Eberspacher B2 Rebuild Project
Page: Previous  1, 2, 3, 4, 5, 6, 7  Next
64Bug
64Bug is offline
PostPosted: Fri Apr 29, 2016 12:58 pm    Post subject: Re: Eberspacher B2 Rebuild Project Reply with quote
Greetings
I would suggest you read the start of this thread back to 2008. I wrote detailed instructions on rebuilding these heaters. If it has not been rebuilt, it could be a number of issues. It is usually either the glow plug wiring or the fuel pump.
Good luck
When you turn it on, does it return the favor?
1974 Westfalia
1964 Beetle (stock)
2017 Santa Fe
ZENVWDRIVER
ZENVWDRIVER is offline
PostPosted: Fri Apr 29, 2016 6:36 pm    Post subject: Re: Eberspacher B2 Rebuild Project Reply with quote
... recently bought a '55 with a gas heater... am enjoying this thread... thanks.
5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK
cn63bug
cn63bug is offline
PostPosted: Tue Oct 11, 2016 11:02 am    Post subject: Re: Eberspacher B2 Rebuild Project Reply with quote
So, I've rebuilt my B2 heater and everything is good except that I am missing the intake tube that goes in the fender well...
64bug's photo as reference.
Does anyone know where I can find one? I've been looking everywhere with no luck. It's the only piece that I need to set up my heater properly. I looked into having one made, but I haven't found anyone local yet that kind do that tight of a radius on the bend.
64Bug
64Bug is offline
PostPosted: Wed Oct 12, 2016 2:29 am    Post subject: Re: Eberspacher B2 Rebuild Project Reply with quote
Greetings cn63bug
Don't get your hopes up, but I may have one in my box of heater parts. I will let you know tonight when I get home from work.
1974 Westfalia
1964 Beetle (stock)
2017 Santa Fe
cn63bug
cn63bug is offline
PostPosted: Wed Oct 12, 2016 7:29 am    Post subject: Re: Eberspacher B2 Rebuild Project Reply with quote
Hey 64bug,
That would be great if you do have one. Please let me know. It's been a bear to try and find anyone that can bend the pipe for me.
Chris
neili
neili is offline
PostPosted: Fri Oct 28, 2016 12:02 pm    Post subject: Re: Eberspacher B2 Rebuild Project Reply with quote
Hi all,
I have a B2 in my 67 .. someone converted the beetle to 12v but didn't do anything about the 6v eberspacher.
I did not realise and it was working fine but then blew the fuse in the main fuse box. there was no other fuse between this and the heater. I then tried running it through a voltage regulater that was converting 12v to 6v and absolutely nothing happened. It did not blow the fuse again but didn't switch on either.
Does anyone have any ideas?
Digger89L
Digger89L is offline
PostPosted: Fri Oct 28, 2016 4:58 pm    Post subject: Re: Eberspacher B2 Rebuild Project Reply with quote
" everything is good except that I am missing the intake tube that goes in the fender well... "
"Air intake tube" ? isn't that the exhaust outlet that goes to the fender? I think it gets its 'intake air' from under the hood ...doesn't it?
I just stumbled across this thread, so I have read it all so I don't know if this was covered, but .....back in the day, I had a 1968 Beetle and couldn't find a 12v gas heater, so I installed a 6v unit. I put a 6v battery under each side of the rear seat and ran the the gas heater off one battery and the rest of the car's electrics off the two connected together. I can't remember how I did the wiring, but I'm sure someone on the forum could explain. So ...in the case of running a 12v heater in a 6v system, couldn't the same idea be applied??
"If you can't fix it with pop rivets, crazy glue and duct tape, or hold it together with zip ties, velcro or magnets, it REALLY is broken."
Bruce
Bruce is offline
PostPosted: Sat Oct 29, 2016 10:38 am    Post subject: Re: Eberspacher B2 Rebuild Project Reply with quote
Your voltage converter doesn't work because it doesn't put out enough power. It's likely limited to a small current output.
If you ran your 6V heater on 12V, you have probably damaged things like the fan, glow plug, series resistor, pump, etc. that were all designed to run on 6V. All of these components need to be changed for 12V versions. The most economical way to find them is to buy another heater body that has them. Then you throw away your junk 6V heater and put the 12V heater in.
DAVID66000
DAVID66000 is offline
PostPosted: Sat Jan 14, 2017 8:07 am    Post subject: Re: Eberspacher B2 Rebuild Project Reply with quote
Hello I'm french ! Happy New Year
I own a ladybug of 1963 equipped with an eberspacher 200 B2
When I pull the zipper the fan turns the candle heats (I put my hand on the corp of the candle)
But no heating! I hear no clic clic clic
No red light in cockpit!
