57/58 body dimensions
bugginpaul
bugginpaul is offline
PostPosted: Sat Nov 26, 2016 11:18 am    Post subject: 57/58 body dimensions Reply with quote
Does anyone have, or know where I can locate some detailed drawings of body dimensions...?
I've had a bug come into my shop, and the rear looks to have had a shunt at some point in its life, and then repaired (badly) at another vw shop.
Telltale for me was the badly fitting wing, and then when I've measured up, the engine bay tapers down on the side trays by over an inch over the length of them...
Cheers in advance for any help!!
panicman
panicman is offline
PostPosted: Sat Nov 26, 2016 12:51 pm    Post subject: Re: 57/58 body dimensions Reply with quote
Hopefully you get a faster resource than me.
I think the Bentley shop manual has very detailed dimensions for body alignment and repair. When I can get to mine, I'll see if they look like what you need. If they do, I can scan them and upload them.
You might see in the technical tab if someone has already done this.
bugginpaul
PostPosted: Tue Nov 29, 2016 11:56 am    Post subject: Re: 57/58 body dimensions Reply with quote
I'd not thought of checking the bentley manual!! I'll have a flick through it tomorrow Cool
Rathguten
Rathguten is offline
PostPosted: Tue Nov 29, 2016 2:16 pm    Post subject: Re: 57/58 body dimensions Reply with quote
http://www.cabshome.de/tipps/kaefer2
pondoras box
pondoras box is online now
PostPosted: Wed Nov 30, 2016 7:01 am    Post subject: Re: 57/58 body dimensions Reply with quote
If I am understanding the dimensions correctly, the left door opening is 1mm larger than the right? Interesting.
1961 23 Window (Bobo)
1965 13 Window (Lucas)
1957 Oval ragtop
1960 hardtop
1964 hardtop
1965 hardtop (Arschloch)
1973 standard bug (Dirty Gertie)
https://www.thesamba.com/vw/forum/viewtopic.php?t=804912
1988 Cabriolet VR6 conversion
panicman
panicman is offline
PostPosted: Wed Nov 30, 2016 9:00 am    Post subject: Re: 57/58 body dimensions Reply with quote
Here is a link, thanks to user Thomas:
http://www.thesamba.com/vw/forum/album_search.php?...t_dir=DESC
Haven't even dug out my Bentley. Apologies!
esde
esde is offline
PostPosted: Fri Nov 29, 2024 4:31 pm    Post subject: Re: 57/58 body dimensions Reply with quote
somewhere here on Samba there is a thread with convertible door gap info. I stumbled across it after I got my 56 vert but foolishly did not bookmark it
Embarassed
modok wrote:
WrennMetallWerks
WrennMetallWerks is offline
PostPosted: Fri Nov 29, 2024 8:48 pm    Post subject: Re: 57/58 body dimensions Reply with quote
Hello there. I’m not sure if this would help you but it has been priceless for me. I have a beetle body I call “The Bible Bug”. I use it’s for reference and measurements when I’m reconstructing bodies. If I can be of any assistance feel free to reach out to me.
⚒ Believe In The Power Of Positive Thinking ⚒
Purpose Over Pleasure 🕊
“Hard Werk ⚒ God First “
