dirtslinger Samba Member
Joined: January 20, 2009 Posts: 392 Location: South Bay, So Cal
Posted: Wed Jul 27, 2016 7:52 pm Post subject: 66-67 Hub Caps |
I need to start sourcing some hubcaps for my daughters 67. I searched the forums but couldn't really answer my question.
If I'm at a swap meet, how do I tell I have the right Hub Cap before I buy it?
Is there an easy tell tale sign? _________________ 1967 Class 5
1970 Class 11 HSD Racing
1972 5/1600 V-MAR/Rasta Baja
1956 Baja
1960 Sand Rover buggy
1965 Street bug
1967 Squareback |
EverettB  Administrator
Joined: April 11, 2000 Posts: 71536 Location: Phoenix 602
Posted: Wed Jul 27, 2016 11:51 pm Post subject: Re: Hub Caps |
Is the diameter of the raised section what is bigger or is it the height of the raised section? What about the back of the cap, is there anything that tells me they are for a type 3 vs. type 1? _________________ 1967 Class 5
1956 Baja
1965 Street bug
1967 Squareback |
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 35911 Location: Conejo Valley, CA
Posted: Thu Jul 28, 2016 7:53 am Post subject: Re: Hub Caps |
dirtslinger wrote: |
If I'm at a swap meet, how do I tell I have the right Hub Cap before I buy it? |
Right and left hubcaps are the same.
sorry, couldn't resist!
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 18046 Location: Eugene, OR
Posted: Thu Jul 28, 2016 8:00 am Post subject: Re: Hub Caps |
 _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Thu Jul 28, 2016 9:10 am Post subject: Re: Hub Caps |
Is the diameter of the raised section what is bigger or is it the height of the raised section? What about the back of the cap, is there anything that tells me they are for a type 3 vs. type 1? |
The height of the raised section is the main indicator.
These caps are Type 3 only.
I dug up some photos from some I sold years ago to show the profile better.
Here they are:
_________________ How to Post Photos
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 23149 Location: Oklahoma City
Posted: Thu Jul 28, 2016 9:15 am Post subject: Re: Hub Caps |
KTPhil wrote: |
Yes....that was a joke...but seriously....I have seen some hubcaps that have the puller holes at 12 o'clock.....some at 3:00 o'clock....all different types....there seems to be no rhyme or reason.
Are they all different part #'s?
Ray |
KTPhil  Samba Member
Posted: Thu Jul 28, 2016 10:06 am Post subject: Re: Hub Caps |
Don't get me started on those chocolate W&Ws I see hiding in M&M packages!
My '71 has the flatter hubcaps common to the Bugs and Buses, I think. From memory, they don't have the protruding bump for the logo.
Or maybe it was a cold day you photographed yours. I live in sunny SoCal. |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 23034 Location: Northwest of Normal
Posted: Thu Jul 28, 2016 10:55 am Post subject: Re: Hub Caps |
KTPhil wrote: |
Yes, '68- on is the flat Bug Bus style. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Those who can- do.
Those who can't? Subaru. |
Posted: Thu Jul 28, 2016 5:21 pm Post subject: Re: Hub Caps |
Thanks,
Hopefully I can figure it out at the next Pomona swap meet and not end up with a 4 lefts or 4 rights.
Actually, it looks like they are pretty identifiable, I see how much they protrude out on the VW logo.
Thanks for the help, and the laugh. _________________ 1967 Class 5
1956 Baja
1965 Street bug
1967 Squareback |
Posted: Thu Jul 28, 2016 9:50 pm Post subject: Re: Hub Caps |
Yes... but for a Beetle, not a Type 3. Type 3 used similar hubcaps in the 1961-5 wide 5 era, but the "VW" emblem is pressed in, not out.
'66/7 Type 3, again, are four lug cars and they use a hubcap that pops OVER, not into, the hub cap lugs. '66/7 Type 3 has a RAISED VW emblem area, with the VW stamped facing out. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Those who can- do.
Posted: Thu Jul 28, 2016 10:01 pm Post subject: Re: Hub Caps |
I think I understand what your referring to with the emblem portion, but I'm failing to see the difference between what Everette posted and these, ugh _________________ 1967 Class 5
1956 Baja
1965 Street bug
1967 Squareback |
Posted: Thu Jul 28, 2016 10:31 pm Post subject: Re: Hub Caps |
Yes, they are 66-67 Beetle hubcaps being advertised with 64-65 Type 3 wheels.
It's hard to tell from those ad photos but the centers are not pressed out as much.
The earlier Type 3 and 66-67 Beetle hubcaps have an edge that looks like this as they clip into the INSIDE of the wheel center:
66-67 Type 3s clip to the OUTSIDE of the wheel center so they don't have a double lip like that. _________________ How to Post Photos
Posted: Thu Jul 28, 2016 10:41 pm Post subject: Re: Hub Caps |
I think that little explanation and pictures is all I needed to be able to figure it out.
Thanks again. _________________ 1967 Class 5
1956 Baja
1965 Street bug
1967 Squareback |
Posted: Tue Aug 02, 2016 7:21 am Post subject: Re: Hub Caps |
OK, lets see if I'm getting better at this. Found these on Craigslist but it was hard to tell what they were, so I had the guy send some other pics.
Now that I have them, I don't think they are 66-67 Type 3.
Are these later type 3 hubcaps? Did I get it right? Sorry, Correct?
1956 Baja
1965 Street bug
1967 Squareback |
Posted: Tue Aug 02, 2016 9:39 am Post subject: Re: Hub Caps |
but type 3 right? _________________ 1967 Class 5
1956 Baja
1965 Street bug
1967 Squareback |
