jwallis Samba Member
Posted: Thu Mar 10, 2016 6:09 pm Post subject: Fixed I hope - transmission, differential won't go back together |
I have the two halves together, hopefully correctly. Thank you very much to everyone who jumped in.
-------original message:--------
I've been trying wrestle these two back together for about three hours now. first on a flat plane now but using a hoist the way Bentley says to do it, transmission on the bottom.
It is extremely close just about to hit the O-ring on the outside with the yellow stripe. It is a hard stop. and when I separate them again there is a little bit of flake looks like brass.
Is there some trick does the transmission need to be in neutral or something like that?
Any help is greatly appreciated. I am about to lose it. _________________ 50+ YouTube videos - brakes, bearings, CV joints, 1.9/2.1 cooling system, mods, Bostig and more...
Posted: Thu Mar 10, 2016 6:18 pm Post subject: Re: Please help - transmission, differential won't go back together |
is the outer shaft here supposed to spin? maybe it's not mating with the splines in the transmission? That's what I'm guessing that I cannot get that shaft to turn[/img] _________________ 50+ YouTube videos - brakes, bearings, CV joints, 1.9/2.1 cooling system, mods, Bostig and more... |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10357 Location: N. Idaho
Posted: Thu Mar 10, 2016 6:43 pm Post subject: Re: Please help - transmission, differential won't go back together |
I just went out to look at my spare trans. I cannot turn the outer shaft, either. However, the inner shaft of mine does not stick out like yours does. It is pretty much flush with the larger shaft. So, perhaps someone else can weigh in on the position of that inner splined shaft. I also assume you have the solid shaft that goes inside the inner splined shaft out of the picture for some reason?
PS - that big chain may be part of your problem....heh.... _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1993 Toyota LandCruiser, 2002 BMW 325iX, 1982 Toyota Sunrader |
Posted: Thu Mar 10, 2016 6:53 pm Post subject: Re: Please help - transmission, differential won't go back together |
Good question about the chain but it's not exerting any lateral force. That interior shaft is loose, so it would not prevent mating... _________________ 50+ YouTube videos - brakes, bearings, CV joints, 1.9/2.1 cooling system, mods, Bostig and more... |
Posted: Thu Mar 10, 2016 6:55 pm Post subject: Re: Please help - transmission, differential won't go back together |
Actually I was joking that the chain is laying across the mating surface = no way it's mating.
So, the inner shaft - does it easily move until its flush? And what about my question about the solid inner, inner shaft? Where is yours? _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1993 Toyota LandCruiser, 2002 BMW 325iX, 1982 Toyota Sunrader |
Posted: Thu Mar 10, 2016 7:03 pm Post subject: Re: Please help - transmission, differential won't go back together |
oh I didn't see that question - that shaft is out because it will just fall out if you hold the differential vertical _________________ 50+ YouTube videos - brakes, bearings, CV joints, 1.9/2.1 cooling system, mods, Bostig and more... |
Posted: Thu Mar 10, 2016 7:05 pm Post subject: Re: Please help - transmission, differential won't go back together |
Just to be real clear about that picture that's the side that goes to the engine.
The inner shaft in the picture is basically loose as well but it will not fall out. I was planning on getting the mated and then seating that one _________________ 50+ YouTube videos - brakes, bearings, CV joints, 1.9/2.1 cooling system, mods, Bostig and more... |
kourt Samba Member
Joined: August 13, 2013 Posts: 2323 Location: Austin, TX
Posted: Thu Mar 10, 2016 7:07 pm Post subject: Re: Please help - transmission, differential won't go back together |
Howdy,
If you can't get it together by Sunday, PM me and I'll come over and have a look. Two heads are better than one. I've mated diff+tranny about six times so I have some experience. Have a beer chilled for me.
BTW see this post:
http://www.thesamba.com/vw/forum/viewtopic.php?p=7989275&highlight=#7989275
Looks like your turbine shaft is out too far. Read farther down in that thread for help on how to seat it.
kourt |
AtlasShrugged Samba Member
Joined: October 30, 2008 Posts: 1605 Location: Decatur, Ga. USA
Posted: Thu Mar 10, 2016 7:57 pm Post subject: Re: Please help - transmission, differential won't go back together |
That center shaft should be able to spin while the trans and diff are put together.
As I recall..you need to turn that center shaft to help the assembly go together..don't leave it till after the final assembly..it needs to be installed and ready to go to help spin the automatic transmission while you connect the diff.
Last edited by AtlasShrugged on Thu Mar 10, 2016 8:00 pm; edited 1 time in total |
Posted: Thu Mar 10, 2016 7:59 pm Post subject: Re: Please help - transmission, differential won't go back together |
kourt wrote: |
Howdy,
BTW see this post:
kourt |
I may take you up on that. I will look at that thread. _________________ 50+ YouTube videos - brakes, bearings, CV joints, 1.9/2.1 cooling system, mods, Bostig and more... |
Posted: Thu Mar 10, 2016 8:02 pm Post subject: Re: Please help - transmission, differential won't go back together |
AtlasShrugged wrote: |
As I recall..you need to turn that shaft to help the assembly go together.. |
The small solid one is basically loose until you mate them again. The middle (center in that pic) rotates if you rotate the axles, whatever you want to call them, in the same direction. The biggest outer one does not rotate, which is a little surprising, but sound like normal. I tried to see if the splines showed wear as if I was knocking them together am smearing them but they show no wear. i imagine they're very hard steel. of course when I'm trying to mate them I'm jiggling the diff quite a bit to try to line the splines up. _________________ 50+ YouTube videos - brakes, bearings, CV joints, 1.9/2.1 cooling system, mods, Bostig and more... |
Posted: Thu Mar 10, 2016 8:28 pm Post subject: Re: Please help - transmission, differential won't go back together |
I guess my main question is - is there a trick? It's not sounding like it and I would not expect there to be one. It def sounds like a solid THONK when I get very close. The housings just barely overlap.
