Sodo Samba Member
Joined: July 06, 2007 Posts: 10735 Location: Western WA
Posted: Tue Jan 24, 2017 9:46 pm Post subject: Syncro front spring compressor (Harbor Freight + 4.75" spacers) |
Just so it's in the database..... Tool info with a PHOTO.
Here is a PIC of the Harbor Freight spring compressor 63262 $34.95 fitted to the Syncro front springs. In this pic, the spring is "loose" at this point.
Notice there are spacers on the bolts cut from 1/2" electrical conduit. The conduit fits pretty tight, any tighter and it wouldn't slide on. I'd bring your spring compressor bolts into the store and be sure they slide into the onduit before walking out with 10 feet of it. 4 3/4 inches long works fine. _________________
....KTMs, GasGas, SPOT mtb |
ragnarhairybreeks Samba Member
Joined: October 26, 2009 Posts: 1944 Location: Sidney B.C. Canada
Posted: Tue Jan 24, 2017 10:39 pm Post subject: Re: Syncro front spring compressor (Harbor Freight + 4.75" spacers) |
Tom,
I use the same compressors but cut the bolts down rather than use spacers. I think your method works better, easier wrench access to bolts.
I found the retaining pins with the spring loaded balls t be poorly made and on mine they jam.
Alistair _________________ '86 7 passenger syncro, converted to westy pop top, project still in progress
https://shufti.blog/
Old address still works...
http://shufti.wordpress.com |
Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 12172 Location: Port Manteau
Posted: Tue Jan 24, 2017 11:17 pm Post subject: Re: Syncro front spring compressor (Harbor Freight + 4.75" spacers) |
Take note that the threaded rods are bent under pressure up at the top, which can also allow them to jam in the compressed position. I had a HF clamshell compressor jam and bind up tight in partial compression on a BMW E36 front strut--it was not fun using three compressors like you have to compress the spring enough to dismantle the clamshell. _________________ Casey--
'89 Bluestar ALH
'01 Weekender --> full camper
NEAT, no ICE. |
Sodo Samba Member
Posted: Wed Jan 25, 2017 9:35 am Post subject: Re: Syncro front spring compressor (Harbor Freight + 4.75" spacers) |
Sir Hairybreeks I'm all for modifying a $35 tool to fit the task at hand, but also recall the bitter taste of "cutters remorse" and iits not pleasant.
Not suprising they are flexed, but they turn nicely with moly-lube. At first test I tried it only with the light oil that was on the tool and it seemed like a grease was necessary on the threads.
I have some liqui moly that I ordered on Amazon to "dose" an ailing transaxle (the "9,000 mile" rebuild). After looking at the oil that came out of the trans it was obviously beyond the restorative capabilities of any elixir. But it's been useful having the MoS2 lube around the shop for high-pressure sliding situations. I use it for my riv-nuts rig. It makes a significant difference lubricating threads (sliding surfaces). The off-axis forces that try to bend this compressor bolt is an ideal situation for moly-lubes (sliding).
Down at the bottom bolt head it looks like a lot of flex but up where the action is there's not much bending. The little spring keepers of this unit are at max size for this spring compressor for OEM Syncro springs. Another indicator this unit is about maxed out (per HF's design) on Syncro springs. But it works, it turns smoothly (greased). _________________
Kombi///M3 Samba Member
Joined: March 16, 2011 Posts: 427 Location: Vancouver, BC
Posted: Wed Jan 25, 2017 10:11 am Post subject: Re: Syncro front spring compressor (Harbor Freight + 4.75" spacers) |
Very good Tom.. I have the same..make more sense  |
flomulgator Samba Member
Joined: March 07, 2013 Posts: 951 Location: Leavenworth, WA
Posted: Wed Jan 25, 2017 11:36 am Post subject: Re: Syncro front spring compressor (Harbor Freight + 4.75" spacers) |
That is briliant, I am doing the exact same job on my bmw with the exact same tool. On the bimmer though the front strut goes up into a bell structure. If it copied your example I could grab all 4 coils and make my life a lot easier. _________________ She's built like a steakhouse, but she handles like a bistro! |
vanonimous Samba Member
Joined: October 19, 2013 Posts: 366 Location: Burien, Center of the Universe
Posted: Thu Jan 26, 2017 12:56 am Post subject: Re: Syncro front spring compressor (Harbor Freight + 4.75" spacers) |
Wow, I re-bushed my whole front/rear suspension without spring compressor, I didn't even know one is needed.
