Wierdest turn signal issue ever...
mattlockwood
mattlockwood is offline
PostPosted: Thu Mar 31, 2016 3:29 pm    Post subject: Wierdest turn signal issue ever... Reply with quote
1970 Bay...
Turn signals, hazards, work great as theyre supposed to. Actual lights are blinking and the turn signals on the dash blink together.
However, with the ignition in the 'Run' position, the blinkers work, but I get no blinkers on the dash. When I use the hazard light, same thing: actual lights are blinking, but no signals blinking on the dash..
Any ideas?
1970 Bay Window Bus.
110 hp 6 cyl Aircooled automatic
busdaddy
busdaddy is offline
PostPosted: Thu Mar 31, 2016 3:39 pm    Post subject: Re: Wierdest turn signal issue ever... Reply with quote
First click on control panel at the very top left of the page, then scroll down to the bottom where it says signature line, now type the model and year of your bus in there and click apply.
Слава Україні!
Tcash
Tcash is offline
PostPosted: Thu Mar 31, 2016 6:01 pm    Post subject: Re: Wierdest turn signal issue ever... Reply with quote
click on pic
busdaddy
busdaddy is offline
PostPosted: Thu Mar 31, 2016 7:08 pm    Post subject: Re: Wierdest turn signal issue ever... Reply with quote
Ahhhh...., thanks for adding that, so many different signal circuits it's impossible to cover issues with a blanket fix. Start by counting the terminals on your flasher, if it's the OG one it likely has 4, if it's a replacement it's probably got 2 or 3, Kbl needs to be piggybacked on 49a if it has less than 4, or your OG 4 terminal relay has issues internally.
All this assumes your fuel gauge and idiot lights work normally.
Слава Україні!
mattlockwood
PostPosted: Mon May 09, 2016 1:47 pm    Post subject: Re: Wierdest turn signal issue ever... Reply with quote
So I fixed my fuel gauge issues, all idiot lights working..
Replaced my aftermarket 4 prong flasher with a new one just in case..
Same issues: blinkers and flashers work fine , just no lights on the instrument cluster while key is in "run" position. Instrument blinkers work fine in the "acc" position.,,
skills@eurocarsplus
Samba Peckerhead
PostPosted: Mon May 09, 2016 2:00 pm    Post subject: Re: Wierdest turn signal issue ever... Reply with quote
there is no "acc" position...off, on, start is how all bus switches work. do you have some sort of aftermarket switch?
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
mattlockwood
PostPosted: Mon May 09, 2016 9:30 pm    Post subject: Re: Wierdest turn signal issue ever... Reply with quote
My bad- "on" not "acc"
busdaddy
busdaddy is offline
PostPosted: Mon May 09, 2016 9:38 pm    Post subject: Re: Wierdest turn signal issue ever... Reply with quote
So then what's the difference between "run" and "on"?
Слава Україні!
mattlockwood
PostPosted: Tue May 10, 2016 6:34 am    Post subject: Re: Wierdest turn signal issue ever... Reply with quote
Sorry: wasn't clear and had it wrong:
Key out or "off": hazards are blinking and lights blinking on dash
Key in and turned at least one position to the right: hazards blinking and lights blinking on the dash
Key turned two positions to the right: hazards blink but no blinkers on dash- all idiot lights on and fuel gauge indicating fuel level.
Also- turn signals work but no lights on dash
kreemoweet
kreemoweet is offline
PostPosted: Tue May 10, 2016 12:49 pm    Post subject: Re: Wierdest turn signal issue ever... Reply with quote
Two positions to the right would be "Start". Don't know why the dash indicator lites aren't coming on, but why would you care?
Ordinarily, for the few seconds the key would be in that position, the starter is running and drawing enormous current, causing
the system voltage to drop way low. Maybe too low for the flasher relay to operate.
Still with the aftermarket flasher relay? Did you wire it up as busdaddy suggested above?
'67 bug: seized by the authorities
mattlockwood
PostPosted: Tue May 10, 2016 1:05 pm    Post subject: Re: Wierdest turn signal issue ever... Reply with quote
Oh my goodness:
Trava : hazards blink and indicate on dash
Desl: hazards blink and indicate on dash
Lig: hazards blink but do not indicate on dash. Blinkers blink but do not indicate on the dash
Partida: start position- not concerned about the lighting
I did wire the flasher as BD mentioned: basically did a one for one wire swap from OG relay to new 4 prong aftermarket one
busdaddy
busdaddy is offline
PostPosted: Tue May 10, 2016 1:24 pm    Post subject: Re: Wierdest turn signal issue ever... Reply with quote
So the Kbl wire is piggybacked on to terminal #49a?
Слава Україні!
mattlockwood
PostPosted: Tue May 10, 2016 1:47 pm    Post subject: Re: Wierdest turn signal issue ever... Reply with quote
No- I wired each corresponding to its match on the aftermarket. KbL went to K1, which seemed logical..
Tom Powell
Tom Powell is offline
PostPosted: Tue May 10, 2016 2:38 pm    Post subject: Re: Wierdest turn signal issue ever... Reply with quote
We need a Spanish or Portuguese translator for the ignition switch.
I found this:
"partida ... departure (act of departing)
start (beginning point of a race)"
Not a three position OG switch: OFF, ON, START
Possibly Spanish or Portuguese switch and a wiring diagram specifically for a Mexican or Brazilian bus would be appropriate.
Aloha
tp
Starbucket
Starbucket is offline
PostPosted: Tue May 10, 2016 3:02 pm    Post subject: Re: Wierdest turn signal issue ever... Reply with quote
The new after market flasher units HAVE to have 21 Watt max bulbs F&R to work right. WolfsburgWest part # N177322 (single element) and N177372 (dbl element) $1.70 each.
mattlockwood
PostPosted: Tue May 10, 2016 3:18 pm    Post subject: Re: Wierdest turn signal issue ever... Reply with quote
thanks. I'm actually talking about the blinker INDICATORS on the dash, not the external lights....the external lights work great .
Starbucket
PostPosted: Tue May 10, 2016 3:44 pm    Post subject: Re: Wierdest turn signal issue ever... Reply with quote
OK well try switching 49 and 49a incase you got them backwards unless you marked the wires when removing from the old flasher. 49 goes to the emergency flasher switch and 49a goes to a triple connector.
Tcash
Tcash is offline
PostPosted: Tue May 10, 2016 6:21 pm    Post subject: Re: Wierdest turn signal issue ever... Reply with quote
I found this:
Aloha
tp
http://www.thesamba.com/vw/forum/viewtopic.php?p=5609119#5609119
Tcash
Tcash is offline
PostPosted: Tue May 10, 2016 6:36 pm    Post subject: Re: Wierdest turn signal issue ever... Reply with quote
Follow the Green wire on E3 E-Switch #15 to the fuse box. Make sure the Green wire and the Black wire from the dash turn signal lights are connected to that fuse on the fuse box.
Good luck
Tcash
mattlockwood
PostPosted: Mon May 16, 2016 8:50 am    Post subject: Re: Wierdest turn signal issue ever... Reply with quote
Ok- so I piggyback kbl onto 49a on the relay. Lights now come on the dash with the key "on"...
But it's both blinkers on the dash blinking now, whether I do left or right turn signal Smile
