Yee Haw, got my governor working/adjusted! *Video!*
Page: Previous  1, 2, 3, 4, 5, 6, 7  Next
easy e
easy e is offline
PostPosted: Sat Dec 17, 2016 3:19 pm    Post subject: Re: Yee Haw, got my governor working/adjusted! *Video!* Reply with quote
Ya right... to back that up.... please post a picture of you wearing the hat with some sunglasses on... touching a voltage regulator or something. Cool
aka: Evan
peecee69
peecee69 is offline
PostPosted: Sun Dec 18, 2016 5:26 am    Post subject: Reply with quote
Eric&Barb wrote:
Very cool! Got one of those hats and did not know that they were that early. It might have come out of the Buffalo NY dealership that was closed about 1960 due to conflict between dealership owner and VOA. Bill D. bought out the entire contents back in the early 1990s.
Was that the Jim Kelly dealership?
View user's profile Send private message Send e-mail AIM Address Yahoo Messenger Facebook Gallery Classifieds Feedback
Eric&Barb
Eric&Barb is offline
PostPosted: Sun Dec 18, 2016 9:44 am    Post subject: Reply with quote
Do not know the name of the dealership, just the location.
In Stereo, Where Available!
BulliBill
BulliBill is offline
PostPosted: Sun Dec 18, 2016 10:07 am    Post subject: Re: Yee Haw, got my governor working/adjusted! *Video!* Reply with quote
I've got one of those hats in NOS condition too in my collection. I'm afraid to put it together and try it on!
Bill
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help!
victorvant4
victorvant4 is offline
PostPosted: Sat Feb 04, 2017 4:55 am    Post subject: Re: Yee Haw, got my governor working/adjusted! *Video!* Reply with quote
Hi!
I´ve restored my governor in a 1500SP engine. the K screw is not tight to keep the intake clap as open as possible. I don´t know if it´s right.
So, at slow motion (no foot in the pedal) the RPM aren´t stable. It goes up and down (800-100-800-...) all the time.
Does anybody have the same problem? Is it right? Vac leak maybe?
It has no seal or loctitte in the front top, is it right?
I´ve read the hole thread and there´s a great info here. Congrats!!
Thank you very much!!
tasb
The Distributor Distributor
tasb is offline
PostPosted: Sat Feb 04, 2017 5:13 am    Post subject: Re: Yee Haw, got my governor working/adjusted! *Video!* Reply with quote
Hi back attcha, Smile Welcome to The Samba! the picture on the left doesn't look right. the tension spring does not appear to be attached to anything. It does sound like you have a vacuum leak. Try sealing the cover to the housing as originally done.
Roads Scholar
Member# 2059
Abscate Premium Member
Abscate is offline
PostPosted: Sat Feb 04, 2017 5:57 am    Post subject: Reply with quote
Jim Kelly's was open well after 1960... Must have been another??
victorvant4
PostPosted: Sat Feb 04, 2017 7:58 am    Post subject: Re: Yee Haw, got my governor working/adjusted! *Video!* Reply with quote
Hi again!😅
The left pic is before i restored it! The left one is how it is now...
I'll try to seal the front cover.
Thank you tasb!!
Eric&Barb
PostPosted: Sat Feb 04, 2017 10:05 am    Post subject: Re: Yee Haw, got my governor working/adjusted! *Video!* Reply with quote
Two lefts do not make a right! Laughing Think second sentence should be "right" instead of left.
victorvant4
PostPosted: Sat Feb 04, 2017 11:38 am    Post subject: Re: Yee Haw, got my governor working/adjusted! *Video!* Reply with quote
Right!! 😅
What do you think about leave soft K screw to keep the intake clap opener?
Is it ok?
tasb
tasb is offline
PostPosted: Sun Feb 05, 2017 11:15 am    Post subject: Re: Yee Haw, got my governor working/adjusted! *Video!* Reply with quote
victorvant4 wrote:
Right!! 😅
Is it ok?
Seeking to undersand what you are saying/asking here
Roads Scholar
Member# 2059
victorvant4
PostPosted: Sun Feb 05, 2017 1:50 pm    Post subject: Re: Yee Haw, got my governor working/adjusted! *Video!* Reply with quote
I´m sorry.
In the first pic you can see how i´ve put the K screw. It´s not tight to keep the intake clap as open as possible.
I don´t know if it´s right or not.
That´s my question.
Thank you Everett!
tasb
tasb is offline
PostPosted: Sun Feb 05, 2017 2:00 pm    Post subject: Re: Yee Haw, got my governor working/adjusted! *Video!* Reply with quote
If you increase the tension on the top main spring the butterfly (flapper) will not close as quickly. There's also and adjustment screw missing from the bottom that will keep the arm from coming down fully. Sounds like you are trying to install the governor but not have it do any work? That's common now a days and better than just curtting/removing the butterfly which destroys the governor.
Roads Scholar
Member# 2059
Gwdghiaguy
Gwdghiaguy is offline
PostPosted: Sun Oct 01, 2017 7:42 pm    Post subject: Re: Yee Haw, got my governor working/adjusted! *Video!* Reply with quote
any reason I can't drop this in my carb cleaner like it is? Should I put the cover back on first? thanks
byron
1957 Oval Window
1963 Alabama Camper Bus
1971 Ghia
1971 Baywindow Bus
tasb
tasb is offline
PostPosted: Mon Oct 02, 2017 8:50 am    Post subject: Re: Yee Haw, got my governor working/adjusted! *Video!* Reply with quote
Go ahead, there's nothing that can be hurt by a brief dunk. Make sure you relubricate, of course. It's good practice to reseal the cover too, so that its air tight.
Roads Scholar
Member# 2059
BarryL Premium Member
BarryL is offline
PostPosted: Mon Oct 02, 2017 8:55 am    Post subject: Re: Yee Haw, got my governor working/adjusted! *Video!* Reply with quote
Gwdghiaguy wrote:
any reason
It looks too clean to dip in the gnarly cleaner stuff. One reason not to dip it would be that there is a permanently sealed chamber with the piston in it that can get its seal eaten by the cleaner.
PostPosted: Mon Oct 02, 2017 9:17 am    Post subject: Re: Yee Haw, got my governor working/adjusted! *Video!* Reply with quote
I was wondering if there is a seal in there too.
A seal could get damaged by carb. cleaner
I think it might only be a metal cylinder?
BarryL is offline
PostPosted: Mon Oct 02, 2017 9:22 am    Post subject: Re: Yee Haw, got my governor working/adjusted! *Video!* Reply with quote
So no gasket where it has the body rivets?
Anyway I bet it would be hard to get the icky carb-dip out if it got in the chamber.
Gwdghiaguy
PostPosted: Mon Oct 02, 2017 9:39 am    Post subject: Re: Yee Haw, got my governor working/adjusted! *Video!* Reply with quote
I think I'll just put the cover back on and scrub it by hand. Thanks for everyone's input. byron
1957 Oval Window
1971 Ghia
1971 Baywindow Bus
PostPosted: Mon Oct 02, 2017 3:35 pm    Post subject: Re: Yee Haw, got my governor working/adjusted! *Video!* Reply with quote
I don't see anything there on the ones I looked at.
I have one that has the cap loose, here's what it looks like with the cap removed:
It's had the entire valve removed too
Page 6 of 7