I did test ladybug at the stop!
Do you have to wait how long before heat release or pump activation
(The pump membrane is clean)
thanks in advance
Have you facebook to talk more easily and exchange photos
DAVID66000
PostPosted: Mon Jan 16, 2017 11:41 am    Post subject: Re: Eberspacher B2 Rebuild Project Reply with quote
Hello
I still test my B2 6 volt eberspacher! The pump made no noise so I removed the pump and cleaned the connections and electrodes!
And direct drill on battery for test and super it works again (click click)
I have everything replaced on eberspacher, but it does not arrive to aspier fuel of the reservoir .... nevertheless it does well click click and the candle heats!
Must there be a minimum of fuel in the tank (10 liters)
Have you facebook to communicate and send photos
thank you
DAVID66000
PostPosted: Thu Jan 19, 2017 6:36 am    Post subject: Re: Eberspacher B2 Rebuild Project Reply with quote
Help please Laughing Cool
thomas.
thomas. is offline
PostPosted: Thu Jan 19, 2017 7:01 pm    Post subject: Re: Eberspacher B2 Rebuild Project Reply with quote
Have you tested that the your fuel pump is actually pulling gas from the tank. If not you might fill up your glass filter to prime it. Also make sure no other electrics are on when you start it and take the rpm's up until red light goes on.
DAVID66000
PostPosted: Mon Jan 23, 2017 8:56 am    Post subject: Re: Eberspacher B2 Rebuild Project Reply with quote
Hello my fuel pump works but I have to change the hose! A pierced essence arrived
But I will start eberspacher on a bench, not in the car
But I wonder for later
Convert 12 volts into 6 volts
DAVID66000
PostPosted: Mon Jan 23, 2017 9:01 am    Post subject: Re: Eberspacher B2 Rebuild Project Reply with quote
Hello Thomas
My fuel pump is ok
Hello my pump fuel works, but I have to change the hose! A breakthrough essence has arrived
Convert 12 volts to 6 volts
thomas.
thomas. is offline
PostPosted: Mon Jan 23, 2017 9:53 am    Post subject: Re: Eberspacher B2 Rebuild Project Reply with quote
If your heater is 6volt don't use anything but 6volt on it. The glow plug can't take any more than 4volts and there is a device on your heater that makes sure it receives only 4volts. Have you read the technical section on these, there is quite a bit of info. The links I'm sending from there is for an earlier heater but it is basically the same as what you have.
http://www.thesamba.com/vw/archives/manuals/eberspacher_trouble_8542.php
http://www.thesamba.com/vw/archives/manuals/eberspacher_repair_8542.php
http://www.thesamba.com/vw/archives/manuals/heater_ac.php
ZENVWDRIVER
PostPosted: Mon Jan 23, 2017 10:13 am    Post subject: Re: Eberspacher B2 Rebuild Project Reply with quote
1960 single cab
'87 Toyota MR2
DAVID66000
PostPosted: Mon Jan 23, 2017 12:46 pm    Post subject: Re: Eberspacher B2 Rebuild Project Reply with quote
Good evening thomas I confirm my Eberspacher is complete and it does not have the case to decrease the tension of candle as on the B2 12 volts
My candle is a 194 grn and not THE 194 GRNS ...
thomas.
thomas. is offline
PostPosted: Mon Jan 23, 2017 3:39 pm    Post subject: Re: Eberspacher B2 Rebuild Project Reply with quote
The 12 and 6 volt b2 use the same glow plug. The spring looking piece that hooks to your glowplug regulates it to 4 volts.
DAVID66000
PostPosted: Wed Feb 08, 2017 4:25 pm    Post subject: Re: Eberspacher B2 Rebuild Project Reply with quote
Good evening voila I found in france on occasion a eberspacher B2 12 Volts
When it will be time to pass the car in 12 volts I will be able to recover two three parts of the b2 6 volts to adapt everything
Meanwhile the 6 volts works!
But I have a question ???
What is the difference between LA BERU 194 GRN AND LA BERU 194 GRNs ??
thomas.
thomas. is offline
PostPosted: Wed Feb 08, 2017 6:25 pm    Post subject: Re: Eberspacher B2 Rebuild Project Reply with quote
I'm pretty sure there the same seeing how they both take 4 volts to run. There may have been an improvement made and they added the letter to make note of it. I used one out of a 12 volt in my 6 volt and it worked the same. The truth is I never noticed the extra letter until you mentioned it and always understood the 12 & 6 volt were the same.
edit.. I went and looked at the new spare glow plugs I have, one is white one is pink . They both are 194grns and the one in my car has to be the same as the pink 194grns. So if you are wondering about purchasing I would go ahead .
Page 6 of 7
