speedystar77 Samba Member
Joined: June 26, 2015 Posts: 76 Location: South Central Idaho
Posted: Sun Apr 10, 2016 8:43 pm Post subject: Distributor Id help and cap recommendation |
I believe this to be a SVDA distributor with electronic ignition (but not Pertronix brand). The cap looks to me like a Bosch cap.
The cap fit feels sloppy to me, like it doesn't mate snuggly to the distributor.
Is there a better cap for this distributor?
Thanks in advance. _________________ 1974 Baywindow Westfalia Bus
Tintop Campmobile
Production date: November 29, 1973
1700 cc engine with manual transmission
32/36 DFEV Weber Progressive |
wcfvw69 Samba Purist
Posted: Sun Apr 10, 2016 8:47 pm Post subject: Re: Distributor Id help and cap recommendation |
Are there any numbers on the side of the distributor? Most of those SVDA copies use the same caps as the DVDA distributors, 03010 is the short Bosch number. _________________ Contact me at [email protected]
The Samba member since 2004.
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80529 Location: Sneaking up behind you
Posted: Mon Apr 11, 2016 6:19 am Post subject: Re: Distributor Id help and cap recommendation |
Its a Hot spark module and the cap is not Bosch. Looks like the Bosch 03 010 cap will fit. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Posted: Mon Apr 11, 2016 6:35 am Post subject: Re: Distributor Id help and cap recommendation |
| wcfvw69 wrote: |
| Are there any numbers on the side of the distributor? Most of those SVDA copies use the same caps as the DVDA distributors, 03010 is the short Bosch number. |
There are no numbers visible on the side that I can see (without removing it anyway).
Thanks guys. _________________ 1974 Baywindow Westfalia Bus
Tintop Campmobile
Glenn  Mr. 010
Posted: Mon Apr 11, 2016 7:23 am Post subject: Re: Distributor Id help and cap recommendation |
| speedystar77 wrote: |
[(without removing it anyway).
Thanks guys. |
Use a mirror  _________________ Glenn
Member #1009
#BlueSquare
Joined: April 27, 2002 Posts: 6869 Location: Pentwater, Michigan
Posted: Mon Apr 11, 2016 5:38 pm Post subject: Re: Distributor Id help and cap recommendation |
Bosch caps don't have those 90* intersecting lines. As above 03010 caps is what's needed. _________________ Roads Scholar
Member# 2059 |
