EverettB  Administrator
Joined: April 11, 2000 Posts: 72020 Location: Phoenix 602
ulme2004 Samba Member
Joined: September 23, 2006 Posts: 5 Location: Germany
Posted: Sat Mar 26, 2016 6:26 am Post subject: Re: Splitcase Gearbox help... |
Thank you - EverettB for the late-1957 -information
The leading N seems to stay a mystery..... |
Huetti_1989 Samba Member
Joined: February 13, 2011 Posts: 1395 Location: Austria
djfordmanjack Samba Member
Joined: June 15, 2009 Posts: 2412 Location: Graz, Austria, Europe
Posted: Tue Mar 27, 2018 12:52 pm Post subject: Re: Splitcase Gearbox help... |
Does it have reduction gear boxes on the axles, Christian ?
if the tri rib '29#' shift cover with the low shift rod input is original to the gear case it means that it is a 1953 to 1955 synchromesh ( except first gear) genuine Barndoor unit.
also this front (nose) cover will not fit on an early (non synchro) split bug without heavy modifications. so chances are good that the whole transmission is late BD. oil filler plug says so as well.
the date code 7 6 25 makes it a June 7th of 2nd workshift 1955. which of course is not a Barndoor anymore. but its still an early Wolfsburg ( post BD) date, and these 1955 buses still had the old axle and transmission cradle like a BD.
so most probably this transmission is a straight fit for your 54BD, but originally came in a very early non BD 1955 Wolfsburg bus. _________________ Hotrods, Fords, Veedubs and Triumph Twins !
54 Oval project
62 Dickholmer, Seeblau L360
67 1500 Käfer, og paint Lotus weiß L282 w/red interior |
Justin Horgan Samba Member
Posted: Tue Jan 26, 2021 5:17 pm Post subject: Re: Splitcase Gearbox help... |
| On my split box casing it has the following stamps , 111.301.101A with the VW logo. Any idea which year this gearbox is from ? Thanks |
Posted: Tue Jan 26, 2021 6:11 pm Post subject: Re: Splitcase Gearbox help... |
| Justin Horgan wrote: |
This is the part # of the casing.
Looks for a "2A-" serial number on the side, either near the nose cone or on a raised area a little behind the nose cone but on the side.
Example from earlier in this thread:
_________________ How to Post Photos
Posted: Thu Jan 28, 2021 4:41 am Post subject: Re: Splitcase Gearbox help... |
| Is the 2A stamping on the nose cone or on the gearbox casing ? I have found the following stamps on the nose cone 21.09.2 , I assume this is a part number, thanks |
Posted: Thu Jan 28, 2021 6:22 am Post subject: Re: Splitcase Gearbox help... |
the 21.*** is the cast part number on the nose cone.
you want to look for a stamped number on the case behind the nose cone .
54 Oval project
Posted: Thu Jan 28, 2021 11:18 am Post subject: Re: Splitcase Gearbox help... |
On the side of the casing.
Maybe this is a better pic, also from page 1 of this thread:
Nosecone at the top of the photo above _________________ How to Post Photos
Posted: Thu Jan 28, 2021 5:31 pm Post subject: Re: Splitcase Gearbox help... |
| Thanks for your help gentlemen. I will try and post photos tomorrow of my gearbox . I don’t see any 2A stamping on the gearbox casing. It does come complete with its reduction boxes. |
ron miche Samba Member
Joined: September 27, 2014 Posts: 43 Location: Peer (Belgium)
Posted: Mon Nov 11, 2024 12:38 pm Post subject: Re: Splitcase Gearbox help... |
| ulme2004 wrote: |
Hallo, I need help in determination the model-year relation
of my barn find splitcase gearbox.
It seems to fit to a 58 T2 kombi
But is it an earlier gearbox? Which model year exactly?
The number is N 2A 1458901
what means N?
Regards Andreas
I also have a 57 gearbox with the N2 number
I also wondering what it means.
fmulon Samba Member
Joined: August 22, 2007 Posts: 26 Location: Montpellier france
Posted: Wed Mar 19, 2025 11:53 am Post subject: Re: Splitcase Gearbox help... |
hi i have a gears box BD (for sale )number 2A-3822207 someone could confirm me its january 1955 please?
many thanks |
Posted: Wed Mar 19, 2025 4:31 pm Post subject: Re: Splitcase Gearbox help... |
| fmulon wrote: |
many thanks |
On the VIN charts on the site, the last transmission # for 12/1954 is:
2A-380 323
So I think your transmission is from 1/1955 if it has 1 less digit, maybe its:
2A-382 207 _________________ How to Post Photos
RockStock Samba Member
Joined: November 26, 2004 Posts: 4255 Location: England
Posted: Thu Mar 20, 2025 6:59 am Post subject: Re: Splitcase Gearbox help... |
_________________ -StockRocks- |
