BJYRGEN Samba Member
Joined: July 11, 2016 Posts: 3 Location: Lappland, Sweden
Posted: Mon Jul 11, 2016 4:59 am Post subject: newer transaxle in air cooled vanagon |
Hey everyone, I'm writing my first post here because I have unsuccessfully tried to find the info in the forums.
My question is; has anyone used the adapter plate go westy sells to mate a "water cooled transaxle" to an air cooled type 4 engine? (See link below)
If so, did you do the work yourself? Exactly how much did you have to shorten the shifter? And what else do I need to know?
http://www.gowesty.com/product-details.php?id=23718
Thanks for any helpful response! |
VWinVT Samba Member
Joined: April 21, 2013 Posts: 1541 Location: North East Kingdom
Posted: Mon Jul 11, 2016 5:31 am Post subject: Re: newer transaxle in air cooled vanagon |
I am interested to know too. I no longer have my type4, but still have the aircooled trans. Someday, a 5 speed would be nice and GoWesty sells them, but I would need to modify in much the same way you will. _________________ 1981 Westfalia with a 2001 Cabrio ABA
Small wheel turns by the firing rod,
Big wheel turns by the grace of God.
Every time that wheel turns 'round,
You're bound to cover just a little more ground. |
Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 12168 Location: Port Manteau
Posted: Mon Jul 11, 2016 8:11 am Post subject: Re: newer transaxle in air cooled vanagon |
You can modify the WBX trans mount to be fit at the same fore/aft position as the DK trans--no need for the GW unit. I can't yet help with the rear shifter mod, but I'm getting ready to do the exact opposite swap in the next couple of weeks, so I'll have a better understanding of how that piece needs to be prepared soon. I do believe it's just shortened by 2" though _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
AndyBees Samba Member
Joined: January 31, 2008 Posts: 2648 Location: Southeast Kentucky
Posted: Mon Jul 11, 2016 9:24 am Post subject: Re: newer transaxle in air cooled vanagon |
Wow! I went the other way! I installed a DK tranny from an air-cool into my 84 water boxer! Although the later transmissions seem to have a better shifting set-up, I believe the DK tranny is far more robust and the grearing is better if you have the power to push it... TDI here!
I agree with Zeitgeist 13, do your own modification to the WBX trans mount! _________________ '84 Vanagon Tin-top, ALH TDI, two trips to Alaska, 2014 & 16. 1989 Tin-top unmolested.
1983 Air-cool, 225k miles, 180k miles mine, seven trips to Alaska from 1986 thru 2003. 1975 Bay hopeful. |
Posted: Mon Jul 11, 2016 10:19 am Post subject: Re: newer transaxle in air cooled vanagon |
Andy, I looked on your TDI Club build thread, but didn't find any pics of the mods you did to the rear shift rod. Is it just as simple as cutting out 2" and re-welding it back together? _________________ Casey--
y u rune klassik? |
Posted: Sat Jul 30, 2016 1:36 pm Post subject: Re: newer transaxle in air cooled vanagon |
Zeitgeist 13 wrote: |
Andy, I looked on your TDI Club build thread, but didn't find any pics of the mods you did to the rear shift rod. Is it just as simple as cutting out 2" and re-welding it back together? |
I never done any mods to install the DK (tranny from an air-cool) in my '84... however, I did drill three new holes in the metal bracket to raise up the front end of the transmission about 1.25 inches. The result did not require doing anything to the shifter rod...... shifts just fine! _________________ '84 Vanagon Tin-top, ALH TDI, two trips to Alaska, 2014 & 16. 1989 Tin-top unmolested.
Posted: Sat Jul 30, 2016 1:50 pm Post subject: Re: newer transaxle in air cooled vanagon |
After reading your thread, it appears that you swapped over the entire aircooled shift linkage. I'm trying to get by with a combination of the two in my install; late front section and early rear section. I'm also dropping the rear of the trans at least 2" _________________ Casey--
y u rune klassik? |
Posted: Sat Jul 30, 2016 6:35 pm Post subject: Re: newer transaxle in air cooled vanagon |
Yep! I purchased the transmission a couple hundred miles from my home location but picked up the shifter and linkage locally. I downed the tranny and installed practically all new bearings, syncro rings, reverse, as well as the upgraded 3rd and 4th, etc.
My next move is to install a Dual Mass Flywheel. I should have done it in the beginning. I listened to all the negatives about the DMF. The DMF in my 2000 Jetta has 358k miles on it. The rattle from my current set up is not acceptable. I installed a pilot shaft to accept the splines of a TDI clutch but that didn't get rid of the rattle. Otherwise, I am happy with my set-up. The .77 4th gear with the 215/75/15 tires works great! _________________ '84 Vanagon Tin-top, ALH TDI, two trips to Alaska, 2014 & 16. 1989 Tin-top unmolested.
