John 90 Samba Member
Posted: Mon May 30, 2016 10:42 am Post subject: Kit car with good access to cylinder heads? |
Which Air cooled based kit car has the best access to the heads, so I can take off the top end easily, ideally removing as little of the kit car bodywork as possible?
Ideally there would be space around the heads too for any mods I might bolt on.
Basically I would like a mobile test bed for heads, as swapping heads and then driving would be the main activity. A distant second here is that the kit car is cool looking and fun.
Thanks! |
hillmotorsports Samba Member
Joined: December 27, 2014 Posts: 432 Location: Morrisburg, Ontario, Canada
Posted: Mon May 30, 2016 11:06 am Post subject: Re: Kit car with good access to cylinder heads? |
If it can be licensed in your area....UK regs are unknown.....a sandrail would be the simplest/cheapest/easiest to play with motor parts as there is nothing in the way.
My 2nd choice would be a Meyers Tow'd or Manx dune buggy. Almost as easy engine access but road legal almost anywhere. _________________ Rosemarie and Paul Hill
Morrisburg, Ontario
(With way more projects than spare time!) |
rockcrawl Samba Member
Posted: Mon May 30, 2016 1:34 pm Post subject: Re: Kit car with good access to cylinder heads? |
Baja Bug. |
Letterman7 Samba Member
Joined: March 14, 2004 Posts: 3231 Location: Downingtown, PA
Posted: Mon May 30, 2016 6:12 pm Post subject: Re: Kit car with good access to cylinder heads? |
Pretty much what was said already. Kits are still relatively common in the UK, but they suffer from the same ailment as US kits - bodies are usually one piece, and if you get something like a Nova (Sterling) or Manta variant, your engine access is very limited. Buggies, on the other hand, usually have the engines out in the open more or less, so you could pull the engine and swap whatever you needed with little issue. |
BL3Manx Samba Member
Joined: August 29, 2006 Posts: 6768 Location: Northern California
Posted: Mon May 30, 2016 11:32 pm Post subject: Re: Kit car with good access to cylinder heads? |
The heads are exposed in almost any buggy, however the component which is usually obstructed from removal from the buggy is the fan shroud and you can't remove the cylinder tins without first removing the fan shroud.
I would look at a design which mounted the vw engine out in front which got enough air flow while driving that a cooling shroud system isn't required. You can build your own
Or a Blackjack zero kit http://www.blackjackzero.com/mainindex.htm
Petfisheric Samba Member
Joined: November 27, 2014 Posts: 130 Location: Knoxville, TN
Posted: Tue May 31, 2016 4:31 am Post subject: Re: Kit car with good access to cylinder heads? |
How about a GT40 based kit or an Aztec GT some of these have clam shell rear sections. You might have to modify the hinges to suit your needs. |
Wolfgangdieter Samba Member
Joined: June 25, 2008 Posts: 1997 Location: FL Panhandle
Posted: Tue May 31, 2016 6:57 am Post subject: Re: Kit car with good access to cylinder heads? |
Porsche 550 Spyder replica! Tail end opens like the old front ends of the AH Bugeye Sprite, TR Spitfire or E-Type Jag. Everything from starter to fan belt pulley nut is out in the open. The Perry-D fits a full sized VW chassis but most others use tube chassis and VW running gear.
A VW engine can be removed in under 30 minutes so I'd simply pick a body style you like or can find locally and go for it. Spare engines are inexpensive - so get a spare and swap them in and out. _________________ CMC '57 Porsche Speedster Replica and Dolphin boat tailed full pan VW MOD-T Street Buggy |
Posted: Tue May 31, 2016 7:33 am Post subject: Re: Kit car with good access to cylinder heads? |
What seems like 4 lifetimes ago I had a GT40 style VW based Fibrefab Avenger. Engine access was total, from axles back if I recall.
Other than the style, the access and VW platform were the best parts! _________________ Rosemarie and Paul Hill
Morrisburg, Ontario
jspbtown Samba Member
Posted: Tue May 31, 2016 9:33 am Post subject: Re: Kit car with good access to cylinder heads? |
Avenger access is much better in the front than the rear....
