stanleyvanagon Samba Member
Posted: Fri Apr 15, 2016 6:30 pm Post subject: Removing Fan Hub- No puller- 81 AC Vanagon |
Can anyone explain what is going on in this picture? I am trying to read up on how to remove my fan hub without a puller, this seems to be the answer but I can't really tell exactly what is going on.
Anyone wanna explain it to me...any other methods?
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32988 Location: Reading Pennsylvania
Randy in Maine Samba Member
Posted: Sat Apr 16, 2016 4:51 am Post subject: Re: Removing Fan Hub- No puller- 81 AC Vanagon |
| You will soon find out why a gear puller is such a good $25 investment. |
Posted: Sat Apr 16, 2016 7:48 am Post subject: Re: Removing Fan Hub- No puller- 81 AC Vanagon |
Steering wheel/harmonic balancer puller actually. AutoBone will let you borrow theirs.
As you start to put pressure on it, give that center a good rap with a hammer and punch.
http://www.harborfreight.com/Bolt-Type-Wheel-Puller-Set-69889.html |
windnsea Samba Member
Joined: May 07, 2008 Posts: 424 Location: Pasadena, CA
Posted: Sat Apr 16, 2016 9:46 am Post subject: Re: Removing Fan Hub- No puller- 81 AC Vanagon |
It appears the engine is out of the vehicle. Are you going to fully disassemble it? The reason that I ask is that in your pics you are pulling against the engine case. In reality, IIRC, you are actually pulling against the thrust bearing surface inside the engine. If you are going for a rebuild and will be replacing this bearing, then no problem; if not, you might want to go the gear puller route.
I've always soaked hard to release bushings by soaking with penetrating oil overnight and then heating up the outer collar with a heat/hair gun to expand the metal just a little little bit.
...got to get it ready for the late spring/summer trips! |
Posted: Sat Apr 16, 2016 10:52 am Post subject: Re: Removing Fan Hub- No puller- 81 AC Vanagon |
I wanted one for our winter place and just picked up one at a yard sale for a dollar. Not much excuse for not having this tool. |
Posted: Sun Apr 17, 2016 12:38 pm Post subject: Re: Removing Fan Hub- No puller- 81 AC Vanagon |
| Thanks, this technique actually worked quite well, slow even turns against a steep plate and the hub came out easily....and yes, I'm doing a full rebuild and will be putting in a new oil seal. |
