytroopy
PostPosted: Sat Feb 27, 2016 11:47 pm    Post subject: Re: Our 69 kombi rebuild Reply with quote
My donor
The power plant
1967250s
1967250s is offline
PostPosted: Sun Feb 28, 2016 1:06 am    Post subject: Re: Our 69 kombi rebuild Reply with quote
Okay. Well, it looks a lot cleaner than some we've seen. And a Scoobaroo on top. Check out the Butty's bits for a better linkage for the gas pedal. lookin' forward to this build! luck.
'72 Elm Green Deluxe
williamM
williamM is offline
PostPosted: Sun Feb 28, 2016 5:53 am    Post subject: Re: Our 69 kombi rebuild Reply with quote
Very Happy looks like good bones to build your "ultimate VW" on- looking forward to more progress potoes
Don't step in any!
Brian
Brian is offline
PostPosted: Sun Feb 28, 2016 10:13 am    Post subject: Re: Our 69 kombi rebuild Reply with quote
I sure hope you disconnected the transmission to the shift rod, else you have a pretty bent shift rod.
Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter
Tcash
Tcash is offline
PostPosted: Sun Feb 28, 2016 1:09 pm    Post subject: Re: Our 69 kombi rebuild Reply with quote
You need to put a strap on the transmission to support it. Right now it is resting on the shift coupler. This can bend the coupler, shifter shaft, trans gear selector shaft.
bent coupler on the right
Good luck
Tcash
Tcash
Tcash is offline
Good luck
Tcash
Shifter Parts ID
ezytroopy
PostPosted: Sun Feb 28, 2016 3:29 pm    Post subject: Re: Our 69 kombi rebuild Reply with quote
Its being changed out to an auto so my family can drive her aswell
ezytroopy
PostPosted: Sun Feb 28, 2016 4:55 pm    Post subject: Re: Our 69 kombi rebuild Reply with quote
Its been hanging like that since forever by the look. The motor was in the back when i picked it up. The damage is most likley well and truly done Sad
ezytroopy
PostPosted: Sun Mar 27, 2016 7:40 pm    Post subject: Re: Our 69 kombi rebuild Reply with quote
Picked up this. Its in great nik.
The old bus must have been a little unreliable. The old owner had a light in the engine bay Wink
ezytroopy
PostPosted: Sat Aug 20, 2016 11:44 pm    Post subject: Re: Our 69 kombi rebuild Reply with quote
Its been awhile. I finally turned the bus around in the garage. Went to remove the cv joints/shafts to remove the gear box. The heads of the bolts are solid with red dirt. Ive given them a good soak, so ill let it sit till i get another chance. Got the engine mount adapters from Subarugears. Want to get the motor and auto conversion done now Smile
