scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 3359 Location: Memphis
Posted: Thu Jun 12, 2014 6:02 am Post subject: |
Has anyone swapped out the og motor in the air box for a different motor? If a burned-up motor is as common as it sounds, we really need a good fix for it in the community here...
My motor is burned up on both speeds - used, from a '72 super in the junkyard - and I can't really imagine it would be cost effective to re-wind the motor. I'm curious if anyone has ever tried _________________ Robert in Memphis
Engine rebuild thread
If you're ever in the Memphis area, you are welcome to stop by for advice and help. |
RainbowManFan Samba Member
Joined: January 15, 2016 Posts: 70 Location: Knoxville, TN
Posted: Tue Oct 25, 2016 6:06 pm Post subject: Re: Fresh air box on 1972 Super Beetle... I'm confused. |
| My fresh air box and defroster ducts were completely missing when I bought my 72 Super Beetle. I have purchased a used set and cleaned up and refurbished the fresh air box. My confusion comes in with the wiring connections. There are 3 wires that exit the rear of the fresh air box. Can anybody tell me how to hook them back up? |
USMCbug Samba Yoda
Joined: April 29, 2004 Posts: 2573 Location: Wichita, KS
Posted: Tue Oct 25, 2016 6:15 pm Post subject: Re: Fresh air box on 1972 Super Beetle... I'm confused. |
There are two black wires with stripes and a brown wire. The two black wires will plug into two black wires that should be hanging lose somewhere under the hood. The brown wire is ground and plugs into the common ground spades near the speedo. _________________ 72 Super Beetle
73 Standard Beetle
79 Baywindow Bus
65 Split Window Bus
79 Baywindow Bus
71 Super Beetle (current)
"When war does come, my advice is to draw the sword and throw away the
scabbard."
- General Thomas "Stonewall" Jackson |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33386 Location: Hot Arizona
Posted: Tue Oct 25, 2016 6:27 pm Post subject: Re: Fresh air box on 1972 Super Beetle... I'm confused. |
The wires should come off the front of the switch, so on the firewall inside the trunk. There are two speeds: slow and slower. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
vamram  Samba Member
Posted: Tue Oct 25, 2016 7:06 pm Post subject: Re: Fresh air box on 1972 Super Beetle... I'm confused. |
I used this guys video and rebuilt my frozen fan into a working 2-speed fan. Patience, and the correct tools, and it works.
https://vimeo.com/1072065 _________________ "Men are qualified for civil liberty in exact proportion to their disposition
'75 Super Le Grande...we hardly knew ye. Sold 2025 for peanuts.
Click to view image
Save the Supers!! |
72VWSB Samba Member
Joined: August 06, 2018 Posts: 722 Location: New Mexico
Posted: Sat Sep 01, 2018 4:06 pm Post subject: Re: Fresh air box on 1972 Super Beetle... I'm confused. |
Hello,
I'm a little late posting in this thread but I also have 1972 SB that I'm trying to find the Anti-vibration connectors for the fresh air box. I tried to look at page 1361 in the McMaster-Carr online catalog but I'm sure the page numbers have changed and I cannot locate these connectors for the air box... Any assistance would be greatly appreciated...thank you |
72VWSB Samba Member
Posted: Sun Sep 02, 2018 11:28 am Post subject: Re: Fresh air box on 1972 Super Beetle... I'm confused. |
Hmm, doesn't seem as anyone is looking for these of late. Anyway, I did find something that will work.
https://www.ebay.com/i/223078817687 |
DesignBuild Samba Member
Joined: September 29, 2016 Posts: 401 Location: HOUSTON, TEXAS
Posted: Tue Jul 23, 2019 1:19 am Post subject: Re: Fresh air box on 1972 Super Beetle... I'm confused. |
Here is a search parameter to use in the McMaster-Carr catalogue.
"General Purpose Vibration-Damping Sandwich Mounts with Studs". I will get the thickness dimension tomorrow and post it. |
Meiang Samba Member
Joined: September 27, 2016 Posts: 660 Location: Perth, Western Australia
Posted: Tue Jul 23, 2019 1:58 am Post subject: Re: Fresh air box on 1972 Super Beetle... I'm confused. |
| Australian and some European 1971-1972 Superbugs did not have the fresh air fan. They had non power assisted ventilation system and full width dash cover (behind) without the ventilation system sticking out. |
alex857 Samba Member
Joined: December 26, 2010 Posts: 780 Location: Stuttgart/Germany
Posted: Tue Jul 23, 2019 3:38 am Post subject: Re: Fresh air box on 1972 Super Beetle... I'm confused. |
| In Europe, you could buy the two Speed fan in Super Beetles and later in Standard Beetles as extra, as part of the "L"-(luxury) package or as "M"-Option. |
Posted: Tue Jul 23, 2019 11:33 am Post subject: Re: Fresh air box on 1972 Super Beetle... I'm confused. |
| The size of the vibration isolators is as follows: rubber cylinder diameter @1/2 inch or 12.7mm, stud on each end 6mm or 1/4 inch diameter (0.236"), stud length @1/2 inch in length or 12 to 15mm, height of the rubber is 10 mm or 13/32 inch. The gap between the attachment points is 10 mm exactly and 13/32 inch is just slightly longer than 10mm. You are going to need 2 small flat washers, 2 each split or star lock washer and 2 each nut to match threads. You don't need a star or split lock washer if you use a nylock nut. Your best bet is buy them from McMaster-Carr because they have a large selection and they are easy to find. Link: https://www.mcmaster.com/vibration-dampers |
