Maxdog2 Samba Member
Joined: August 06, 2009 Posts: 208 Location: Grand Junction, Colorado
Posted: Sat Dec 17, 2016 5:20 pm Post subject: Question on Lucas assembly lube and rod bearings |
I have read good things about the Lucas assembly lube and used it today when building my crankshaft. Plastigage and rod clearances are within spec. No tight spots when rotating the rods, but they do not swing freely. This stuff seams really thick. I pulled a cap and removed some of the Lucas and added 30 wt. much better. I them wiped off all the Lucas and coated with 30 wt. and now the rods swing like butter.
I believe the Lucas assembly lube would protect the bearings, but am concerned it may be too think to let the oil in. Thoughts?
Maybe this product would be best for the oil pump.
Thanks,
David |
modok Samba Member
Joined: October 30, 2009 Posts: 27757 Location: Colorado Springs
Posted: Sat Dec 17, 2016 5:27 pm Post subject: Re: Question on Lucas assembly lube and rod bearings |
I assume it is a thick goop? This is good for if the engine may not get started for a long time. It will protect all the surfaces and not dry or runoff. Way better than grease!
If the engine will NOT be sitting for a long time, or will be pressure lubed before starting, I prefer to use 90wt gear oil for this, and a lot of things, valve guides, pin bushings, ect. but keep it off the cylinders. The gear oil has slightly more EP additive and less detergent so it slightly more suited than engine oil, but engine oil will work fine too, 30 or 40 wt tends to stay put better. 90wt gear oil is actually not any thicker, they just rate gear oil at a lower temp.
While I may be conflicting my own advice here, I've lubed stuff with gear oil and even a year later it hasn't gone anywhere......seems to work great. i should just put some red dye in there, a bit of wintergreen oil, and re-label it as super assembly lube and make a killing  |
Posted: Sat Dec 17, 2016 5:36 pm Post subject: Re: Question on Lucas assembly lube and rod bearings |
Thanks Glen, yep pretty thick stuff. The motor will not sit for an extended period, just going slow on my first VW build. I will pick up some 90wt and proceed.
David |
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2550 Location: Meridian,ID
Posted: Sat Dec 17, 2016 5:46 pm Post subject: Re: Question on Lucas assembly lube and rod bearings |
| I've used the Redline assembly lube and also white lithium grease in the past. Neither is very thick and will "wash away" with the oil. Both work well to prime the oil pump too. |
Posted: Sat Dec 17, 2016 6:21 pm Post subject: Re: Question on Lucas assembly lube and rod bearings |
| I like the Lucas products and have used them in my Harley. Probably will be ok, just making sure. Thanks |
Posted: Sat Dec 17, 2016 6:37 pm Post subject: Re: Question on Lucas assembly lube and rod bearings |
| ps2375 wrote: |
Thanks, I have used Redline also. |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20912 Location: Just a tiny bit west of Yosemite Valley
Posted: Sat Dec 17, 2016 7:36 pm Post subject: Re: Question on Lucas assembly lube and rod bearings |
I Use Sta-Lube.... Brand probably does not really matter as long as you spin up motor and insure you have oil pressure and have whetted all bearing surfaces before you put the fire to it...
Dale _________________ “Fear The Government That Wants To Take Your Guns"
SamT Samba Member
Joined: April 17, 2009 Posts: 1767 Location: Rule, Tx
Posted: Sat Dec 17, 2016 8:08 pm Post subject: Re: Question on Lucas assembly lube and rod bearings |
We used to use gun Greace when I was a kid. I've used motor oil, stp, white Greace , moly with graphite, Ect. Hell I used to put Vaseline in the oil pump to prime it, why? Who knows, I hope I read that somewhere intelligent. I prefer redline moly but I have to order it and that sucks. _________________ Rides:
300HP 900lb turbo VW rail 18/15 travel
Never ending jeep/rzr hybrid build!
