WendyArmbuster Samba Member
Joined: March 03, 2006 Posts: 349 Location: Springfield, MO
Posted: Sat Apr 09, 2016 7:18 pm Post subject: Exhaust stud thread chasing |
What tool would a person use to clean up the threads of an exhaust stud? I've got one that has a rough spot, but of course there isn't enough space for a standard die to fit in there. _________________ Brian Z
1978 Westfalia |
wcfvw69 Samba Purist
Posted: Sat Apr 09, 2016 7:25 pm Post subject: Re: Exhaust stud thread chasing |
I'd use a thread file. They sell them in different sizes to match the thread pitch. _________________ Contact me at [email protected]
The Samba member since 2004.
old DKP driver Samba Member
Joined: March 30, 2005 Posts: 4145 Location: Los Gatos,Ca.
Posted: Sat Apr 09, 2016 8:06 pm Post subject: Re: Exhaust stud thread chasing |
You can also make your own 'cutting oil mix' with engine oil and pb blaster
and use a brand new nut or 2 as a die and go slowly through the damaged
threads back and forth until the bad threads are cleaned up.
Coat the stud with the mix and continue to do so as you move upward
as I assume the head is still on the engine. _________________ V.W.owner since 1967 |
Brian Samba Moderator
Posted: Sat Apr 09, 2016 8:32 pm Post subject: Re: Exhaust stud thread chasing |
Thread file if it's real bad, as Bill said. I spent an hour with a die on an exhaust stud once. Nicest stud I've seen to date, you're welcome Robbie.
And yes, definitely agree on making some oil. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4855 Location: Kaneohe
Posted: Sat Apr 09, 2016 9:59 pm Post subject: Re: Exhaust stud thread chasing |
I have used a small triangular file to cut a slot in the threads of a new nut and used that to clean up the threads on a stud. The rust from the stud collects in the slot and prevents galling. You have to use some lubricant, turn it back and forth, go only a bit at a time, and clean out the groove with a small wire brush. Tedious, but it works well and doesn't damage the stud or try to start new threads like a die might.
Aloha
tp |
Posted: Sun Apr 10, 2016 6:19 am Post subject: Re: Exhaust stud thread chasing |
Or, double nut the stud if it's really bad. Unscrew the stud from the head and install a new one. _________________ Contact me at [email protected]
Tcash Samba Member
Joined: July 20, 2011 Posts: 12846 Location: San Jose, California, USA
Posted: Sun Apr 10, 2016 8:42 am Post subject: Re: Exhaust stud thread chasing |
Thread Chaser
http://www.sears.com/craftsman-48-pc-sae-metric-th...lsrc=aw.ds
Or make one out of a nut. File a groove in the nut and run a tap through it to clean up the threads. Then use the nut to chase the threads.
This is a bolt, but will give you the idea.
Good luck
Tcash |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 13530 Location: West Coast, USA
Posted: Sun Apr 10, 2016 7:53 pm Post subject: Re: Exhaust stud thread chasing |
Brian wrote: |
Um, you spent an hour and a half on that exhaust stud.
Robbie _________________ One-on-one tech help for your vintage Volkswagen:
www.airschooled.com
https://www.patreon.com/airschooled |
Posted: Sun Apr 10, 2016 11:05 pm Post subject: Re: Exhaust stud thread chasing |
Pretty hard to use a thread file if the damage is not visible on the stud and usually this would happen when pulling the F-pipe or heat exchanger off
Unless you have a thread file that goes around the stud like a rubber band.  _________________ V.W.owner since 1967 |
Little Steve Samba Member
Posted: Mon Apr 11, 2016 4:57 am Post subject: Re: Exhaust stud thread chasing |
I vote for replacing the stud if you can get it out all the way. Might not be able to unthread all the way out if it's the 40mm long version behind the J pipe. If in the back no problem with the header pipes off. |
