Seatbelts
Page: Previous  1, 2, 3 ... 11, 12, 13
Relyt
Relyt is offline
PostPosted: Mon Jun 06, 2016 1:10 pm    Post subject: Reply with quote
Motor7710 wrote:
Hope these pics help! Very Happy
There is thin slit barely visible allowing me to slide belt into place with no binding.. Razz
You'll need brackets and to drill a hole for the mounting bolt through to the wheel well. Make sure to use a good lock nut.
69 Beetle - Daily driver
1600 SP (unknown history)
30 PICT 1 w/power circuit (Volkzbitz)
205T (Bill)
Gravell
Gravell is offline
PostPosted: Mon Jun 06, 2016 5:08 pm    Post subject: Re: Seatbelts Reply with quote
Hey Relyt,
Those pictures are exactly what I need. Thank you.
Relyt
Relyt is offline
PostPosted: Tue Jun 07, 2016 12:52 pm    Post subject: Re: Seatbelts Reply with quote
Not my pictures, they're Motor7710's who I quoted from earlier in this thread. But yes I found these pictures to be very helpful for my installation.
205T (Bill)
b1pig
b1pig is offline
PostPosted: Wed Jun 08, 2016 3:28 pm    Post subject: Re: Seatbelts Reply with quote
that rear seat is niiiice. i like that alot.
dvancleve
dvancleve is offline
PostPosted: Wed Jul 27, 2016 4:57 pm    Post subject: Reply with quote
No concerns about the retractor/anchor end just being bolted through the body? I ended up with more Humvee belts than I really need and it would be easy to just use 4 of them in my '68. I am concerned that a bolt/washer/nut through the sheetmetal isn't particularly safe compared to the factory anchor points.
I also noticed that JBugs says, and I quote, "We only offer the brackets as a "Restoration" piece, not a safety piece. The shared mount VW used mounted the belt and retractor to the same point which does not meet current safety standards." Are these still the best way to mount front retractors? What is the alternative?
Thanks, Doug
'62 ragtop bug w/ '71 1600 dual port
dvancleve
PostPosted: Mon Aug 15, 2016 1:57 pm    Post subject: Reply with quote
jlex wrote:
Weather finally let me install the belts this past weekend. Clean installation w/ plenty of hardware.
Relyt is right about using the correct bolt for the top pivot point. There are bolts that are non threaded at the shoulder for that purpose. The top pivot points of attachment are meant to swivel to keep the belt from binding up in the corners when being pulled out or retracted. It's important to use this bolt plus 2 or 3 of the supplied washers to move the pivot point away from the sidewall so it can pivot properly. (See pic). Just a suggestion. If your top connection doesn't swivel, get back into the hardware and fish out the correct bolt & reinstall.
So I just recently bought a batch of these belts, more than I need but the price was right. My 68 doesn't have belts at all right now, but it does have four of the six original bolts. My thought is to use those four bolts on the lower mounts and get new hardware (preferably better looking) for the B pillar mounts. My Humvee belts didn't come with any hardware, so I don't really know what I need. Should I just take one of the original bolts to the hardware store and try to get a close match? I know I need some good size washers for the female ends on the tunnel, do I need any spacers or anything for the B pillar mounts Question
Thanks, Doug
Cusser
Cusser is offline
PostPosted: Mon Aug 15, 2016 4:02 pm    Post subject: Re: Seatbelts Reply with quote
The thread size for seatbelt mounts was standardized at 7/16 inch x 20 thread.
dvancleve
PostPosted: Mon Sep 19, 2016 10:03 am    Post subject: Bumping an old part of this thread... Reply with quote
b1pig wrote:
you may also need to remove the metal tab/flap thing thats on the back of the reel. i did by drilling out the rivets. (carefully)
So there is no issue with drilling out the silver rivets to remove that thin plate on the back?
I think it shows up OK in this picture, but I was surprised to see that the mounting brackets I ordered from JBugs have bumps on them that seem to match up with holes in the seatbelt mounting plate:
That thin metal plate with the spike on it is obstructing the holes and it doesn't seem to serve a purpose in this installation, so I would like to remove it. I'm hoping to make sure nothing falls apart if those rivets or Dremeled or drilled out…
Also, does anybody have spare hardware left over from installing their belts? The belts I ordered didn't come with anything extra. My 68 bug had 6 of the original 10 seatbelt bolts in it. Two of them are shoulder bolts which will work to mount that the B pillar hanger/pivots but with no room for a washer:
Looking at the Humvee hardware that came with the full kits, these two bolts and washers look like they would be perfect:
Anybody happen to have a pair of those bolts and washers left over that they like to sell? I'm not having a lot of luck finding new bolts in the correct diameter and thread, except for plain ones…
Thanks, Doug
Cusser
Cusser is offline
PostPosted: Mon Sep 19, 2016 11:29 am    Post subject: Re: Seatbelts Reply with quote
I have the HumVee belts in my VW, and the pair of adapter brackets.
I did buy some high-strength bolts at Ace Hardware for this; you may want to try Ace Hardware first.
Here's my extra stuff. Bolts (all same thread listed below, measured from bottom of the hex)
2ea 6mm shoulder length, 25mm thread length
4ea 6mm shoulder length, 18mm thread length
2ea NO shoulder, 20mm thread length
Some washers for these: fit over the threaded part of the bolts, but not the shoulder.
TX-73
TX-73 is offline
PostPosted: Mon Sep 19, 2016 1:30 pm    Post subject: Re: Seatbelts Reply with quote
I've also got the Humvee belts and modified that riveted bracket. In my case I simply trimmed the bracket and added a plastic piece where it rests against the rear seat.
You can look in the build, somewhere in the last few pages.
Those Humvee belts were literally a bolt-in, that little bracket mod was nothing.