http://www.thesamba.com/vw/forum/viewtopic.php?t=546712 |
Posted: Sat Dec 17, 2016 9:35 pm Post subject: Re: Question on Lucas assembly lube and rod bearings |
| Thanks for all of the responses. Finishing up the crank in the am. |
Zundfolge1432 Samba Member
Posted: Sun Dec 18, 2016 9:16 am Post subject: Re: Question on Lucas assembly lube and rod bearings |
| SamT wrote: |
| We used to use gun Greace when I was a kid. I've used motor oil, stp, white Greace , moly with graphite, Ect. Hell I used to put Vaseline in the oil pump to prime it, why? Who knows, I hope I read that somewhere intelligent. I prefer redline moly but I have to order it and that sucks. |
R U related to Marc Tucker? |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33587 Location: Hot Arizona
Posted: Sun Dec 18, 2016 10:09 am Post subject: Re: Question on Lucas assembly lube and rod bearings |
| Dale M. wrote: |
Dale |
I used Sta-Lube with my B2200 truck engine in late 2011; so I'll use the same container with my 1600cc engine assembly within a few weeks. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
77charger Samba Member
Posted: Sun Dec 18, 2016 10:13 am Post subject: Re: Question on Lucas assembly lube and rod bearings |
Have used it here and there too noticed the same thing.But no issues on start up either.I prefer to use oil in some places and lucas in others. _________________ Click to view image
Bugpack 4 seater rail
2275 built by me
Auto linea alm case,82 dpr crank wedgemated by DK machine
cb 5.4 h beams,12 pound DPR f/w,Slr xv294cam,cb straight cuts,hpmx 44s,40x35 heads ported by brothers machine |
Posted: Sun Dec 18, 2016 10:21 am Post subject: Re: Question on Lucas assembly lube and rod bearings |
| Going with middle of the road for assembly lube. Autozone has Valvoline VR1 50-weight on sale for $2.00. |
Vanapplebomb Samba Member
Joined: November 03, 2010 Posts: 5573 Location: Holland, MI
Posted: Sun Dec 18, 2016 3:38 pm Post subject: Re: Question on Lucas assembly lube and rod bearings |
Lucas assembly lube is fine. I have used it in numerous instances. Assembly lube is supposed to be thick...dont worry about it. Once the engine builds oil pressure and oil makes its way to the bearings, the assembly lube will wash away.  _________________ 1800 Type 4 Berrien 295
http://www.thesamba.com/vw/forum/viewtopic.php?t=487021 |
Posted: Sun Dec 18, 2016 8:08 pm Post subject: Re: Question on Lucas assembly lube and rod bearings |
| Vanapplebomb wrote: |
Lucas assembly lube is fine. I have used it in numerous instances. Assembly lube is supposed to be thick...dont worry about it. Once the engine builds oil pressure and oil makes its way to the bearings, the assembly lube will wash away.  |
I have a tendency to over think things.
Thanks |
borninabus Samba R&D Dept.
Joined: May 18, 2006 Posts: 4787 Location: Arizona Highways
Posted: Mon Dec 19, 2016 8:53 am Post subject: Re: Question on Lucas assembly lube and rod bearings |
| Maxdog2 wrote: |
| I have a tendency to over think things. |
what fun would life be if there wasn't time for over thinking things?
i like the lucas ass'y lube because it's really sticky.
so i use a mix of lucas, motor oil & gear oil  _________________ 88 Van WBX, A/T - 93 Multivan 5cyl 5M/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
Posted: Mon Dec 19, 2016 9:01 am Post subject: Re: Question on Lucas assembly lube and rod bearings |
| borninabus wrote: |
| Maxdog2 wrote: |
so i use a mix of lucas, motor oil & gear oil  |
On of my friends nicknamed me "Tweeker" because I'm always trying to dial something in to make it better. Thanks for your response. |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 3481 Location: Hamble, Hampshire, UK
Posted: Mon Dec 19, 2016 10:15 am Post subject: Re: Question on Lucas assembly lube and rod bearings |
I used a small can of generic sewing machine oil because it had a convenient nozzle..
Seemed a bit thicker than engine oil and stickier. But then I had it running only a couple of days after throwing it together.
The simplicity of an engine that is only needed to run at 4500 rpm or less..
17000 miles and 18 months later the engine is still running well.. _________________ Ancient vehicles and vessels
Posted: Mon Dec 19, 2016 10:42 am Post subject: Re: Question on Lucas assembly lube and rod bearings |
| mikedjames wrote: |
17000 miles and 18 months later the engine is still running well.. |
Simple build here. 1835 with a W100 cam and PICT 34 Super Stock carb from Aircooled.net. Stock size valve heads. |
esde Samba Member
Joined: October 20, 2007 Posts: 6414 Location: central rust belt
Posted: Mon Dec 19, 2016 6:35 pm Post subject: Re: Question on Lucas assembly lube and rod bearings |
What's really nice about the Lucas assembly lube, is that it pretty much stays where you put it. Everything that I build is second to my real job, so sometimes there are weeks where I'll leave an engine sit half done. With the Lucas, there may be a few drips under a short block if left for weeks. When I was using redline, or before that, moly based sta-lube, I had to leave a drip pan under the case because of how much would run out. It never really instilled much confidence when firing a motor that had sat for months while the tin and carbs got sorted, how much protection was left there for the bearings when it was started?
Lately, I've been using the Torco MPZ. Webcam sent me a decent size tube with my last cam and I liked it, so I ordered more. It seems a bit thicker than the Lucas and really stays put.
SD _________________ modok wrote:
