Rhino trans case in a barndoor
EmpiGT
EmpiGT is offline
PostPosted: Wed Oct 05, 2016 7:48 pm    Post subject: Rhino trans case in a barndoor Reply with quote
Is there any issues with putting a rhino tranny case in a barndoor? are the ribs too tall to clear the tube trans supports?
Trevor P
Trevor P is offline
PostPosted: Wed Oct 05, 2016 8:59 pm    Post subject: Re: rhino trans case in a barndoor Reply with quote
It will interfere with the lower trans hoop. You will need to clearance the case in that area.
53 SG Barndoor SC
53 Canadian standard oval
56 Wolfsburg PG/SG
57 Oval, 2332 & Berg 5
70 911T
91 Westy
EmpiGT
EmpiGT is offline
PostPosted: Wed Oct 05, 2016 9:21 pm    Post subject: Re: rhino trans case in a barndoor Reply with quote
That's what I was afraid of.. guess I'll stick to a normal tunnel case for the build. Thanks Trev
BeaterBarndoor
BeaterBarndoor is offline
PostPosted: Thu Oct 06, 2016 4:15 am    Post subject: Re: Rhino trans case in a barndoor Reply with quote
I had a rhino case that was sitting around and finally needed a trans rebuild so I had it all swapped into the rhino case and Just before selling my 53 I put it in there. I don't recall ever messing with anything to fit it in. Pretty certain it fit as normal.
www.thebustransfer.com
Whaaaaat?
Scotty
Scotty is offline
PostPosted: Thu Oct 06, 2016 5:15 am    Post subject: Re: Rhino trans case in a barndoor Reply with quote
Any non split case gearbox will need clearancing to fit in a pre 53 bus. The tube that goes under the gearbox is flat on a pre 53 bus, on later buses it has a dip in the middle.
If I remember correctly, a rhino case only has extra ribbing on the top?
EmpiGT
EmpiGT is offline
PostPosted: Thu Oct 06, 2016 5:56 pm    Post subject: Re: Rhino trans case in a barndoor Reply with quote
The ribbing on the bottom side is taller than stock too.
Pic from gallery
Scotty
Scotty is offline
PostPosted: Fri Oct 07, 2016 5:36 am    Post subject: Re: Rhino trans case in a barndoor Reply with quote
This is how much I had to clearance my gearbox to fit my 52
What year is your bus?
EmpiGT
EmpiGT is offline
PostPosted: Fri Oct 07, 2016 6:37 pm    Post subject: Re: Rhino trans case in a barndoor Reply with quote
Hey Scotty. Thanks for the help. Mine is a 52 as well. I'll probably just run a normal tunnel case. I'll be running a 1776. But at times I may stick my 2332 in it for fun. [/b]