I'm guessing that forcing it is both a bad idea and impossible (due to the solidness of the blockage).
thanks again. i probably haven't been this frustrated since I did the fuel lines 4 years ago. _________________ 50+ YouTube videos - brakes, bearings, CV joints, 1.9/2.1 cooling system, mods, Bostig and more... |
fraggle00 Samba Member
Joined: October 19, 2011 Posts: 356 Location: Bristow, VA
Posted: Thu Mar 10, 2016 8:42 pm Post subject: Re: Please help - transmission, differential won't go back together |
Are you sure the middle hollow shaft is in correctly? It can be flopped in backwards and things barely do/don't fit. I know because I did that, made it fit, and later regretted it. _________________ '91 Vanagon Carat
'87 Porsche 928S4 DOWN
'12 Fiat 500 Abarth |
alaskadan Samba Member
Joined: January 09, 2013 Posts: 1937 Location: anchor pt. alaska
Posted: Thu Mar 10, 2016 10:27 pm Post subject: Re: Please help - transmission, differential won't go back together |
Just went through this a few weeks ago. IIRC the inner shaft had slid out and i was able to grab the end of it and jiggle it whilst twisting and pushing and got the inner end to line up and it slid in . |
Posted: Thu Mar 10, 2016 11:20 pm Post subject: Re: Please help - transmission, differential won't go back together |
fraggle00 wrote: |
Are you sure the middle hollow shaft is in correctly? It can be flopped in backwards and things barely do/don't fit. I know because I did that, made it fit, and later regretted it. |
wow, i'm 99% sure, but i will check to make sure. thanks- _________________ 50+ YouTube videos - brakes, bearings, CV joints, 1.9/2.1 cooling system, mods, Bostig and more... |
Posted: Thu Mar 10, 2016 11:22 pm Post subject: Re: Please help - transmission, differential won't go back together |
alaskadan wrote: |
i'm pretty sure it isnt the inner shaft thats binding but i will try this. ive been thinking it must be the big outer one but well see. _________________ 50+ YouTube videos - brakes, bearings, CV joints, 1.9/2.1 cooling system, mods, Bostig and more... |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 18770 Location: Retired South Florida
Posted: Fri Mar 11, 2016 8:14 am Post subject: Re: Please help - transmission, differential won't go back together |
In the bellhousing, the outer splined piece is the stator support and is fixed. It does not come into play until the torque convertor is installed.
Is there a trick? I would suggest looking at 38.5 in the manual. The pinion shaft has splines that need to seat into the automatic clutch drums. While you are trying to mate the pinion shaft to the automatic, grab both cv flanges and turn them together. This will help to align the pinion shaft splines into the drums.
While you are in the manual, in that section, it would be a good idea to measure the final drive endplay. Good luck. |
Posted: Fri Mar 11, 2016 8:37 am Post subject: Re: Please help - transmission, differential won't go back together |
MarkWard wrote: |
In the bellhousing, the outer splined piece is the stator support and is fixed. It does not come into play until the torque convertor is installed. |
ok that makes sense, that outer shaft would be the drive the engine is supplying to the transmission, then the transmission supplies drive to the diff through the pinion shaft... ? german engineering.
if that out shaft is difficult/impossible to turn with the pieces separated, I'm afraid the piece it mates to in the transmission may have turned.
with a crappy night's sleep and newish eyes i'm going back in. i'll let you all know how it goes.
thanks for everyone's help. _________________ 50+ YouTube videos - brakes, bearings, CV joints, 1.9/2.1 cooling system, mods, Bostig and more... |
Posted: Fri Mar 11, 2016 9:01 am Post subject: Re: Please help - transmission, differential won't go back together |
jwallis wrote: |
if that out shaft is difficult/impossible to turn with the pieces separated, I'm afraid the piece it mates to in the transmission may have turned. |
The outer shaft is just a fixed stub, it doesn't mate with anything inside the differential or transmission. |
Posted: Fri Mar 11, 2016 10:34 am Post subject: Re: Please help - transmission, differential won't go back together |
Wildthings wrote: |
jwallis wrote: |
I should have been more clear. The splines on the fixed stub insert into the torque convertor. They are part of how the torque convertor works internally. All transmissions I am familiar with have a similar part. It holds section in the torque convertor while the other parts whirl around inside of the torque convertor. I am not qualified to explain how a torque convertor actually works, but I do know, part of the convertor needs to be "stationary" for it to do it's job. The torque convertor support bushing also rides on this stub. |
