Chop and weld Tie rods? or cut more threads? what to do!?
Page: Previous  1, 2
Doodoob
Doodoob is offline
PostPosted: Thu Sep 15, 2011 7:39 am    Post subject: Reply with quote
What is the thread pitch for the RH Tie Rod Ends? I can get 14MM taps for 10$ but not sure if I need the 1.25 or the 1.50??????
Michael Fischer
Michael Fischer is offline
PostPosted: Thu Sep 15, 2011 11:20 am    Post subject: Reply with quote
Thread pitch is 1.50.
Doodoob
Doodoob is offline
PostPosted: Thu Sep 15, 2011 12:52 pm    Post subject: Reply with quote
Thanks!
Sanders23
Sanders23 is offline
PostPosted: Fri Dec 07, 2012 4:47 pm    Post subject: Why the slot Reply with quote
Found this to be a great write up but an curious as to what make the slot important? why not just weld the first bolt to the end of the tie rod? And of course tap the tube. Mostly why the slot?
Anders
2 64 Sunroof Bug's
1 65 Bug
www.HomeRestorationsInc.com
goualon69
goualon69 is offline
PostPosted: Thu Jan 01, 2015 3:29 pm    Post subject: Re: Why the slot Reply with quote
Anders
Want to kow too!
Adam91
Adam91 is offline
PostPosted: Thu Jan 01, 2015 3:35 pm    Post subject: Reply with quote
When I've done this I have cut the middle and taken a sway bar from a beetle and cut it up to fit inside and weld to that. The sway bar piece you cut will fit perfectly inside the tie rod.
View user's profile Send private message Facebook Twitter Instagram Gallery Classifieds Feedback
Abscate Premium Member
Abscate is offline
PostPosted: Thu Jan 01, 2015 3:46 pm    Post subject: Re: Why the slot Reply with quote
Anders
The slot allows the clamp to squeeze the threads and prevent the tie rid from twisting in the ends(and screwing your alignment). Without the slot, the clamp would just squeeze the tube and the threads would be free to move.
buggin65
buggin65 is offline
PostPosted: Thu Jan 01, 2015 7:30 pm    Post subject: U Reply with quote
I agree with your engineering principle but you need to consider the application. We are not talking aircraft, we are talking air cooled vw's with forty year old safety technology anyway. You are in a tin can at 70 mph, your gas tank is in front of you and you are worried about tie rods flexing? Moto did a more than adequate job of splicing, measuring, and sharing what was learned.
All that aside, I bet you that joint is stronger than the rest of the rod because of the bolt inserted. Sure, takes longer but saves money and time no need to order tap.
EMPIImp69
EMPIImp69 is offline
PostPosted: Thu Mar 17, 2016 6:20 pm    Post subject: Re: Chop and weld Tie rods? or cut more threads? what to do!? Reply with quote
I can do either the cut/weld or tap one end method easily for my 3.5" beam. but I need new tie rods and tierod ends. Does it make sense to buy pre-shortened tie-rods with new tie rod ends or is it much cheaper to buy stock ones and shorten them myself? Thx
1963 Ragtop Bug
1966 Vert Bug
Check out my ads, Thanks!
slalombuggy
slalombuggy is offline
PostPosted: Thu Mar 17, 2016 9:09 pm    Post subject: Re: Chop and weld Tie rods? or cut more threads? what to do!? Reply with quote
Buy them and cut and thread them yourself. I don't know about where you live, but if a car is found with non-factory welded steering parts it gets yanked off the road and has to go for a certification inspection. I would never weld tie rods together and it's way easier to just cut and thread them, takes me less than 10 minutes to do one.
brad
EMPIImp69
PostPosted: Fri Mar 18, 2016 8:08 am    Post subject: Re: Chop and weld Tie rods? or cut more threads? what to do!? Reply with quote
brad
Thanks yea that's what I'll be doing. I already have the tap anyway.
1963 Ragtop Bug
1966 Vert Bug
marklee
marklee is offline
PostPosted: Sat Mar 19, 2016 3:46 am    Post subject: Re: Chop and weld Tie rods? or cut more threads? what to do!? Reply with quote
in the UK, welding tie rods will result in an annual inspection fail....
CGLI qualified body repair and refinish tech
CGLI qualified motor repair tech
Qualified automotive Glass installer
Motor Insurance Repair and Research Centre,Thatcham, Advanced Vehicle Damage Estimator.
Police qualified vehicle examiner
Police Class 1 High performance, pursuit trained Advanced driver
EMPIImp69
PostPosted: Tue May 17, 2016 4:53 pm    Post subject: Re: Chop and weld Tie rods? or cut more threads? what to do!? Reply with quote
If the below is for a 4" beam. How much am I removing for a 3" beam 7/8"-1" off each tirerod? Thanks
For a 4" Narrowed Front End:
Remove - 1 3/16" to 1 1/4" for the short Tie Rod
Remove - 1 1/4" to 1 5/16" for the long Tie Rod
Overall Dimensions after cutting -
Short Tie Rod - 7 7/8"
Long Tie Rod - 22 5/16"
1963 Ragtop Bug
1966 Vert Bug
Dr OnHolliday
Dr OnHolliday is offline
PostPosted: Thu May 19, 2016 4:46 pm    Post subject: Re: Chop and weld Tie rods? or cut more threads? what to do!? Reply with quote
Regarding flexing tie rods, I'm sure you all know that standard off road practice is to either reinforce the stock tie rods with added internal rod (sway bar) or sleeved on the outside with tubing...not much flexing going on there...especially when coupled with a shorter tie rod lengths...and it works fine in an abusive off road application that tests everything well beyond street use.
The next step up off-road wise, is using larger than stock tie rod ends and larger, stronger tubing for the tie rods.
Regarding welded components and nanny states - if the part is welded "fat" and carefully ground down and painted - who can tell??
1965 Type 1 sunroof Baja / about 70k miles on self-rebuilt '74 1600 and counting / SP heads and aftermarket valve keepers / non-doghouse shroud with external cooler and filter / 1.5 qt extended sump / Weber 32/36 DFAV progressive carb / 009 dist with Pertronix / 1.25 ratio rockers and ball adjusters / 1.5" stainless steel J-pipes and carbon steel baja exhaust
Page: Previous  1, 2
Page 2 of 2
