Mattasmith12 Samba Member
Posted: Thu Jun 30, 2016 2:38 pm Post subject: Corrosion around cylinder bores |
I have a case that was cleaned and bored for 90.5 cylinders. Unfortunately, the machine shop found some corrosion around the bores. Am I right to assume this case is garbage now since the cylinders won't seal correctly?
miniman82 Samba Swamp Donkey
Joined: March 22, 2005 Posts: 9515 Location: Southern Maryland
Posted: Thu Jun 30, 2016 3:05 pm Post subject: Re: Corrosion around cylinder bores |
It'll seal fine, why wouldn't it? None of that damage connects a point from inside the engine to the outside, and you're going to use sealant anyway. I've always used silicone in this area of the engine, but nowhere else! _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
satterley_sr wrote: |
I just wanted to bitch but I'm getting no sympathy. |
Welcome to the Samba. |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15599 Location: Deep in the 405
Posted: Thu Jun 30, 2016 3:38 pm Post subject: Re: Corrosion around cylinder bores |
I'd run it. It is not in a pressurized oil stream so the silicone will do it's job and seal it up. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Posted: Thu Jun 30, 2016 3:53 pm Post subject: Re: Corrosion around cylinder bores |
Thanks for the input! That turned my day around. I'll move forward as planned. |
powerbee1 Samba Member
Joined: November 13, 2011 Posts: 8 Location: Sonoma, CA
Posted: Thu Jun 30, 2016 4:23 pm Post subject: Re: Corrosion around cylinder bores |
cut deck .100 use spacer for right deck height:D |
modok Samba Member
Joined: October 30, 2009 Posts: 27655 Location: Colorado Springs
Posted: Thu Jun 30, 2016 4:33 pm Post subject: Re: Corrosion around cylinder bores |
it's alrady cut .040 approx
dab 518 in the pot-holes, it'll work |
Posted: Fri Jul 01, 2016 12:01 pm Post subject: Re: Corrosion around cylinder bores |
Whoever did that must have a pretty sharp flycutter for it to clean up that good, looking at it beforehand I bet you didn't think it would turn out that clean.  _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
mark tucker Samba Member
Joined: April 08, 2009 Posts: 23950 Location: SHALIMAR ,FLORIDA
Posted: Fri Jul 01, 2016 5:26 pm Post subject: Re: Corrosion around cylinder bores |
looks like a good job but should of went about .040 farther. shims are sheep...and seals are wet....unless there sunning them selves.  |
Rome Samba Member
Joined: June 02, 2004 Posts: 10524 Location: Pearl River, NY
Posted: Fri Jul 01, 2016 6:11 pm Post subject: Re: Corrosion around cylinder bores |
matta, very good work with your photos- sharp, well lit. Wish I could reach thru the computer and run my fingers lightly over the machined surfaces. |
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4368 Location: Los Angeles, CA 90016
Posted: Sat Jul 02, 2016 9:04 am Post subject: Re: Corrosion around cylinder bores |
Who did that machine work? Looks like EMW in Hawthorne. |
rs58rag Samba Member
Joined: August 22, 2010 Posts: 419 Location: riverside,ca
Posted: Sat Jul 02, 2016 11:13 am Post subject: Re: Corrosion around cylinder bores |
Permatex ultra copper silicone to seal cylinders to case.... |