My 1973 Standard Beetle Build SOLD
Click to view image
dvancleve
PostPosted: Tue Sep 20, 2016 12:48 pm    Post subject: Re: Seatbelts Reply with quote
Thanks guys. I think I'm going to carefully Dremel those two silver rivets and hope that that back plate is the only thing that comes off. Since seatbelt bolt thread and diameter are standardized, does that mean the bolts generally have the same size head Question I ask because I want to get some of those black button things that pop onto the bolt head, and I'm probably going to have to order them. It would be lame if they didn't fit on the bolts once they got here…
I think the VW shoulder bolts I have will work for the B pillar mounts, although my 68 is missing most of the headliner in that area:
I plan to get a longer bolt to anchor that loop on the female side with a big washer, a short bolt with a nylon nut or nut with lock washer to attach the belt to the bracket and a short bolt and lock washer to attach the bracket to the floor.
Thanks again, Doug
dvancleve
PostPosted: Sat Sep 24, 2016 4:45 pm    Post subject: Re: Seatbelts Reply with quote
Since I am not 100% sure removing those silver rivets on the back is okay, I decided to (carefully) cut most of that thin back plate off:
I used a hacksaw (put Gorilla tape anywhere it might touch), then carefully filed the cut edge and dabbed some black Testors on the silver edges. I am hoping to find the hardware I need the the closest Ace Hardware I can find and get them in the car in the next day or so. Once that plate was off, I found that the raised bumps on the mounting plate don't quite line up with the holes in the retractor. I will need to carefully Dremel the outside edges of the holes to get the bumps to properly seat. It should help keep everything straight though, so it should all be good in the end.
Since it doesn't seem feasible to put these belts in the back and I couldn't find any non-retractable shoulder belts that are a particularly close match, I am going with end-release/Euro style lap belts in back. These seem to be the closest: http://www.retrobeltusa.com/product-p/278-xxx.htm , http://www.seatbeltsplus.com/product/1511-74.html . Anybody have experience with either? I am leaning toward the second ones, because that place also sells the black buttons that cover the bolt heads and I am hoping they will work on the B pillar mounts. I do think it's kind of weird that the female side on them is 34" long. I generally expect that to be the short side and it is only 17" on the RetroBelts. It is a bit shorter on the 60" option, 24", which still seems long to me. Anybody know what the typical bug specific lap belt lengths are?
Thanks, Doug
mr matt
mr matt is offline
PostPosted: Sat Apr 15, 2017 7:32 am    Post subject: Re: Seatbelts Reply with quote
THANKS FOR THIS TOPIC especially the OP, - and all the contributors.
Just bought these belts for my 71 vert, aka John Doe.
for those who bought it cheap early on... good buy!!
They are for the front seats
Some questions for these belts for the convert.. (I read all 13 pages)...
In summary, what mods are needed to be done for this belt setup?
I ordered the belt bracket from Chucks ( it was unclear whether CIPs is identical or not, one poster said a bolt hole was bigger from CIPs(?)
Cusser mentioned the bolts and gave the sizes (thanks!)
Is it necessary to remove the backing plate as mentioned in the above post?
I understand they have to mounted very vertical to work
Thanks again to everyone who contributed, these are still so much cheaper than Chuck's.
By the way....Has anyone tried Chuck's? curious about their fit, length, ease of installation - just curious
Cusser
Cusser is offline
PostPosted: Sat Apr 15, 2017 7:43 am    Post subject: Re: Seatbelts Reply with quote
Responses in capitals.
I GOT MY BRACKETS FROM CHUCK'S TOO.
I DID NOT, DIDN'T HAVE TO (HUMMVEE BELTS)
JUST VERY VERTICAL TO GET RETRACTED WHEN JUST OUT OF THE BOX.
mr matt
mr matt is offline
PostPosted: Sat Apr 15, 2017 7:51 am    Post subject: Re: Seatbelts Reply with quote
Great! & thanks Cusser for the quick response - and again, for all of your help and contributions to this topic!
joey1320
joey1320 is offline
PostPosted: Sat Apr 15, 2017 8:00 am    Post subject: Re: Seatbelts Reply with quote
I can't find front humv seat belt kits on eBay but I found one for the rear seats. Are those the same?? The link posted before are no longer working.
http://www.ebay.com/itm/172047127714
1971 Super - Sold
1984 Puma GTC - Sold
1971 Campmobile
mr matt
mr matt is offline
PostPosted: Sun Apr 16, 2017 5:45 pm    Post subject: Re: Seatbelts Reply with quote
This should help.. there is a set for ~ $65, saw this after I ordered an $85 set.
Matt
http://www.ebay.com/itm/Military-HMMWV-3-Point-Fro...2438766685
http://www.ebay.com/itm/2-3-POINT-FRONT-SEATBELT-M...2438766685
http://www.ebay.com/itm/TWO-3-POINT-FRONT-SEAT-BEL...2438766685
19VDuB68
19VDuB68 is offline
PostPosted: Mon Mar 16, 2020 6:25 pm    Post subject: Re: Seatbelts Reply with quote
Matt
I know this is a old post but wondering if the rear belts will work as well? They are 85 compared to 125 for front. I see those extra bracket for front are probably causing the cost increase.
H2OSB
H2OSB is offline
PostPosted: Mon Mar 16, 2020 9:14 pm    Post subject: Reply with quote
1970VWGUY wrote:
priss wrote:
confirmed 1970 bug, HumV belts are awesome.
Where does the hose go?
Ancient thread, I know. Can anyone identify the front passenger seat in this car? It doesn't look like a sports bug seat to me. Looks like it could be rebuilt into something pretty sporty.
H2OSB
(o\_i_/o) Funny thing about pigs, they're cleaner than you and me. Well....you.
Page 13 of 13