After unbolting upper control arm, radius rod, sway bar, steering rod end and loosening the top shock nut most of the way there was almost no pressure on the spring. But my Syncro is stock height so that might be why. _________________ If happiness is being a mechanic, owning a Vanagon is nirvana.
Lighting upgrades: https://www.thesamba.com/vw/forum/viewtopic.php?t=578291 |
Sodo Samba Member
Posted: Thu Jan 26, 2017 1:06 am Post subject: Re: Syncro front spring compressor (Harbor Freight + 4.75" spacers) |
Van, you could be right. But when I was unscrewing the nut at top, and down to as few threads as I thought I should go, it still had tension. I didn't know how much. I THOUGHT I read in the Bentley a spring compressor was required so I bought one and proceeded in that path.
Now that it's apart I can see how you could probably do it with a jack from below, but I took the lower control arm off FIRST thus it never occurred to me.
TheSamba needs to be a thread titled "How to change a Syncro front shock". _________________
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15406 Location: Syracuse, NY
Posted: Thu Jan 26, 2017 9:10 am Post subject: Re: Syncro front spring compressor (Harbor Freight + 4.75" spacers) |
Sodo add a washer or 2 to the 'bearing surface' between the nut head and the conduit spacer will help in letting things turn easier. _________________
Abscate wrote: |
Sodo Samba Member
Posted: Thu Jan 26, 2017 9:47 am Post subject: Re: Syncro front spring compressor (Harbor Freight + 4.75" spacers) |
A couple thick washers with my secret sauce between them would reduce the friction against the face. But it "feels like" the real friction comes from the bending of the compressor bolts (in their threads).
In any case it looks like the way to do this is to remove the top nut while there is weight on the ground (wheels). Then (with no nut at top) just lift the vehicle weight off the spring with a hydraulic jack lifting the chassis(??). Reassembly may be difficult if the shock is not gas-charged..
I could have benefitted (years ago) from a Samba thread titled "How to change a Syncro front shock."  _________________
Posted: Thu Jan 26, 2017 10:05 am Post subject: Re: Syncro front spring compressor (Harbor Freight + 4.75" spacers) |
When I did this job on a stock Syncro, I used a combination of floor jack and compressors like yours. I had to use the screw compressors because the whole van lifted up rather than allowing the spring to compress, so it needed a little help.
When I make my own tools that rely on threaded rod I use the thick washers and flat roller bearings I've removed from old AC compressors. This can greatly reduce friction against whatever the rod is pressing against.
This is a better compressor for Syncro springs
https://shop.ktcautotools.com/products/macpherson-strut-spring-compressor-bmw-toyota-honda _________________ Casey--
'89 Bluestar ALH
NEAT, no ICE. |
Pcforno Samba Member
Joined: October 14, 2014 Posts: 596 Location: Santa Fe, nm
Posted: Thu Jan 26, 2017 10:59 am Post subject: Re: Syncro front spring compressor (Harbor Freight + 4.75" spacers) |
I've done this onerous job a number of times-
Stock springs- easy- disconnect radius arm and sway bar end link and it slides right in and out
Not stock springs- if you are redoing your front end then do exactly like Sodo has done and place the LCA under the positioned shock/strut combo which is hanging by it's top nut
Not stock springs- If you are not redoing front end then you absolutely need a spring conpressor and a lot of patience, the worst part is getting the shocks top end to clear the spring perch then center it in the hole. If anyone has tips for this I'd love to hear it!! |
Posted: Thu Jan 26, 2017 11:10 am Post subject: Re: Syncro front spring compressor (Harbor Freight + 4.75" spacers) |
Sodo wrote: |
TheSamba needs to be a thread titled "How to change a Syncro front shock". |
I certainly could have used one, I claim my own ignorance on this one!
If I was working on a lift with car off the ground compressor would be a must! _________________ If happiness is being a mechanic, owning a Vanagon is nirvana.
Sodo Samba Member
Posted: Tue Jan 31, 2017 9:46 pm Post subject: Re: Syncro front spring compressor (Harbor Freight + 4.75" spacers) |
Works good reassembling too.
and as one feller on this forum ends his posts at times....
heh
GoWesty caught me in a moment of weakness. I can't believe race-shocks are available for a Vanagon.
If someday they're unobtanium I'll be glad I got them when I could.
I do like my gravel roads.... _________________
