markd89 Samba Member
Joined: November 04, 2005 Posts: 674 Location: Los Angeles
Posted: Sun Nov 20, 2016 5:49 pm Post subject: Steering box adjustment nut -- stripped? |
Hi all!
I noticed some oil leaking from the steering box adjustment nut area. I put a wrench on the nut and it wasn't tight. Easy, I thought, I'll use a screwdriver to keep the adjuster where it is and tighten the nut -- only the nut wouldn't get tight.
Looking at the nut, it appears to be copper. If so, I'm thinking perhaps that is stripped rather than the threaded adjuster.
Am I on the right track? If so, is there any tricks to be aware of in removing/replacing? Can I use a stainless nut with a copper washer to seal or must I get the original nut?
Thanks much!
Mark _________________ 78 TDI Sunroof Bus
Los Angeles |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42594 Location: at the beach
Posted: Sun Nov 20, 2016 9:36 pm Post subject: Re: Steering box adjustment nut -- stripped? |
The original nut was steel with a built in plastic seal. Use a steel nut with some rtv _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
kaiisons Samba Member
Joined: January 07, 2012 Posts: 78 Location: Sydney, Australia
Posted: Sun Nov 20, 2016 10:28 pm Post subject: Re: Steering box adjustment nut -- stripped? |
@SGKent,
I haven't seen one of those sealed nuts on a steering box before. Do you have any pics? |
SGKent  Samba Member
Posted: Mon Nov 21, 2016 8:14 am Post subject: Re: Steering box adjustment nut -- stripped? |
you have to take the nut off to see the red ring. It is kinda like an oil pump nut on a T1.
This is an oil pump sealing nut from Aircooled.net site. The larger steering nut as show in the last photo has one of these red rings on the boxes I have worked on.
Posted: Mon Nov 21, 2016 10:45 am Post subject: Re: Steering box adjustment nut -- stripped? |
Great info, thanks Steve!! _________________ 78 TDI Sunroof Bus
Los Angeles |
Posted: Fri Nov 25, 2016 12:39 pm Post subject: Re: Steering box adjustment nut -- stripped? |
Update:
The nut and screw are OK (not stripped).
Unfortunately, it is the aluminum steering box cover that is stripped. It has got worse with my efforts so now when I turn the wheel, the adjuster is pressed out about 5-10mm.
I pushed it in and have JB Weld and a heat lamp on it, hoping that will buy some time.
I have a spare steering box - condition unknown.
Questions:
1. Is it possible to remove the cover from my spare and put it onto the box that is in the bus without removing the steering box from the bus?
2.If the adjuster managed to work its way out, would I lose all steering or it just be sloppy?
Thanks again!
Los Angeles |
Posted: Fri Nov 25, 2016 3:27 pm Post subject: Re: Steering box adjustment nut -- stripped? |
So, JB Weld didn't work so back to making a more proper repair.
Any help on 2 questions from last post, much appreciated! _________________ 78 TDI Sunroof Bus
Los Angeles |
SGKent  Samba Member
Posted: Fri Nov 25, 2016 6:43 pm Post subject: Re: Steering box adjustment nut -- stripped? |
Quote: |
1. Is it possible to remove the cover from my spare and put it onto the box that is in the bus without removing the steering box from the bus? |
IF THIS IS YOUR 1978 I think so. A photo is below of late steering box parts. Loosen the center nut on the screw. Then the three bolts come off, oil drips everywhere, and the you hold the screw steady with a screwdriver while you spin the cover off the box. I THINK BUT AM NOT SURE that the center screw is held into the shaft with the snap ring. I don't think it is held into the cover as I recall. There will be an O-ring for the whole top that will be old. You will need to seal that area with some sealer and the o-ring because it will be permanently compressed. Installation is reverse of removal. Be 100% sure you test that box lock-to-lock quite a few times before you drive it in case tolerances are different between boxes. LATE boxes were not all made in the same factory. some were made in Germany and some in France. All were made under license from Gemmer but internal dimensions and the cover can vary.
Quote: |
2.If the adjuster managed to work its way out, would I lose all steering or it just be sloppy? |
Just don't drive it like that. The lash could be so bad you would lose control. It isn't all that hard to change the box however it does take the right tools.
. _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 3322 Location: Hamble, Hampshire, UK
Posted: Sat Nov 26, 2016 10:45 am Post subject: Re: Steering box adjustment nut -- stripped? |
Yes the screw is held into the end of the shaft with a snap ring. Of couse in keeping with the rules, the end plate you stripped the thread in will have a non worn brass bushing and the replacement will have wear grooves... _________________ Ancient vehicles and vessels
Posted: Sun Nov 27, 2016 9:28 am Post subject: Re: Steering box adjustment nut -- stripped? |
Gentleman, than you!
Steve, especially, awesome info and pics are very helpful! _________________ 78 TDI Sunroof Bus
Los Angeles |
Posted: Thu Dec 08, 2016 1:08 pm Post subject: Re: Steering box adjustment nut -- stripped? |
So, what happened:
Steve was right, of course. Once the three bolts are removed from the cover, the cover can be spun off the adjuster screw.
Unfortunately, I was not able to complete the in-situ repair.
I had managed to mangle the threads a little on the adjuster screw of the box in the bus and so couldn't remove the nut.
On my "spare", I snapped one of the three bolts holding on the cover. I was still able to spin off the cover as the broken bolt is in the housing side of the box.
Rather than fixing the above and having a box that would probably leak from a new spot, I got a new TRW Brazil box and it was installed yesterday. I had already replaced pretty much everything else steering related and with this box, there is almost no play in the steering.
Side note (and news to my very experienced mechanic buddy): The TRW boxes don't come with oil, you must add it!
Thanks again for all the help!
Los Angeles |
hiwaycallin Samba Member
Joined: May 07, 2008 Posts: 362 Location: Salmon Arm, BC
Posted: Thu May 02, 2019 9:44 pm Post subject: Re: Steering box adjustment nut -- stripped? |
Another steering box adjustment nut question ...
The steering adjustment locking nut is stuck/fused to the adjustment screw on my '78, so when I loosen the nut, the screw turns with it and vice versa, making it impossible to adjust the box. I've soaked them with PB Blaster but so far no luck getting them to turn independently. My question is, if I back the screw out all the way until the screw stops turning, will it hold firmly enough for me to apply enough pressure on the nut to separate them? Or if I do that am I likely to pull the screw right out of the box and ruin it? |
Posted: Fri May 03, 2019 4:27 am Post subject: Re: Steering box adjustment nut -- stripped? |
hiwaycallin wrote: |
I would not do that. The split ring holding the bolt into the end of tbe steering output shaft will be pulled out by the tension or you will strip the thread in the cover.
Cut the nut off. _________________ Ancient vehicles and vessels
SGKent  Samba Member
Posted: Fri May 03, 2019 12:35 pm Post subject: Re: Steering box adjustment nut -- stripped? |
Make sure you are doing it right. The screw threads into the cover. You turn the screw in while the nut out. Use a screwdriver sideways in the adjuster screw to hold it while you turn the nut. Otherwise as Mike says - cut the nut off. It is a special nut however with a seal on one side like type 1 oil pump nuts. _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
Posted: Fri May 03, 2019 2:38 pm Post subject: Re: Steering box adjustment nut -- stripped? |
Thanks guys. After another day of letting it sit with some more PB and getting it into a position where I could get some good leverage with the sideways screwdriver, I got them apart. |
SGKent  Samba Member
Posted: Fri May 03, 2019 4:36 pm Post subject: Re: Steering box adjustment nut -- stripped? |
good job _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
